Old 01-08-2012
Jklee Jklee is offline
(Jimmy)
Vehicle: 95 Jeep Grand Cherokee zj
Reputation: Jklee is an unknown quantity at this point
Default 4:1 transfercase question
I am still looking for a transfercase to buy and I have come across these np231 with the four to one kits installed. If I understand correctly if I bought one of these I could keep my 4:10 gears in the axles for highway and still have a great crawl ratio with the 4:1 transfer case. Is that correct? Any of you have one? Like it ect?
Old 01-08-2012
GRUNT's Avatar
GRUNT GRUNT is offline
(Jarhead) (KE7TOG)
Vehicle: 93 YJ(LS powered)
Reputation: GRUNT is on a distinguished road
Default Re: 4:1 transfercase question
Yes, that is correct. I assume by saying you have 4.10 R&P gears that you have a 4 cylinder motor? My YJ was a 4cyl with the 4.10 R&P. It got around just dandy. Although, after I put in my 4 to 1 kit, I was able to get up and over anything I tried. In fact, sometimes the 1st gear with 4-Lo was too low and I used 2nd and 4-Lo. I was very pleased with my purchase as when in 4-Lo I could easily walk up terrain that other people were banging and gunning against. This made my heart rest easy for I did not have fear of trashing my jeep or breaking parts.
60% of the time, it works all the time.
Old 01-08-2012
(Steve) (KG7EWF)
Vehicle: CJ7 - OlBlue
Grunt explained it well... Bottom line is tha the 4:1 gearing of the t-case low range only affects gearing, when you have shifted the t-case to low range. Highway driving (high range in the t-case) will be un-affected.
Old 01-09-2012
macinyart's Avatar
macinyart macinyart is offline
(KC9PKI)
Vehicle: 1994 YJ
Reputation: macinyart is an unknown quantity at this point
I am using exactly that setup, although my 4:1 t case is from Teralow, along with 4:10 gears. I have also found that 4 Low and second gear is a bit more useful than First gear. My engine is a 4.0L but George (Number 7) has a 4 cylinder (gear ratio unknown at this time) goes anywhere he wants. I like it a lot and wouldn't go back.
The only difference between a rut and a grave is the depth.
4:1 Teralow w 4.10 gears, ARBs f/r
Currie rear end, 33" tires
Winch, underbody armor
Old 01-09-2012
Number7's Avatar
Number7 Number7 is offline
(George)
Vehicle: Number 7
I have mixed feelings about my 4-1. It is too low for running trails and sand dunes. In heavy rock and steep ledges it is not low enough. I should have went with a three speed t-case. George
George & Diane
4:88 Gears / Super 35 Rear
Dana 30 Front w/ Warn Hubs
TeraLow 4:1 T-Case
OX Lockers
Every Dog Has His Day!
Old 01-09-2012
(Jimmy)
What's a three speed case? Just a normal one?
Old 01-09-2012
Number7's Avatar
(George)
Vehicle: Number 7
StaK makes a three speed t-case, it's more money and requires some mods to make it fit. Atlas makes a four speed t-case also more money and mods. George
George & Diane
TeraLow 4:1 T-Case
OX Lockers
Old 01-09-2012
samwhite samwhite is offline
(Sam) (KE7QXI)
Member In Memoriam
Vehicle: Jeep JK 2009
Reputation: samwhite is an unknown quantity at this point
I just wonder if the cost of the kit is worth it. You could get a NP 241 with the 4:1 gears included. Maybe a 241 wouldn't fit.
Old 01-09-2012
(Jimmy)
I have the 242 and it went bad. I just try and upgrade when I have to replace something (if I can afford it). I was looking at going to a 231 or 231 with the 4-1. Not to sure what the 241 is from or if it would fit. What gears to you run in your axles George?
Old 01-09-2012
Number7's Avatar
(George)
Vehicle: Number 7
I run 4.88 gears with 33 inch tires ( these specs are in my signature line). Diane's XJ has a good setup, 4.56 gears, 33s and auto trans with the 231 t-case. It work great on trail and rocks. George
George & Diane
TeraLow 4:1 T-Case
OX Lockers
Tire Question AZBillyBoy Other/Multiple Brand Vehicles 14 11-29-2012 09:31 AM
Ipad question PMA4x4 Communications & Other Electronics 35 07-16-2012 09:59 PM
iPad question here too! PMA4x4 GPS, Mapping & GeoCache 4 07-05-2012 01:51 PM
SYE question Jklee General Talk 12 11-28-2011 07:45 PM
Wrangler Question AZBillyBoy Jeep Specific 7 10-23-2011 06:32 PM
