Old 05-16-2012
klaykrusher's Avatar
klaykrusher klaykrusher is offline
Vehicle: '14 JKUR
Reputation: klaykrusher is on a distinguished road
Default Tech Question: Grease type and ball joint removal
So I have a couple questions.
Mechanic I am not, done some tinkerin', but it's time to dive in. I am replacing my driver side axle assembly. I have read through web and service manual instructions. They say to grease the splines, but cant seem to nail down the type/kind of grease to use. Some photos show a red grease, others with the standard blackish used for ball joints, u-joints etc. I assume the type matters. I'll also be contacting Toyota to get their specs, just wondered the opinions of others.
Also looking for tips/tricks to remove the upper ball joints. I have a puller, looks pretty straight forward. Called a shop for a quote and they wanted 170 labor and 1.6 hours per side. So not sure if there is more to it than meets the eye.
~ Dave
Old 05-16-2012
(Steve) (KG7EWF)
Vehicle: CJ7 - OlBlue
Default Re: Tech Question: Grease type and ball joint removal
The splines can be lubed with ANY chassis lube, which is there basically to keep the splines from corroding together, making it difficult -to- impossible to disassemble later...
Even with your pic, I don't know enough about Toyota's indipendent frt suspensions to be able to authoritatively answer the ball joint removal question posed. From your pic, unless I am missing something, it does however, appear to be a rather straight forward job, once the veh frame is supported on jack stands and wheel/tire removed for access... Might be worth while to get another opinion from someone who knows Toy's on this one...
Old 05-17-2012
6x6pinz 6x6pinz is offline
Vehicle: Pinzgauer 712
Reputation: 6x6pinz is an unknown quantity at this point
its pressing them out and back in that is the trick. Some go fairly easy while others are more of a pain. I am not a gambling guy and for $170 I would have them do it. I know the last set I did I would have paid twice that (what a pain they were).
Old 05-17-2012
Vehicle: '14 JKUR
Thanks guys. For 170, i wouldn't think twice, but that is per side and just the labor. Another place wanted 460, again just labor. That's why I'm leaning toward doing it myself. I read where an air chisel/hammer did the trick verses beating on it or using the puller. I'm still on the fence though, gonna call a few more places.
~ Dave
Old 05-17-2012
mbuckner's Avatar
mbuckner mbuckner is offline
(Mike) (KE7GRM)
Vehicle: 2001 TJ
Reputation: mbuckner is on a distinguished road
Have you ask the question on any of the Yota forums?
Old 05-19-2012
Vehicle: '14 JKUR
I've been reading the forums and write ups. I would be willing to try the air chisel, but I think it make sense to have a shop do the uppers. I'm getting quotes for 1.5 to 2.5 hours per side. All are saying steering knuckle needs to come off, so for me to try and remove it while on the vehicle, I think I'm asking for a lot of trouble and unnecessary stress. Sometimes you just have to know when to let the pros do it....
~ Dave
OEM-Type bottle jacks gcdaz Classifieds: Parts & Equipment For Sale 2 02-09-2015 12:08 PM
What type of trails do you like to run? Number7 Trail Info & Other Destinations 32 11-02-2014 03:27 PM
UTV for expedition type riding NEVERENOUGH Bikes / ATV / Side-by-Sides / UTV 6 09-23-2013 01:42 PM
SOLD - Adjustable ball joints for 99-04 Grand Cherokee (WJ) theksmith Classifieds: Parts & Equipment For Sale 2 06-04-2012 06:01 AM
$40 grease! theksmith All Other Activities, Gear & Resources 3 09-22-2011 05:34 AM
