Old 02-08-2018
dzJeepChic's Avatar
dzJeepChic dzJeepChic is offline
(Diane) (KD7JPC)
Vehicle: '92 XJ
Default Re: The other blue XJ
Originally Posted by k9bxj View Post
I'm already signed up for March 31 in Payson.
Sweet! See you there.
My '92 XJ Clifford
Old 02-24-2018
k9bxj's Avatar
k9bxj k9bxj is offline
(David) (k9bxj)
Vehicle: 01 Jeep Cherokee
Reputation: k9bxj is an unknown quantity at this point
Couple mods done in the last couple years.
Hood vents. I got these to help with the engine overheating (before the stroker), when driving the grades to Payson. The true test will be this summer, when driving the grades with the stoker.
Sector shaft reinforcement from Boostwerks. I didn't need this, since the XJ has the hydro-assist steering. I got it, because it ties in the front of the unirails at four bolts per side.
http://www.boostwerksengineering.com...Brace_p_8.html
Old 02-24-2018
adriaanvn99 adriaanvn99 is offline
(Adriaan) (ZS1AVN)
Vehicle: 1998 Jeep Cherokee XJ Limited
Reputation: adriaanvn99 is an unknown quantity at this point
How do you find the Boostwerks brace?
I need to replace my steering box and was thinking of going with a Bluetop box and a brace. However, I am choosing between the Ironman4x4Fab kit, Boostwerks brace and the JCR front unibody tie in kit. I like the Boostwerks brace because of the recovery point integrated into it. Curious to hear about your input about the performance of the Boostwerks brace
Old 02-25-2018
k9bxj's Avatar
(David) (k9bxj)
Before the brace, I had the XJ on an RTI ramp to gauge suspension flex and any interference. I noticed the gap between the bumper and the driver-side headlight was greater than between the bump and the passenger-side headlight. This told me that the front unirails were moving to do the weight and leverage of the bumper and front axle. After installing the brace, the gap change is now minimal or eliminated.
I'm fore anything that helps tie-in the unirails. IMO, every XJ should have a two hitch in the rear and this brace (or toe hitch) in the front. The front crossmember is too lightweight.
Old 03-11-2018
k9bxj's Avatar
(David) (k9bxj)
New bling for the XJ, that you won't see. Front axle still had the original spindles. The spindles were rough and pitted, where the wheel bearing sit. The axle is noticeably quieter, when the hubs are locked. We also put in new bearings and seals.
Old 03-12-2018
Reputation: theksmith will become famous soon enough
shiny where it counts!
the famous Yellowstone hot spring was blue in the 1950s theksmith Land Use & Environmental Concerns 1 03-13-2015 05:31 PM
Blue Ribbon Coalition Legal Update dzJeepChic Land Use & Environmental Concerns 4 07-07-2013 10:03 PM
Blue Ribbon Coalition Needs Our Help! dzJeepChic Land Use & Environmental Concerns 0 06-07-2012 12:07 PM
Blue Dick Mine attempt-Bradshaws-May 12-13, 2012 teddyearp Trip Reports & Photos 1 05-28-2012 07:47 AM
Blue Ridge Reservoir DayDreamin' Camping & Overland Living 5 09-18-2009 10:39 PM
