Old 05-14-2019
subPar subPar is offline
(Parley)
Basic Member
Vehicle: 2017 JK Rubicon
Reputation: subPar is an unknown quantity at this point
Default Steering Component Upgrade for JK
So I went and did Box Canyon again today, and rather than take the bypass, I took the more challenging route. All went well but the steering wheel is off by about 2 inches now. Easy fix, but I want to upgrade some of the steering components now. I’m just not entirely sure what to go with to beef it up more in the front. Drag link and tie rod? And has anyone used the drag link flip kits on the JK? I like the idea of less bump steer but not if it means sacrificing strength where the drag link mounts.
Old 05-15-2019
Default Re: Steering Component Upgrade for JK
usually a drag link flip comes with a raised track bar bracket for the axle, which is important to keeping your steering geometry correct. that whole thing isn't the most necessary mod in the world until you've got maybe 4" of lift.
you can't flip the tie-rod as far as i know unless you get different knuckles.
i plan to get one of the 7075 aluminum tie-rods with offset GM 1 ton TRE's soon - it seems to really be able to take a beating. then i'd also eventually like to get the knuckles that raise the tie-rod, either from Rancho, Reid, or Teraflex.
several places sell the aluminum tie-rod i'm talking about, Barnes4wd, RPM, etc., here's a video:
i also like the look of the Metalcloak tie-rod, it's not aluminum but they have special TREs with less misalignment to prevent "tie-rod flop".
Old 05-15-2019
(Parley)
Basic Member
Sweet. Thanks for the info. I’ll check out those tie rods you were talking about. Haven’t had issues yet but that would be a bad one to have break on the trail. I was looking into the drag link flip but not sure I need it/want it now. Maybe I’ll just replace it with something beefier.
Old 05-23-2019
FYI, i was looking at Synergy's tie-rod and drag link and they have their own TRE's that match the JK taper so you don't need to drill or ream anything and yet they look even beefier than the GM 1-ton ends which DO require reaming:
i had Synergy's drag-link on my WJ with JK axles and it worked well.
...so now i'm leaning towards eventually getting Rancho knuckles and the Synergy tie-rod & drag-link.
chain of component failure - lesson learned gearhead Jeep Specific 5 05-14-2013 08:23 AM
Jeep Steering question PMA4x4 Jeep Specific 5 12-17-2011 08:20 AM
Steering wheel play macinyart Jeep Specific 6 03-31-2011 08:25 PM
Steering loose/knocking - LJ klaykrusher Jeep Specific 8 02-05-2011 10:29 PM
Steering Shaft for an XJ with 4.5 lift ?? CampnFever Jeep Specific 12 04-30-2010 03:42 PM
