Old 08-14-2009
Vehicle: 2003 Jeep Grand Cherokee (WJ)
Post 30 Minutes and more cargo space in a WJ...
an ez way to gain some storage space in the WJ...
all you need is:
- a socket set
- a torx bit
- (4) wire lock pins 5/16" x 2 1/4" (2 1/4" usable, 2 1/2" total length usually)
- a drill and 21/64" bit (next step up from 5/16")
in a ZJ or XJ, you can remove the rear seat bottoms when you don't need them, but in the WJ they are permanent... or they were...
so when you flip the rear seats down, you have to flip the bottom part up, and you end up with this:
take the rear seat bottom out including the brackets, i think it was a 10mm:
you might could do the next steps without removing the brackets, but i found it easier to just take the brackets off, can't remember which torx bit it was:
drill out the end of the bracket hinge that is pressed over like a rivet:
after you drill it, you may still need to use a punch to remove the hinge:
drill out both parts of the bracket to 21/64" and verify the lock pins will fit, then repeat everything for the other bracket:
bolt the back portion of the brackets back to the floor:
now you have an ez to remove lower back seat, here it is installed:
and here it is removed only on one side, demonstrating how much space you gain:
Old 11-29-2009
two_ton_anchor's Avatar
two_ton_anchor two_ton_anchor is offline
Vehicle: 2010 JK
Reputation: two_ton_anchor is an unknown quantity at this point
Default Re: 30 Minutes and more cargo space in a WJ...
Here's my attempt at it....
Wrangler Cargo Basket jgaz Jeep Specific 15 08-23-2015 10:42 PM
Pima Air and Space Museum Photo Gallery matt@expaz Photography & Videography 3 02-25-2013 08:05 PM
Need suggestions on how to use this space PMA4x4 Jeep Specific 8 09-24-2011 05:05 PM
Cargo camper azarmentrout Camping & Overland Living 15 12-08-2010 11:24 AM
cargo net??? jburns All Other Activities, Gear & Resources 0 09-24-2010 10:00 PM
