Old 2 Weeks Ago
Default Re: JK Wrangler Push-to-Start, Hands-Free Keyless Entry & Remote Start
Originally Posted by SinisterJK420 View Post
Ok so I had some time and mounted the push button to the new bezel, I trimmed some of the lighter mount to get the button as flush as I wanted without using the bulky rubber trim. I should get to the wiring this week. What size resistors did you get nad where did you end up putting the resistors and the relay to. I'm probaly go a make a harness with the wires so it's nice And clean
i used 1/4 watt resistors, but 1/8 or 1/2 watt should be fine as well. i just zip-tied the relay and the heat-shrunk little resistor pack into the wiring harness and hid all the modules and wires up in the dash well.
Old 1 Week Ago
Ballistix Ballistix is offline
Vehicle: Wrangler
Reputation: Ballistix is an unknown quantity at this point
Just bought all the parts, should be in by Saturday. Perfect for a funday Sunday project. Thanks for this great write-up.
Old 4 Days Ago
Vehicle: Wrangler
One quick question. Did you cut the blank that came with the EC002-FO version fob, or did you find another flip out style jeep key to then cut? Seems kind of skinny and might not work.
Old 4 Days Ago
i had regular non-chip key copy made at Walmart for like $10 and then cut it up with a Dremel to make a custom blade for the FO style fob.
a standard Chrysler style blank that has worked with most Jeep/Dodge/Chrysler cars for the past 15 years will be available at any place that makes keys. it cuts up like butter with a Dremel metal cut-off wheel, or you could even just use a hacksaw and a file pretty easily.
i also still had to Dremel out the inside edges of the FO fob housing just a bit in order for the actual keyed portion to fold down into it. my particular keyed section had just one "bump" that was nearly the full width of the blank which prevented it from folding in otherwise.
Old 18 Hours Ago
Vehicle: Wrangler
Thanks for that. I'll take a look at my local home depot.
Finally got all the parts and I'm starting the wiring and I think I might have found a discrepancy. You said the Easyguard 20p has two large gauge red wires, but I don't see those. I do see that the Easyguard 6p and two large gauge red wires, is that what you meant? If so, do we just substitute Easyguard 20p for 6p? Photos for reference.
Old 14 Hours Ago
Attachment 4059
Attachment 4060
nice catch! yes it should have said Easyguard 6P has 2 large red wires. i just went back and and fixed the 3 places i could find where i screwed that up in post #4 - so it should read correctly as of now.
Old 14 Hours Ago
Vehicle: Wrangler
Was so confused for a sec, but then just looked over the wiring diagram and it made sense. Onto making a resistor pack and wiring in the relay now.
Old 13 Hours Ago
Vehicle: Wrangler
Also on the relay diagram, are 87 and 85 supposed to both connect to the blue/white wire and the white wire, all together? Or is 85 going to the blue/white and 87 to the white?
Old 11 Hours Ago
i have all 4 joined together (87 + 85 + blue + blue/white).
Old 1 Hour Ago
nice soldering iron choice - i've got the older analog dial version of that same one!
Ryobi brushless drill & get a tool free sale theksmith All Other Activities, Gear & Resources 1 11-30-2017 06:38 AM
dzJeepChic Entry in Ladies Offroad Challenge 2017 dzJeepChic Offroad Passport News & Info 5 06-10-2017 07:12 AM
inexpensive entry-level HAM radio theksmith Communications & Other Electronics 2 03-17-2011 08:27 AM
Other: March 26 - 27, 2011 AZ Game & Fish Outdoor Expo FREE!!! Offroad Passport Trip & Event Planning/Sign-up 0 03-14-2011 09:08 PM
Free USGS Topo PDF Maps & Acrobat GPS Plugin theksmith Trail Info & Other Destinations 5 09-17-2009 10:51 PM
