Old 04-16-2016
Weather Sunny Re: Vehicle mounted camp area light (LED strip)
Originally Posted by curbjumper View Post
Hi Kristoffer, there are so many benefits of viewing the undercarriage area at night vs. day. It is much easier to ID an issue or repair.
Me...I would probably nail the LED's the day after a trail run with the power washer without thinking. What suggestions would you recommend to install & protect the LED's? Thanks.
there are several companies making dedicated rock light kits using different types of pods and most claim to be waterproof - you'd have to look at the individual construction to see how well you think their claims would hold up.
however, if you did your own using LED strips, just make sure to get the fully encased type. from the place i used for this project, scroll down on this page and you'll see they offer IP68 "whole injection" as one of the waterproofing options: http://www.ledlightsworld.com/smd-50...leds-p-92.html
another place i've purchased from several times is Oznium here in the US and they offer a similar fully potted strip: https://www.oznium.com/smd-bar
i wouldn't be worried about the pressure washer at all with fully epoxied lights. note that those kind don't come adhesive backed, so you'll need to figure out some little clamps or whatever to mount them (which is probably better for long term durability anyway).
be sure to use quality adhesive-lined (aka marine) heat shrink on the electrical connections between the strips.
i've just recently ordered another set of those cheap COB style daytime running lights (which are definitely not waterproof) for an experiment. i'm going to wrap each one fully in clear 3/4" adhesive lined heat shrink tubing, leaving about an inch on each end which i'll squish flat when i apply the heat. that should make an inexpensive but fully submersible rock light. the flattened heatshrink extending past the ends will also allow me to screw it to something with one screw through each of those "flaps". we'll see how that goes!
Old 08-21-2018
mesach mesach is offline
(Marc)
Vehicle: 2015 JK Unlimited Rubicon
Reputation: mesach is an unknown quantity at this point
Default Re: Vehicle mounted camp area light (LED strip)
Among the PLETHORA of things I have coming this week is this little gem which I came across yesterday while searching for something else
Brawlee Jeep Wrangler LED Rear Glass Lift Gate Dome Light Bar
https://www.amazon.com/gp/product/B076KR77Y9/
I don't know what the color temp of the strip is, but I figure if it craps out, then I can just take out the strip and solder in a new one that is RGB and add in a controller, the nice part about that one is that it has an aluminum channel and a diffuser (which I think is white but we will see)
Old 08-21-2018
great find!!
Old 08-27-2018
Lightbulb Re: Vehicle mounted camp area light (LED strip)
mesach reviving this thread got me off my butt... one of the wires going from the hardtop to my camp strip light had an intermittent break, so i finally spliced in a new section.
while i was in there i decided to ditch the dimmer and instead have a second light in red for times i don't want to overly-enlarge my pupils!
i already had an extra pair of "COB DRL" strips i accidentally ordered in red when i was doing my rock lights.
a new 3 position toggle (on-off-on) was installed in place of the old dimmer & switch combo.
the single red strip puts out plenty of light for its purpose and has a good spread even mounted up inside the hardtop.
my original white strip light is still mounted on the rear window, just wired to the other position on the new switch now.
Old 3 Weeks Ago
Zeep Zeep is offline
Vehicle: 05 Jeep LJR
Reputation: Zeep is an unknown quantity at this point
I'll be considering this mod when the weather breaks. Too damn cold around here now!
JEEP The AR-15 of the automotive world
Brightest DOT-Approved LED Headlights For TJ? rubicontrail.net Jeep Specific 0 09-01-2014 10:57 AM
Raxiom LED Lighting Giveaway! Offroad Passport General Talk 2 06-04-2014 05:30 PM
Great camp light for the $! tucsonWJ Camping & Overland Living 0 11-01-2013 08:58 PM
hitch mounted Trail Vise theksmith All Other Activities, Gear & Resources 6 02-25-2013 06:04 PM
GPS Mounted on winshield - State Laws klaykrusher GPS, Mapping & GeoCache 6 06-15-2012 07:44 PM
