Old 02-06-2017
JeepUniq's Avatar
JeepUniq JeepUniq is offline
(Dan) (KJ7DAN)
Forum Vendor
Default Warn Powerplant Woes
As some might know, my pride and joy Warn Powerplant winch and compressor combo decided to transform itself into a coffee grinder. Not that was any good at it, but the noise it was making was very convincing.
I delayed and delayed pulling it off the bumper, but over the weekend I finally did. A few months back I searched Warn's website and found that it had a service center in Phoenix, so I loaded the damn pig in the Jeep and searched again to get the address but found that that center wasn't listed as a factory service center anymore. The closest one is in California (you know our westerly Peoples Republic neighbor) and shipping a >100 lbs is almost cost prohibitive. So I took matters into my own hands and took the damn thing apart.
BTW, I typically "buy American" to (a) support domestic businesses, and (b) because I found that Chinese crap is usually just that, compared to Made in USA. Well, Warn is Made in USA, a legend in the offloading community, so it must be top notch quality, right?
Well, upon disabling it, I can attest that the engineering and build itself is really solid, no plastic parts, nice fits, etc. However the assembly seems to have been done by a monkey: most screws were loose. Even more, none of them had even a trace a Loctite. Not blue, not red, nothing! It's like the Warn factory ran out of Loctite when assembling my unit. No nylocs, no split washers either. I mean this is an offroad winch?!? BTW, no real seals either, but surprisingly the grease was very clean despite this.
"Dan, enough with your didactic rant! What the hell was making the grinding noise?"
Well, the compressor has (had) an aluminum gasket attached to the top of the piston. Via a bolt. No loctite. No split washer. Lots of vibration. Yep, the damn screw came out and trashed the piston along it the valve (which it was trying to grind perfect for an espresso). This semi-seized the piston.
I'm not done yet with the full disassembly, so the carnage might've affected the belt that engages the compressor as well.
More to come.
Dan
Old 02-06-2017
JeepUniq's Avatar
(Dan) (KJ7DAN)
Forum Vendor
Default Re: Warn Powerplant Woes
Surprisingly, the belt is in perfect shape, so I only need to replace the piston and the piston head and valve. Should receive the parts this week.
Another observation: even tough I'm critical about the way the unit was carelessly assembled, I have to say that I really, really missed the compressor. Since the Warn was out of commission I've played to several other compressors: Puma PD1006, Superflow MV-90 (similar with the Smittybilt 2781) and found that none match the PowerPlant in speed and convenience.
Dan
Old 02-06-2017
did Warn send you the parts for free?
Old 02-06-2017
JeepUniq's Avatar
(Dan) (KJ7DAN)
Forum Vendor
Not exactly. I didn't bother to call them, but I will get them from Warn free via another source.
Dan
Old 02-06-2017
Number7's Avatar
Number7 Number7 is offline
(George)
Vehicle: Number 7
Dan, take some pics inquiring minds want to see. Your work on this rebuild will be much better then some one else's work.
G
George & Diane
4:88 Gears / Super 35 Rear
Dana 30 Front w/ Warn Hubs
TeraLow 4:1 T-Case
OX Lockers
Every Dog Has His Day!
Old 02-06-2017
JeepUniq's Avatar
(Dan) (KJ7DAN)
Forum Vendor
Sure G. The main diagram from Warn's website is:
The piston is #38.
Here're some pics of the piston, the top of piston head, the top of the compression chamber, the compression sleeve, and lastly what's left of the valve:
Note how the bolt hole got destroyed on the piston.
Some pictures of the rest of the bolts, nice and clean w/ no trace of loctite.
Dan
Old 02-07-2017
SlyDawg's Avatar
SlyDawg SlyDawg is offline
(Roy)
Vehicle: 2018 Chevy Colorado ZR2
Reputation: SlyDawg is an unknown quantity at this point
Dan,
Thanks for posting this up. I am following closely due to having this Warn also.
Roy
Old 02-07-2017
Dan, thanks for posting this info and the photos.
I hope you email or talk to Warn through your sources and find out if it's expected for nothing to have threadlocker, nylocks or lock-washers... I'm hoping yours represents a fluke or a bad batch. Otherwise it would certainly seem like a very poor design decision considering the vibrations a compressor must endure.
Old 02-07-2017
scottL's Avatar
scottL scottL is offline
Vehicle: 2001 jeep cherokee
That's some heavy scoring right there
Old 02-07-2017
johnpa johnpa is offline
(john)
Vehicle: 2004 Jeep TJ Rubicon
Reputation: johnpa is an unknown quantity at this point
can you hone the cylinder?
Need a Dimension fro a Warn M12000 or M15000 winch PMA4x4 General Talk 2 10-25-2012 03:55 PM
Tread Lightly! and Warn partner for a SEMA promotion!!! TreadLightly! Land Use & Environmental Concerns 7 12-12-2011 01:03 PM
WARN 9,500 lb Powerplan Dual Force Winch Number7 Classifieds: Parts & Equipment For Sale 0 11-09-2011 04:18 PM
Warn Winch and High Lift --- For Sale JWFAB Classifieds: Parts & Equipment For Sale 5 10-24-2011 06:57 PM
Warn 9.5 thermometric scottL All Other Activities, Gear & Resources 1 05-15-2010 12:14 PM
