Old 03-28-2018
scottL's Avatar
scottL scottL is offline
Vehicle: 2001 jeep cherokee
Default Re: ScottLs 2001 XJ
in this one case, chrome might get you home
hey you mentioned on my thread that you added a grade 8 shock bolt... that grade 5 bolt you had in there shearing off might have actually saved your spenesive shock since you aren't bump-stopped correctly - just a thought.
When loaded down w/ Gary, ms. Shelley, our camping gear, tools & spare parts, my jeep sits low out back. Having shock relocation brackets compounds the issue
I posted twice to this thread regarding Daystar's extended bumpstops & received no feedback. Might be time to measure up & try them out. Also probably will add-a-leaf from my spare stash if needed.
Old 03-28-2018
scottL's Avatar
Originally Posted by adriaanvn99 View Post
Looks sweet! Mine is a ticking time bomb. Occasionally on cold starts it will squeal for a few seconds, but the most notable problem is when it’s engaged I can feel the strain it places on the serpentine belt from inside the cab.
Where did you find the Mopar unit? I’ve seen remmaned units online, but I’m not too keen on that and would prefer a Mopar replacement
Sounds exactly like my issues prior to swapping.
If I hadn't lost video posting capabilities I could show before & after cold start video's.. Night and day difference!
Got mine at My Mopar Parts but it is a reman unit. All Mopar units for sale on the internet are. Their serial numbers begin with the letter "R" & in my experience you will not be able to find a brand new one online anywhere. If you do find one, let me know!
Click on "a/c compressor" in my post above & it will take you to the website where I purchased mine. You can verify fit if you know the last 8 digits of your VIN number.
Old 03-28-2018
adriaanvn99 adriaanvn99 is offline
(Adriaan) (ZS1AVN)
Vehicle: 1998 Jeep Cherokee XJ Limited
Reputation: adriaanvn99 is an unknown quantity at this point
I too have been trying to figure out exactly how the XJ's rear bumpstop actually works. I was running no bumpstops for a while but wasn't doing any heavy wheeling. About 1 month ago I ordered the Daystar rear poly extended stops. I have not got down to doing a proper test and taking measurements, but from eyeballing it I can't exactly see where it should contact. I think the idea is that when the axle articulates (not straight up down movement), the axle perch plate (where U bolts are fastened to) is supposed to tuck into the unibody and contact the bump stop. The XJ is at home at the moment so I can't take pictures, but I definitely will try do a write up. I think to effectively bumpstop one will have to install a modified perch plate, like this DBO one which has an extra bumpstop mount. I still think a set of Fox Air bumpstops is your best option, at a price of course!
Thanks! Will check it out. I will try post a video of the XJ idling, and then how it sounds with the AC engaged
Old 03-28-2018
scottL's Avatar
Thumbs up Re: ScottLs 2001 XJ
Perch plates? Interesting
Thanks for also posting the Fox link here Adriaan, might need to reference it later!
Old 03-28-2018
i made a you a graphic of your rig and where to measure.
measure just sitting on the ground at normal ride-height...
distance A is your potential up-travel if you hit a hard bump. and yes, the factory bump stop can compress nearly 100%, so you measure from the TOP of it.
distance B is how much up-travel your shock is allowing. note you're measuring straight vertically here, so you'll have to eyeball a little bit and thus it's just approximate. alternatively if you have an angle finder, you could measure the angle of the shock and the length of the exposed shaft and we can do maths to get an exact figure.
this is just basic straight up-travel. like when you nail a speedbump, whoop, or jump it - but that's your primary concern. when articulating things are a little different - but that's usually at low speeds with hardly any axle momentum, so it's not as big of a problem if your shocks are your limiter in that scenario.
don't buy poly extended bump-stops! they are only slightly better than using a bag of rocks - they hit hard and crumble apart fairly quickly.
the factory style foam bumps work progressively and they are what you want unless you can afford air or hydraulic racing bump-stops. you'll just need to add either steel spacers that lower those factory bumps, or wider perch plates like was just posted.
Old 03-29-2018
scottL's Avatar
Wow.. K! Thanks man, you
Old 07-19-2018
scottL's Avatar
Default Swampbox garage starter motor swap
I could hear a loud grinding noise on start up. Same sound as trying to start a vehicle when it's already running, only mine wasn't, and it was grinding on every start.
No visual damage or uneven wear on the flywheel
I noticed the wire housing which connects the solenoid to the starter motor was cracked and brittle
Wire was black
Inspection plate was covered in grease and dirt muck so I cleaned it with degreaser, a wire brush then painted it to match my brown dog motor mounts
All complete and back in good working order
Old 07-20-2018
shiny stuff Scott!
Old 12-16-2018
Old 12-17-2018
scottL's Avatar
Great shot and I can see Gary's ear too. Thanks for posting!
2001 tj mbuckner Your Rig! 12 05-27-2018 10:43 PM
My 2001 Dodge Durango azdurango Your Rig! 13 11-12-2013 04:14 PM
2001 Mitsubishi Montero. Ready for any trip. datrupr Classifieds: Vehicles For Sale 6 05-05-2011 08:54 PM
2001 XJ For Sale K7VZ Classifieds: Vehicles For Sale 13 04-18-2011 08:15 AM
2001 XJ Fender/Bumper Trimming theksmith Your Rig! 4 11-17-2009 07:51 AM
