Old 10-12-2016
RV Window Vents for Sleeping Inside Your Rig
I made a couple rear window vents for my JK Unlimited to get air circulating while sleeping in it, yet not let in the rain or bugs. The basic idea would work for any rig with relatively square window openings.
The inspiration comes from these similar vents made by the German company Nakatanenga 4x4 Equipment: https://www.nakatanenga.de/Zubehoer/...eep-Patriot-MK
Nakatanenga's appear to be a quality product, but I wanted something a little bigger (for more air flow). If you're interested in those, someone on Expo Portal found that one of their employees speaks english and will setup a paypal transaction for you. Last I heard they were running about $80 shipped to the US for a pair. Email Melanie at melanie@nakatanenga.de to order.
Here's the inside view of my DIY ones:
I went cheap and easy for the first version by using simple 1/4" thick black corrugated plastic. If they work out well but prove too flimsy, I'll probably re-make them using some 1/8" Lexan.
The actual vents are $2.50 aluminum attic vents from Home Depot (with the roofing stuff near the lumber section). They have 2 other heights available as well.
They have a mesh, but I added better screen with smaller holes to keep the mosquitos out. I used a putty knife to fold back the edges where the existing mesh was tucked to add in my screen.
Everything is simply stuck together using 3M exterior 2-sided tape. It's the same stuff used to hold moldings and trim on your car, so it's actually pretty durable.
Some Z-channel aluminum strip was used on the lower edge to create a drip-rail that overhangs the window glass. Besides weather-proofing the setup, this helps hold it in place against the glass.
To use them, I simply roll the rear windows down 3/4 way, slide these in and leave them resting down against the glass, then roll the windows up till these guys tuck into the top channel... takes all of 30 seconds!
I bought everything for this quick project from Home Depot and I think it was about $40 worth of stuff. However, a third of that was because I bought their best roll of screen (smallest holes to keep out the gnats). If anyone nearby needs some screen, I've got a giant roll now!
The first use will be this weekend on the Rug Road trip!
Old 10-13-2016
lofreqjeff's Avatar
lofreqjeff lofreqjeff is offline
(Jeff & Katie)
Vehicle: 89 4Runner
Reputation: lofreqjeff is an unknown quantity at this point
Default Re: Window Vents for Sleeping Inside Your Rig
I had a set of magnetic window screens on the 99 4Runner I used to have - I have every intention of getting another set for my 89 & 06 4Runners:
http://theskeeterbeater.com/choose-your-size/
Cecil - 1989 4Runner SR5: Rebuilt 3.0 V6 w/upgraded cams, bored .30 over, ported & polished, balanced crank, Doug Throley Headers & custom exhaust w/ high flow cat, Bosch 4 port fuel injectors; Factory R150f manual trans w/Marlin Crawler 1200 lb HD clutch, Marlin Crawler built t-case with 4.7 crawl gear; Custom fab'd SAS: 85 4Runner front axle, Trail Gear diff armor & truss, Longfield Chromoly axles & birfields w/ factory Toyota eLocker, FJ60 brakes; Detroit locker in rear; 5:29 gears; Old Man Emu leaf springs in front, 57" leaf springs in the rear; 315/75/16's (35's); Custom sliders and front & rear bumpers, Softopper, Tube doors, Bud Built Skids
Nameless 2017 4Runner SR5 Premium Daily Driver: 4.0 V6 auto; 2.5" Bilstein lift w/OME FJ rear springs; 33" Nitto Terra Grapplers
Old 10-15-2016
Bradywgn71's Avatar
Bradywgn71 Bradywgn71 is offline
(Chris)
Vehicle: 2002 Jeep Grand Cherokee Overland
Reputation: Bradywgn71 is on a distinguished road
Very interesting. We also use just the skeeter beater screens for now.
Old 10-15-2016
Ladybug Ladybug is offline
(Karen) (KG7UHP)
They are very nice Kris! Good Job!
smiles, ladybug
Old 10-16-2016
the vents worked great! there was plenty of air movement, they installed/removed quickly, and tucked away easily when not in use.
the only advantage to these over the skeeter beater idea would be if it rains during warm weather. we don't see rain too often on trips here in the SW. but if it does pour these should keep me from having to sleep in a sweltering stuffy rig. for the simplicity and cost, i think it's a worthwhile upgrade from magnetic or sock-style screens.
in fact, i liked them so much that i'm going to go ahead and make some out of a sturdier plastic. that was the only issue with them really - i felt like i had to be very careful to not crush the flimsy corrugated plastic when putting the windows up to hold them in place.
Old 10-16-2016
04DubyaJay 04DubyaJay is offline
Vehicle: 04 Jeep Grand Cherokee
Reputation: 04DubyaJay is an unknown quantity at this point
These are awesome!! Great idea!
Old 11-11-2016
i finally got around to re-making these out of some ABS sheet and pop-riveting the vents on so everything is more durable.
the plastic was ordered from here: http://www.tapplastics.com/product/p...abs_sheets/524
2 sheets of 1/8" black ABS cut to the right size were only $10, but shipping added another $8.
i found that using a jigsaw with a coarse-tooth wood blade worked well, especially if you barely pull the trigger and let the blade move very slowly while still pushing the saw forward at a normal pace (i.e. let it bite large chunks). otherwise, the ABS just melts itself back together.
Old 09-20-2018
mesach mesach is offline
(Marc)
Vehicle: 2015 JK Unlimited Rubicon
Reputation: mesach is an unknown quantity at this point
Where in HD did you get the Z channel? Was it with the loose metal? I did a cursory look for it but figured I could probably find it online, but I haven’t found it cheaply.
Old 09-20-2018
that z-channel was either back near the screen door material and weather stripping stuff or over in the tile edging area. it's very thin, the only place i've seen aluminum Z-channel online was pretty expensive with shipping.
i still keep these vents that i made in my camping stuff and they've come in handy the very few times that it rained...
but we usually have great weather in the Southwest and so more often i just use some $10 mesh nets. they are quicker to deploy and let more air in. these are the ones i bought... i'm not sure why there are some bad reviews, i've been using them for nearly 2 years without a problem. if you get something like that make sure you get tall version (around 22+ inches) instead of the car window height.
i know a couple people that use Skeeter Beater brand and are happy with them as well. those mount on the outside with magnets that are sewn into the mesh.
Sleeping in an LJ. jhart Your Rig! 20 07-14-2018 05:06 AM
WJ hood vents? tucsonWJ Jeep Specific 4 12-18-2014 07:46 PM
Sleeping-plattforms - how to sleep inside Surfy Camping & Overland Living 4 10-09-2014 05:07 AM
Elephant rams and rolls safar Jeep - video from inside! theksmith Photography & Videography 5 08-31-2013 01:23 PM
survival sleeping options urbex Survival & Emergency Preparedness 8 05-13-2013 07:47 PM
