Old 06-05-2018
dzJeepChic's Avatar
dzJeepChic dzJeepChic is online now
(Diane) (KD7JPC)
Vehicle: '92 XJ
Default Re: Big Tuna's "Building the Dub!"
Looking good!
My '92 XJ Clifford
Old 06-19-2018
BigTuna117's Avatar
BigTuna117 BigTuna117 is offline
(Michael)
Vehicle: "Pegasus" 1999 Jeep WJ 4.7L
Reputation: BigTuna117 is an unknown quantity at this point
Now we get to one of the most important parts of the build thus far. The part where I play "Lets pay money to fix a bunch of self-inflicted problems but also look cooler at the same time." Recently I bought IRO's front long arm upgrade kit, which meant it was time to install them! Basically, everything suspension related over the last 4 years has been leading to this. As it turns out, the IRO adjustable arms no longer use a stop-nut to cease the adjustable joint. A built in clamp holds things quite securely, and without the hazard of the stop-nut loosening. I did find that my Core 4x4 short arms did hold up pretty well, all things considered. With all of the overall adjustments to the suspension, I found myself with a completely re-aligned front axle, and fresh, proper angles in the rear. All of my driveline vibes, bump-steer, and strange clunks and rattles have disappeared. She purrs down the road, with only engine roar audible.
The new control arms themselves are extremely beefy. Even though I went with IRO's older "Iron Y" 3-link Radius Arm setup, I feel like this is a great value for someone looking to go to 4" on a budget, or if you have been slowly accumulating parts like I have.
I didn't take any pictures while working, it took long enough without the camera in my hand!
There are a few parts to work out, though. The Jeep WILL NEED extended brake lines and coil retention in order to articulate past "sway bar normal." In other words, disconnecting the sway bar is currently not an option, unless I want to use my brake lines as limiters. But for now, she behaves much better on the tired Mohave Valley roads, so I'll take that as a victory.
Old 06-20-2018
Number7's Avatar
Number7 Number7 is offline
(George)
Vehicle: Number 7
I like it, long arms are the way to go.
George & Diane
4:88 Gears / Super 35 Rear
Dana 30 Front w/ Warn Hubs
TeraLow 4:1 T-Case
OX Lockers
Every Dog Has His Day!
Old 06-20-2018
scottL's Avatar
scottL scottL is offline
Vehicle: 2001 jeep cherokee
I see rock sliders in your future.
Old 06-21-2018
BigTuna117's Avatar
(Michael)
Oh yes.
Hopefully this year, too.
Old 06-27-2018
BigTuna117's Avatar
(Michael)
I decided to upload a review of the Core 4x4 Control arms I've been using for the last few years.
Old 07-16-2018
BigTuna117's Avatar
(Michael)
Finally began re-working the exhaust. I began to see severe power loss consistent to a clogged catalytic converter. I cut the main cat off, and replaced the Y-pipe. Mine is equipped with the dual mini-cats for California compliance, so of course that's the model I went for. New O2 Sensors all around too. This is also a pretty good example of what the Anker Roav dash cam is capable of.
I still need to install the new muffler, But it's looking like that will be next week.
Last edited by BigTuna117; 07-17-2018 at 05:43 PM. Reason: Trying to fix video, to no avail.
Old 07-17-2018
scottL's Avatar
Video link does not work for me but good to see new work-log posts here.
Old 07-17-2018
BigTuna117's Avatar
(Michael)
Interesting, something has broken the last two videos I posted. I wonder how I go about fixing this?
Old 09-17-2018
BigTuna117's Avatar
(Michael)
While y'all were out @ Cinders...
Meanwhile, I've been diagnosing a temperature issue in the Jeep. It's not so much that the Jeep is overheating, rather more "bouncy needle syndrome" Than I'd like to see. Some fluctuation between 190-210 is pretty much expected with the aftermarket setup, as the system heats and cools under load, BUT... 215-220 tells me something is afoot. I replaced the rad cap (which was the wrong pressure it turns out), which helped some. My suspicion is actually the new Y pipe. It not only has larger catalytic converters on it, but a section appears to run closer to the oil pan than on the previous y-pipe. The temp spike seems to correlate more with engine rpm rather than load, which leads me to believe that perhaps the new Y-pipe is splashing excess heat into the oil via the pan, and causing the system to run hotter than expected. Today I further tested this theory by clamping on a piece of 2" exhaust wrap parallel to the "close contact" point, Using this wrap material as a makeshift heat shield rather than wrapping the exhaust, I was able to drive to Las Vegas and back (about 1.5 hours each way) without passing 215. I will double up this piece of wrap and see if I can push temps down further. I will also probably add an oil cooler at some point in the near future, too.
"Ultimate" Trail Welder & Jumper Cable Kit theksmith All Other Activities, Gear & Resources 21 03-15-2017 08:00 AM
"how an obsessed explorer found and lost the world's oldest subway" theksmith Trail Info & Other Destinations 3 07-27-2016 05:11 AM
New "Yukon Cold Locker" rugged/extreme coolers from Igloo theksmith Trail Cooking & Kitchen 22 04-29-2012 10:24 AM
GOTMTNS 2004 2WD Dodge Ram "Do It All" Rig Build GOTMTNS Your Rig! 28 04-13-2012 01:12 PM
