Old 4 Weeks Ago
adriaanvn99 adriaanvn99 is offline
(Adriaan) (ZS1AVN)
Vehicle: 1998 Jeep Cherokee XJ Limited
Reputation: adriaanvn99 is an unknown quantity at this point
Default Re: 1998 Jeep Cherokee XJ Build
I have been busy with a number of smaller projects on the XJ over the last few weeks. The biggest upgrade which was done is that I finally regeared to 4.56 Yukon gears and swapped in my Chrysler 8.25 rear. Andrew at LetzRoll Offroad did a great job of regearing my axles and installing a SYE in the NP242 with a new Adam's driveshaft. I finished the break in period and of course had to go try it out! Headed up to Broken Arrow trail over the weekend and I am very pleased with the performance. A quick comparison; on the 3.55's I was at 2850 rpm at 65 mph, with the 4.56 I am cruising at 2050 rpm at 65 mph. The biggest difference for me is the off road performance... 4 Low is totally in proportion now and I hardly have to give throttle over an obstacle which is great! Everything is smooth as butter! The factory LSD also made a major improvement traction wise off road. I will still eventually like to upgrade to ARB selectable lockers front and rear
I recently bought the Engel MR-040 fridge freezer. I have always been loyal to Engel as they make a great product and are well known in the industry. I needed a quick way to mount it, so I bought the Engel transit-lock slide along with it. Its quite a neat setup which allows you to slide the fridge into place and it keeps it nice and secure. Of course, I needed a platform to mount this too so I made a rear platform out of 1/2 inch Birchwood ply. It turned out great and serves a good job of keeping the fridge secure. I added some tie down points to secure my Wolfpack boxes to. I like that I still have easy access to my Hi-Lift and compressor on the driver side. I will eventually upgrade to a more complete system such as the ARB drawer system and drop down fridge slide, but this serves my needs for now!
Another major replacement was my timing chain, rear main seal, oil pump and oil pan gasket. This was quite a big job but I am relieved it was done. The XJ was leaking pretty badly from the RMS and oil pan gasket. My timing chain was so stretched that it had completely destroyed the rubber isolator in the timing chain cover. Luckily all went well and I have not run into any major issues yet!
Old 4 Weeks Ago
dzJeepChic's Avatar
(Diane) (KD7JPC)
Vehicle: '92 XJ
Wow, that's a lot of projects! The Jeep is looking good, and sounds like it runs a lot better too. Nice write up and pictures, thanks for sharing!
My '92 XJ Clifford
Old 4 Weeks Ago
scottL's Avatar
scottL scottL is offline
Vehicle: 2001 jeep cherokee
Looking good double A!
Really liking your hi lift cover too. Might have to pick one up for myself..
Old 6 Days Ago
(Adriaan) (ZS1AVN)
The XJ has had a cracked header for a while now, and finally got to replacing the whole exhaust system. Whilst at it, I decided to do the 99-01 horseshoe intake swap. I got the intake manifold from DeadJeeps on eBay and then got it media blasted and Cerakoted by AZ Pro Strip in Mesa. It turned out real nice. I added the DEI insulation kit over the fuel rail and and intake shield to prevent any heatsoak issues. Full exhaust replacement with a Magnaflow high flow cat and muffler. I decided to have everything welded in by a guy close by, called Wicked Wrench. The 4.0 is breathing a lot happier now!
Old 6 Days Ago
very nice!
ScottL should install that insulation kit too - is this the one you used: https://amzn.to/2GdT7q3
Old 6 Days Ago
(Adriaan) (ZS1AVN)
very nice!
Thanks Kris! Yes that’s exactly the kit I got, also through Amazon.
Here’s a better shot of the Cerakote. This is the “titanium”. They offer black and silver too
Bradywgn Build - Grand Cherokee Overland 2002 Bradywgn71 Your Rig! 298 06-05-2018 06:16 AM
My other non-Jeep vehicle build thread scottL Other/Multiple Brand Vehicles 75 04-19-2018 02:05 PM
My new Grand Cherokee build crgeorge Your Rig! 165 01-28-2014 05:59 AM
1998 Grand Cherokee 5.9 L Jeep available azjeep4me Jeep Specific 0 11-29-2012 06:53 PM
Jonny's 99 Jeep Grand Cherokee Laredo WJ build - Starting from Scratch jscraggles99WJ Your Rig! 9 09-13-2012 06:36 PM
