Old 12-27-2017
scottL's Avatar
scottL scottL is offline
Vehicle: 2001 jeep cherokee
Ford Re: 1998 Jeep Cherokee XJ Build
Originally Posted by adriaanvn99 View Post
Thanks everyone for the warm welcoming!
Jeep should be back and running this week!
On the hunt now for either a 29 Spline Chrysler 8.25 rear, or ideally a Dana 44 for the XJ to replace my Dana 35.
Ever thought about an 8.8? Same strength as a 44 and rear disc brakes too.
Old 12-29-2017
adriaanvn99 adriaanvn99 is offline
(Adriaan) (ZS1AVN)
Vehicle: 1998 Jeep Cherokee XJ Limited
Reputation: adriaanvn99 is an unknown quantity at this point
Default Re: 1998 Jeep Cherokee XJ Build
Semi mock up of completed axle. Resprayed, every seal and bearing replaced, outer axle tube seals (not pictured) and LockRight locker installed on the D30! Ready for install
Reinstalled the carpet after a thorough cleaning. While it was out I soundproofed/insulated most of the floor with a foil-type insulator and spray adhesive (no picture unfortunately)
Old 12-29-2017
(Adriaan) (ZS1AVN)
Solid option. Have limited access to a welder to weld the shock mounts and leaf spring perches unfortunately. But definitely an idea!
Old 01-02-2018
Pelagius's Avatar
Pelagius Pelagius is offline
(Jason)
Reputation: Pelagius is an unknown quantity at this point
https://www.cherokeeforum.com/f75/xj...r-axle-240908/
Just saw this.....
Old 01-03-2018
(Adriaan) (ZS1AVN)
EDIT:
Divided the last 2 numbers stamped on the ring gear 39 11, and divided them (39/11 = 3.5454). So rounded up its 3.55, which is stock gearing. Thanks!
Need some advice - opened up a D30 axle and saw this stamped on the ring gear (488). Am I correct in saying that this is 4.88 ratio? If it was standard as I was told it would be stamped with 3.55?
Old 01-08-2018
(Adriaan) (ZS1AVN)
Got the axle back under the Jeep. Had a slight issue of realigning my adjustable track bar from Rubicon Express, hence it still being on the axle stands. Ran out of time as I had to get back to school! Will be working on it this week. I am also still waiting for my CavFab upper adjustable control arms which were ordered almost 2 months ago!
Mock up of where I want to store my HiLift jack
Replaced my center console switch panel to Carling style switches, to run my LED's in the front bumper and electric engine fan
Old 01-08-2018
scottL's Avatar
Coming along nicely.
Are you planning to take out the rear seat after mounting your high lift there? I don't see how it could fit with seat down & no modification.
Old 01-08-2018
(Adriaan) (ZS1AVN)
Thanks!
No I plan on keeping my rear seat. Yes - you have to remove the center hump (either cut and weld new flat piece) or hammer a section down as far as I understand
Old 01-08-2018
scottL's Avatar
Thumbs up Re: 1998 Jeep Cherokee XJ Build
Thanks!
Looking forward to see how it works out. I've been tying mine to the back of my rear seat with bungee cords for years.
Old 01-08-2018
(Adriaan) (ZS1AVN)
Picked up a Chrysler 8.25 straight out of a 97 XJ (170 000 Miles, Factory limited slip!) for a good deal. Thanks to fellow XJ’er Dave from Cottonwood, AZ. Will be doing a bench rebuild on it (bearings, seals, repaint) and a caliper swap. Not in urgent need so will be done in a while!
Bradywgn Build - Grand Cherokee Overland 2002 Bradywgn71 Your Rig! 298 06-05-2018 06:16 AM
My other non-Jeep vehicle build thread scottL Other/Multiple Brand Vehicles 75 04-19-2018 02:05 PM
My new Grand Cherokee build crgeorge Your Rig! 165 01-28-2014 05:59 AM
1998 Grand Cherokee 5.9 L Jeep available azjeep4me Jeep Specific 0 11-29-2012 06:53 PM
Jonny's 99 Jeep Grand Cherokee Laredo WJ build - Starting from Scratch jscraggles99WJ Your Rig! 9 09-13-2012 06:36 PM
