Old 06-22-2019
jgaz jgaz is offline
(Jim)
Vehicle: 2006 LJ
Default Can’t Drill Straight?
I don’t think I’ve ever posted these tools on ORP. Its getting hot in the garage in the afternoon and too hot to hike so here goes.
Even after 50+ years of practice I still struggle at times (a lot of times honestly) keeping the drill or tap square with the surface.
Santa brought me these guides a couple years ago. Made in the good old USA.
https://biggatortools.com/
These two have replaced most of the homemade guides I collected thru the years.
The latest use that showed how handy these guides can be was a repair I did on my power washer. I needed to remove the wheel in order to replace a leaking tire tube.
The wheel was originally retained by a stupid, pushed on, pal nut, that had to be mangled in order to remove the wheel. I decided to drill the 5/8” axle shaft for an old school cotter pin. The chances of me drilling the hole straight thru the center of the shaft were about zero.
The drill guide has v notch in the bottom to center it on a round shaft.
Sometimes the right tools make all the difference.
Old 06-25-2019
(Steve) (KG7EWF)
Vehicle: CJ7 - OlBlue
Default Re: Can’t Drill Straight?
Thanks for the link Jim... One can NEVER have too many tools...
Old 07-03-2019
GRUNT's Avatar
GRUNT GRUNT is offline
(Jarhead) (KE7TOG)
Vehicle: 93 YJ(LS powered)
Reputation: GRUNT is on a distinguished road
Great tool idea! Thank you, Jim.
60% of the time, it works all the time.
Ryobi brushless drill & get a tool free sale theksmith All Other Activities, Gear & Resources 1 11-30-2017 05:38 AM
AZ: Search and Rescue Drill 4x4Ham.com Events from 4x4Ham.com 0 02-09-2017 10:05 AM
7/8" drill bit to borrow Number7 Classifieds: Wanted 4 12-03-2016 04:22 PM
The 12V Trail Drill dzJeepChic All Other Activities, Gear & Resources 2 11-09-2013 04:09 PM
Straight Up's "New" M101 In-A-Rut Your Rig! 4 01-31-2011 12:41 PM
