Old 12-17-2014
Default Android Tablet as a Head Unit & GPS - New Install
a couple weeks ago, Aimee went ahead got me my Christmas present early - a new Sony Z2 Tablet (4G Verizon edition)!
out with the old...
the new Z2 will replace my current docking XOOM tablet in the Jeep. the current setup performs many duties including GPS, offroad mapping, on-road navigation, stereo head unit, movie player for the projector system, OBDII engine interface, digital factory service manual, and gives me internet access anywhere there is 3G/4G service or free WiFi.
the XOOM is easily removable so that trail planning, checking email, and general web surfing can be done from inside the house, at starbucks or a in a hotel room.
the plan for the new tablet is to do all of this and some more (thanks to it being a faster and more capable machine). it's a similar size and still runs the Android OS, so much the transition will be seamless.
the Z2 is much thinner/lighter than the XOOM and only a little wider (in landscape).
here's a reference shot of how the XOOM currently looks in the Jeep:
...in with the new
of course the custom mount and dock for the XOOM will have to be changed out for something that fits the Z2. i also recently ditched all of the complex electronics behind the XOOM installation and will have a much simpler infrastructure to support this tablet.
i'm still waiting on a couple items, but here's what i have so far for the new install:
i also recently re-did all of the audio components (new amps, speakers, EQ and BT receiver). i still need to build an enclosure for the new sub in order to complete that part of the project.
Old 12-17-2014
dzJeepChic's Avatar
(Diane) (KD7JPC)
Vehicle: '92 XJ
Default Re: Android Tablet as a Head Unit & GPS - New Install
Nice work!
My '92 XJ Clifford
Old 12-17-2014
ChrisD's Avatar
ChrisD ChrisD is offline
(Chris)
Vehicle: 2008 Jeep Wrangler Unlimited Rubicon
Reputation: ChrisD is an unknown quantity at this point
I like that one. Looks much better than my Parrot Android unit.
OffroadDance
2008 Jeep Wrangler Unlimited Rubicon with 4'' Coilover Lift, 40'' Toyo MT, UD60´s front and rear axle, Warn winch, Genright front bumper, TNT Customs rock sliders, Rockhard underbody protection, CB, 5.7 l VVT Hemi....
Old 12-17-2014
Originally Posted by dzJeepChic View Post
Nice work!
i didn't do anything new yet!
Old 12-17-2014
K7VZ K7VZ is offline
(Virgil) (K7VZ)
Vehicle: 2014 Ram
Reputation: K7VZ will become famous soon enough
You did a great job!
Old 12-17-2014
jhart's Avatar
jhart jhart is offline
(KF7AJT)
Vehicle: 2004 Jeep LJ
Reputation: jhart is an unknown quantity at this point
Some people are easily impressed.
2004 LJ, I6, BFG AT 33s, 3" Teraflex lift, d30/d44, open/LSD.
- Joe KF7AJT -
Old 12-18-2014
protection - back
because of the way i'll be mounting the tablet, a case won't work. i did however still want to avoid scratching it up with daily use, so i ordered a decal type skin for the back: http://amzn.to/13fscVp
it's a "black brushed aluminum" skin, fairly thick and with a lot of physical texture. i was worried if it might not stick well to the "soft feel" back of the Z2, but it seems to be staying in place. the cut/size was perfect, including the cutout for the camera. it also doesn't show every little touch (with oily smudges) like the factory coating did.
protection - screen
of course i needed a screen protector as well. i ordered a SOJITEK brand through Amazon: http://amzn.to/1r2lpsQ
i'm not impressed with the SOJITEK though as it was cut/sized poorly. it is literally the exact width/height of the tablet's glass, with not even a hair of forgiveness. this makes installing it a complete PITA, which i could accept if the rest of the fit was perfect. however the corner radius is sized wrong causing it to overhang on all 4 corners and the camera cutout is not perfectly centered.
i went with the anti-glare finish for the first time, and i'm still not sure if i like that or not. i'm waiting to try out this matte finish in the Jeep before i order a different brand that hopefully fits better.
protection - security
my requirement of easy docking has the negative side effect of making it an easy theft so i purchased accidental damage and theft insurance. see this thread for more info on that topic: http://offroadpassport.com/forum/showthread.php?t=4006
i have my Tasker (automation app) scripts so the tablet stays locked most of time. i have the Android Device Manager enabled which helps you track down a stolen/lost device and remotely erase it if needed. my Tasker scripts are also set so that if the device is rebooted it will start up locked, with 4G/WiFi/GPS enabled - that way Device Manager can actually remotely contact the tablet to help locate it. the script also starts it up at full volume as you can remotely ring it with Device Manager too.
Old 12-18-2014
physical mount & power
the Z2 has a magnetic power port on the bottom. i thought this would make creating a dock for it easier and that was a concern when picking which new tablet to get.
later i ran across a cradle with power adapter made by ProClip: http://www.proclipusa.com/tablet-hol..._leftorright=0
it's expensive for what it is IMO, but i guess there's low demand. i went ahead and ordered it despite the cost as i think it will save me a bunch of time/aggravation versus creating a custom solution. i may still need to fabricate a way to lock it into the cradle at the top depending on how well it stays in while offroading.
it's been backordered, so that's the main thing holding up the install right now.
other connections
besides power, i need to get to the Micro USB port in order to attach an MHL (HDMI) adapter for the projector. unfortunately this port is on the top of the tablet, behind a little cover (to keep the waterproof rating).
since it's on the top, and after having experience always fiddling with getting the XOOM to line up with a Micro USB when docking, i won't be trying to incorporate this port into the dock. instead i'll just have a cable behind the tablet that i can plug in whenever i want to use the projector.
eventually i plan to experiment with a Miracast dongle to see if that would work well and negate the need for the extra connection (Mircast is similar to the Chromecast wireless TV stick, but supposedly doesn't require an internet connection to work).
Old 12-18-2014
scottL's Avatar
scottL scottL is offline
Vehicle: 2001 jeep cherokee
That Aimee is a real keeper.
Old 12-19-2014
i tend to agree
What to use for Phone/Tablet based GPS (maps) theksmith GPS, Mapping & GeoCache 47 04-05-2017 01:17 PM
A Basic Tablet Setup for GPS & More theksmith GPS, Mapping & GeoCache 21 12-26-2014 04:52 PM
Head Center & Sin Fin Mines: Anyone ever been there? matt@expaz Trail Info & Other Destinations 1 08-15-2014 10:29 AM
Clinic: Saturday 6/28/2014: Tablet/Phone based GPS/Map Clinic: Phoenix, AZ theksmith Trip & Event Planning/Sign-up 27 07-07-2014 08:26 AM
tough/ruggedized Android phones & tablets theksmith GPS, Mapping & GeoCache 2 08-17-2012 09:57 PM
