Old 02-03-2018
Number7's Avatar
Number7 Number7 is offline
(George)
Vehicle: Number 7
Question What's wrong with this drive shaft?
Theksmith gave me this front drive shaft a long time ago. It came off of his WJ when he upgraded to JK axles. I installed it on Clifford recently, and found out that, when in 4 wheel drive and the Jeep is under load (i.e.: going uphill or making a hard turn) there is a clunk sound for every revolution of the drive shaft from the CV joint.
I took it out and looked it over, and I think I know what the problem is. Besides the caps are missing, what do you think is the problem?
George & Diane
4:88 Gears / Super 35 Rear
Dana 30 Front w/ Warn Hubs
TeraLow 4:1 T-Case
OX Lockers
Every Dog Has His Day!
Old 02-03-2018
Curly's Avatar
Curly Curly is offline
(Tim/Curly) (KF7INL)
Vehicle: 97 Jeep Wrangler
Reputation: Curly is on a distinguished road
Default Re: What's wrong with this drive shaft?
If the ujoints are tight, the centering ball in the CV is most likely worn. Replaceable. Be sure to get one that can be greased.
I Start What I Finish!
Old 02-03-2018
(Steve) (KG7EWF)
Vehicle: CJ7 - OlBlue
Ditto what Tim said. Also, be sure to look closely at both the driveshaft yokes, and the mating yokes at both the t-case & the axle, to make sure there are NO witness marks where the yokes may be interfering.
Old 02-03-2018
Curly's Avatar
Looking again, the ends look out of phase.
Old 02-03-2018
(Steve) (KG7EWF)
Good catch Tim ! ! ! It does indeed appear as if the slip yoke is mis-positioned by approx one spline.
Old 02-04-2018
Number7's Avatar
(George)
Vehicle: Number 7
Yes the u-joints are misaligned. The cv joint is tight and nothing hits or rubs. I pulled the yoke off and rotated it one spline and it misaligned the other direction. That slight misalignment must be causing my clunking.
George & Diane
TeraLow 4:1 T-Case
OX Lockers
2005 LJ Rubi Front Drive Shaft $150 dzJeepChic Classifieds: Parts & Equipment For Sale 0 08-22-2014 02:21 PM
4x4 Recovery goes wrong dzJeepChic Survival & Emergency Preparedness 5 12-05-2013 08:10 AM
drive shaft length trackiscrack Jeep Specific 4 11-30-2013 05:03 PM
WJ V8 Rear Drive Shaft Bradywgn71 Classifieds: Wanted 11 11-18-2013 09:21 PM
axle shaft mbuckner Classifieds: Wanted 1 09-25-2011 08:35 AM
