Old 01-06-2013
Radio Inexpensive Hand-Held HAM Radio
i mentioned to some of you at the holiday party having read good reviews on this inexpensive hand-held HAM rig:
it's a BaoFeng UV-5R+ (UV 5R Plus), currently on amazon for EDIT now only $38! (was $55): http://amzn.to/1l7zPjy
it's not going to compete on features with a Yaesu or Kenwood, but if you're just looking for better trail communications than CB, i think this will fit the bill. note that you probably want the newer "plus" (UV-5R+) model, not the original UV-5R - i read a fair number of complaints about how the menu system works on the original and that it was improved on the plus model.
be sure to check out the amazon reviews and also the eham.net reviews (http://www.eham.net/reviews/detail/10755).
i'd go ahead and get a different antenna. you'll get the best experience with an external vehicle mounted antenna, but even a quality on-unit antenna would be worth the cost. the Comet SMA24J or Diamond SRJ77CA would probably be good for on-unit replacements and are around $20.
it does not come with a car/12V adapter, but the reviews indicate good battery life. there are car adapters available (listed as battery eliminators): http://amzn.to/1gyv007
so for only $55, or $75 with a good antenna, there's no reason not to get your HAM license!
Old 01-06-2013
gearhead's Avatar
gearhead gearhead is offline
(Mike) (KF7OGY)
Vehicle: 1991 YJ
Reputation: gearhead is on a distinguished road
Default Re: Inexpensive Hand-Held HAM Radio
cool!
Old 01-07-2013
J.R.'s Avatar
J.R. J.R. is offline
(J.R.) (KE7JRW)
Vehicle: '05 Silverado
Reputation: J.R. is an unknown quantity at this point
I do have one of those UV -5R's. Actually HAD , I just recently gave it to a friend because I just bought to try out the new UV-5RA (actually it should be here today). Supposedly the RA is pretty much the same as the R just an updated firmware and a different case from my old one. I'll have to see how I like it when it gets here.
I have to agree the Baofeng is a pretty good little unit. Its not like my FT-60, but pound for pound, $ for $ you cant beat it.
Oh and a BIG piece of advise... Get the programming cable when you buy the tx. Programming from the keys is a PITA, but with the cable, off your computer is a breeze.
Great info on the 5R series of radios for those considering one.
http://www.miklor.com/uv5r/
PS.
I didnt like the Baofeng UV-3R at all.
Old 01-07-2013
J.R.'s Avatar
(J.R.) (KE7JRW)
The "guy in the van" just dropped off the new 5RA.
I will keep ya'all posted, but my impressions so far are: 1. TX seems to be put together just as well as the old 5R, but just a little fancier with the cool black chrome grill. And 2. The lady's voice in the box is Much easier for me to understand.
With my old 5R the voice had an Asian accent and some of the terminology is different from what Im used to using . The 5RA is apparently marketed at the American market (hence the "A" designation) and the girl in the box has an American accent and uses more familiar terms for things like frequency etc...
I hear that there is also a 5RE that is marketed for the European market....maybe British accent? Russian? French? IDK.
Also,Im not sure of the 5R+ I havnt had one to compare to.
Old 01-16-2013
kmayesaz's Avatar
kmayesaz kmayesaz is offline
(Ken) (KE7VOM)
Vehicle: 2013 Jeep Rubicon Unlimited
Reputation: kmayesaz is an unknown quantity at this point
Thanks for the info. I ordered one this evening!
Old 01-22-2013
kmayesaz's Avatar
(Ken) (KE7VOM)
Received my UV-5R Plus radio today. One problem though: Windows 8 does not support the USB to Serial Driver. So I will have to program by hand.
Old 01-22-2013
K7VZ K7VZ is offline
(Virgil) (K7VZ)
Vehicle: 2014 Ram
Reputation: K7VZ will become famous soon enough
Don't do that. It's good to know how to manually program, but you'll waste too much time doing it. I could help you program it, if needed.
Also, for programming check out Chirp vs. using the software that came with it. http://chirp.danplanet.com/projects/chirp/wiki/Home
Old 01-22-2013
kmayesaz's Avatar
(Ken) (KE7VOM)
Thanks. I would like your help. I went to the Chirp site but it also states only Windows 2000/XP/Vista/7 are supported. Windows 8 has a problem with the serial port or something.
thanks
Old 01-22-2013
looks like the programming cable uses the prolific serial to usb chipset and only the latest version of that chip has windows 8 drivers...
there's always the possibility that it actually has the newer chip but everyone is just still pointing to the old driver... you might try installing these newer drivers just to see: http://www.prolific.com.tw/US/ShowPr...id=225&pcid=41
install, reboot, then plug in the cable and see if a COM port shows up for it in device manager
Old 01-23-2013
(Virgil) (K7VZ)
Vehicle: 2014 Ram
I'm using Windows7 64bit and was able to get it to work with the Prolific drivers that came on the CD. The Baofeng software kept closing and opening itself, so I switched over to Chirp and it worked fine.
how to get Ham radio license? Jomax Communications & Other Electronics 4 02-06-2015 08:16 PM
Why you should get a HAM radio now and then get your license theksmith Communications & Other Electronics 16 12-20-2013 08:31 PM
inexpensive entry-level HAM radio theksmith Communications & Other Electronics 2 03-17-2011 07:27 AM
Ham Radio Satellites KC7IPY Communications & Other Electronics 5 03-19-2010 05:43 AM
Ham Radio Info K7VZ Communications & Other Electronics 8 02-15-2010 07:26 AM
