Old 03-19-2017
Curly's Avatar
Curly Curly is online now
(Tim/Curly) (KF7INL)
Vehicle: 97 Jeep Wrangler
Reputation: Curly is on a distinguished road
Default Needle grease gun tip
On a recent jeep trip, the CV joint on my front driveshaft began making noise. It requires a needle tip on the grease gun to lube it and of course I didn't have mine with me. I went to Oreilly's and found this adapter.
It does require you to change the end fitting on the grease gun, but that takes about 1 minute. Boy,does this thing work well! 100% of the grease went into the fitting, and it also worked well on the regular zerk fittings on the ujoints.
Lincoln # 5803.
For reference, I had been using the style of adapter that plugs into the end of the grease gun. No matter how hard I tried, I always had some leakage where the adapter plugged into the grease gun.
I was impressed enough to make this post! I recommend this tool!
I Start What I Finish!
Old 03-19-2017
mbuckner's Avatar
mbuckner mbuckner is offline
(Mike) (KE7GRM)
Vehicle: 2001 TJ
Reputation: mbuckner is on a distinguished road
Default Re: Needle grease gun tip
I have to use a needle tip to grease my rear drive shaft. No room for regular zerts.
Old 03-19-2017
ob1jeeper ob1jeeper is offline
(Steve) (KG7EWF)
Vehicle: CJ7 - OlBlue
Reputation: ob1jeeper is on a distinguished road
Cool bit of info Tim. Same as I've been using... Thanks for the tip..
Gun Manuals johnpa Hunting & Shooting Sports 2 01-08-2013 07:38 AM
Tech Question: Grease type and ball joint removal klaykrusher Other/Multiple Brand Vehicles 5 05-19-2012 06:01 PM
$40 grease! theksmith All Other Activities, Gear & Resources 3 09-22-2011 06:34 AM
Needle Rock area of the Verde River now restricted (AZ) theksmith Trail Info & Other Destinations 2 08-04-2011 07:58 AM
