Thread Tools Rate Thread Display Modes
Old 09-29-2018
4x4Ham.com's Avatar
4x4Ham.com 4x4Ham.com is offline
(W7AZO)
Offroad Passport Partner
Vehicle: n/a
Reputation: 4x4Ham.com is an unknown quantity at this point
Default AZ NV PA SD QSO Parties
This event is cross-posted from our sister club 4x4 Ham.
Note that only the first post from the original thread is shown. Click here for the full thread...
October 12-14, 2018 is the date for the AZ NV PA and SD QSO Parties!
AZ NV PA all have the same exchange. This makes working all three simultaneously easy. For PA simply put the signal report (59 usually) in for the serial number. If your using N1MM+ Logger, or other loggers, simply "force" the log from other states. Then turn in the same Cabrillo file to all three parties. If your really good, you can edit your exchange file for N1MM+ so you don't have to force the other states exchange.
https://www.azqsoparty.org/
http://nvqso.com/
http://paqso.org/index.html
https://sdqsoparty.com/
Once again NV7CV will be working from a tri-county county line expedition in Nevada. We're looking forward to hearing you on the air.
Display Modes Rate This Thread
Rate This Thread:
You may edit your posts
