Old 02-02-2014
BigTuna117's Avatar
BigTuna117 BigTuna117 is offline
(Michael)
Vehicle: "Pegasus" 1999 Jeep WJ 4.7L
Reputation: BigTuna117 is an unknown quantity at this point
Default Big Tuna's "Building the Dub!"
I picked up my 99 WJ almost 2 years ago (gosh, time flies!), after my 94 ZJ was rear-ended, and pretty much turned into an accordion. It had had only one previous owner, who had taken fantastic care of it, though it hadn't been driven in nearly 7 years! That being said, at 45k miles, it had never seen dirt. When I bought it, it got a full front-to-back fluids change, of course.
(day one)
The previous owner had already equipped it with a 2"BB and the Westin safari/light bar. From day one, I was unsure of what I would change on it. Of course, it is stuck as my daily driver, and it stayed that way for a while, until the off-road adventure bug really bit me.
On an overcast day in January of 2013, I rolled her off the pavement for the first time and set off on a trail I had been on when I was younger.
...and that is where this build began.
Once summer came, the radiator went, and would shoot hot antifreeze 5ish feet straight forward out of the front of the grill when you shut the vehicle off. That's where it started. After I replaced the radiator, I began to develop a list of things I wanted to do with the Jeep. I started pricing parts, and figuring out how I wanted to proceed. basic things got done pretty quick. Speakers got replaced, and then the stock Casette/CD player (which would etch a lovely pattern into my CDs and then eject them with an "ERR" code) was replaced with a Clarion CZ302, and in November I did a driveshaft conversion. If you have a Rezeppa-Rezeppa driveshaft, it is worth EVERY penny to convert to a U-joint/CV Driveshaft. The vehicle drives MUCH quieter, and there is much less vibration.
Shortly after this, I got the opportunity to run the Backway to Crown King.
This was my first opportunity to really test my rig. The experience was INCREDIBLE! I made some new friends, I learned a whole lot about off highway driving, and about what I needed to improve and change on the rig.
I then solidified a starting game plan of what I wanted to do with the Dub.
-Phase 1- (complete!)
Various tweaks and changes prepping the jeep for Phase 2
-Phase 2-
CB Install (complete!)
Lift (IRO 3" lift- Complete!)
New tires (Complete)
Roof rack (Complete!)
Rock rails
Underbody armor
various aesthetic and mechanical tweaks
-Phase "2.5" (or the parts Phase 2 forgot)-
Dual battery setup (Done!)
Infinity amp replacement (Done at last)
Rear tire solution
LED/HID conversion
Additional lighting
-Phase 3-
Transfer Case Swap
Long arm conversion
Who knows?
Old 02-02-2014
BigTuna117's Avatar
(Michael)
Default Re: Big Tuna's "Building the Dub!"
Now we're getting to current. I recently bought a Nexus 7, and added a dock for it on the dash.
(Action shot!)
It is connected to the Head Unit via Bluetooth, and connected to power through a 12 volt plug I installed in the dash.
A couple of weeks ago I got bored, and decided to end the chrome grille once and for all. I decided on Chrysler Charcoal Grey, the same color as the grille on the WK2 Trailhawk. The sub grille got a fresh coat of satin black, and the Grille got a couple layers of Charcoal Grey and Spray on clear-coat.
In the end, I'd say it was a success.
Now I just need to find a suitable color for the bumpers and rocker panels!
Old 02-02-2014
BigTuna117's Avatar
(Michael)
The next order of business was getting a CB radio put together.
Although tuning it was a headache, the setup is pretty straightforward. A Uniden PRO505XL, a Firestik MK-184R mini-kit for the Dodge Ram/Durango, A Firestik heavy duty spring, and a Firestik Firefly II 3 foot, super flexible tunable tip antenna.
As many do, I installed it above my passenger tail light, using the included Firestik mounting plate.
I trimmed my tail light, so that it isn't as crooked, however had to add washers and a lock nut to the mount for correct ground, so it needs to be trimmed again.
Old 02-02-2014
dzJeepChic's Avatar
(Diane) (KD7JPC)
Vehicle: '92 XJ
Cool, love build threads. Glad you were able to get caught up fast!
My '92 XJ Clifford
Old 02-04-2014
BigTuna117's Avatar
(Michael)
Thanks! I'm hoping to start making some serious progress in the weeks and months to come.
Old 02-06-2014
UnderlyVerbose's Avatar
UnderlyVerbose UnderlyVerbose is offline
(Jeff)
Vehicle: 2001 WJ Limited
Reputation: UnderlyVerbose is an unknown quantity at this point
It's really coming along nicely, Mike. Don't forget to budget for some skid plates/underbody protection too.
2001 WJ -
fivewheeldrive.me
Old 02-06-2014
BigTuna117's Avatar
(Michael)
Of course! The next major step I think, ought to be differential skids. Definitely a good idea.
Old 02-06-2014
BigTuna117's Avatar
(Michael)
Today I did a quick little mod to the dash that makes a BIG difference in sound. I expanded the dash speaker holes to make way for a Rockford Fosgate 3.5" full range coaxial Speaker. Since the Infinity amp cuts off somewhere in the mid-range (The stock setup is 2.75" full range) I figures I'd replace my second pair of blown tweeters with something a little beefier.
Overall, it was a pretty easy switchout. A little trimming with the dremel and cutting out some of the foam padding that sits between the firewall and the dash made it sit perfectly in the dash.
The nice thing is, after trimming the original mounts, the top panel fits back on, no problem.
I did expect better mid range presence, but wow. I didn't realize what I was missing out on.
Old 02-06-2014
Attachment 2064
Attachment 2065 Attachment 2066
Attachment 2067
good to know, i still want to do an entire speaker system upgrade one day myself.
Old 02-10-2014
BigTuna117's Avatar
(Michael)
As far as the other speakers go, I have a pair of Polk DB651 series 6.5" coaxial speakers in my rear doors. Love em. All of Polk's DB series is built to marine spec, so a little moisture doesn't intimidate them. They also do very well in the heat. As far as sound quality on em goes, I have yet to find a 6.5" coax that can beat them. Very clear crisp highs, and a good present mid range, and the lows on these are incredible for 6.5's These sound twice their size easily.
On the front channels I have now the Fosgate 3.5's and a pair of Pioneer 6x9 4 or 5 way speakers in the doors. I cant really vouch for the 6x9's sound because they are under powered by the infinity amp, plus the crossover effect that the infinity amp has. Eventually, I'll rip the infinity amp out and replace it with a Rockford Fosgate low profile, 4 channel, 300 watt amp. That will power the doors, and the front lines from the headunit will power the dash.
"Ultimate" Trail Welder & Jumper Cable Kit theksmith All Other Activities, Gear & Resources 21 03-15-2017 08:00 AM
"how an obsessed explorer found and lost the world's oldest subway" theksmith Trail Info & Other Destinations 3 07-27-2016 05:11 AM
New "Yukon Cold Locker" rugged/extreme coolers from Igloo theksmith Trail Cooking & Kitchen 22 04-29-2012 10:24 AM
GOTMTNS 2004 2WD Dodge Ram "Do It All" Rig Build GOTMTNS Your Rig! 28 04-13-2012 01:12 PM
