Old 02-07-2011
jhart's Avatar
jhart jhart is offline
(KF7AJT)
Vehicle: 2004 Jeep LJ
Reputation: jhart is an unknown quantity at this point
Bed Sleeping in an LJ.
So I have been researching ways to sleep in a Jeep over the past couple months. Last time I took a quick overnight trip out around the Wickenburg area and didn't want to set up a tent, I slept on top of the Jeep (on the roof rack) under the stars while my son slept in the back seat. We were both pretty comfortable, but if it would have rained or gotten real windy, I would have to break out the tent, or sleep in the front seat. (Not good for my back or neck)
After googling all over the place the best solution looked like a roof top tent, or an XJ. Since I didn't want to spend more than a couple hundred dollars, both of those options were off the table. (For now anyway)
I ran across an article of someone that built a platform that would lay on the floor of his Jeep and go all the way to the front dash on the passengers side. (He had to remove the passengers seat and the back seat to make this work). because I have an LJ, I started to think, is my LJ long enough to make this happen without removing any of the seats? After some careful measuring, and remeasuring, I decided it was very doable. One advantage I have is that I'm 5'10". If you want to accomplish this and you are over 6' tall, it might be a little cramped.
I started by figuring out that I wanted this sleeping area to fold up when not in use. (Easily achievable with hinges.) I also have a Tuffy slide-out tool drawer in the back that is ~20" from front to back. The total length of this platform is 68", so I can accomplish what I need in four sections. Three 20" sections, and one 8" section. Conveniently, the ridge of the back seat when folded down is 20" in front of the tuffy toolbox (right where I would need support for the one of the hinged areas). Also, the center console would provide support for the front hinged area, but only in the center. The height of the senter console and the ridge of the back seat were the same, but the top of the toolbox was about 2" lower. I could recitfy this problem by putting 2" pieces under the rear section to raise it and make it all "mostly" level.
My next step was to figure out what material to use. I looked into using some particle board, or some cheap plywood, but finally decided to spend a little extra money and go with a nice 1/2" birch plywood. I thought it would look nicer once finished with stain, and a polyurethane coating. To support the front corners of the platform, I decided to use 1&1/2" dowels with table leg hanger bolts to make them easily removable.
Here are a few shots of the platform so far. I haven't finished sanding, staining, etc. I also have to get it bolted down in the back, so it doesn't move around or go flying anywhere should something bad happen. (Like a rollover)
With the hardtop on and closed up, there is a nice amount of room for me and my son to sleep. I can't wait to get it completely finished and go test it out on the trail.
Full length view.
Folded up for storage.
This is where the front legs screw in.
Underneath the front with the legs attached.
My son testing it out.
2004 LJ, I6, BFG AT 33s, 3" Teraflex lift, d30/d44, open/LSD.
- Joe KF7AJT -
Old 02-07-2011
Default Re: Sleeping in an LJ.
well done!
Old 02-07-2011
dzJeepChic's Avatar
(Diane) (KD7JPC)
Vehicle: '92 XJ
That came out really well! Great write-up, too, thanks for sharing it. I'm a big proponent of sleeping in the vehicle where it's warm & cozy. d
My '92 XJ Clifford
Old 02-07-2011
Ladybug Ladybug is offline
(Karen) (KG7UHP)
Cool! Good to see this, as I could probably think of maybe doing this too! It would be nice to sleep inside sometimes.
Thanks for sharing!
smiles, ladybug
Old 02-08-2011
jhart's Avatar
(KF7AJT)
Thanks. I'll post up more pics when it's all finished. I can't wait to test it out overnight sometime in the next few weeks.
- Joe KF7AJT -
Old 02-12-2011
jhart's Avatar
(KF7AJT)
All done! Here are the final pictures. Can't wait to try it out.
- Joe KF7AJT -
Old 02-12-2011
Number7's Avatar
Number7 Number7 is offline
(George)
Vehicle: Number 7
Nice, how long is the sleeping area? George
George & Diane
4:88 Gears / Super 35 Rear
Dana 30 Front w/ Warn Hubs
TeraLow 4:1 T-Case
OX Lockers
Every Dog Has His Day!
Old 02-12-2011
jhart's Avatar
(KF7AJT)
From tailgate to front seat it's about 72 inches.
- Joe KF7AJT -
Old 02-12-2011
klaykrusher's Avatar
klaykrusher klaykrusher is offline
Vehicle: '14 JKUR
Reputation: klaykrusher is on a distinguished road
Very cool, I like!!!
~ Dave
Old 02-12-2011
dzJeepChic's Avatar
(Diane) (KD7JPC)
Vehicle: '92 XJ
That's 6' even. Very cool you figured out how to do this. d
My '92 XJ Clifford
Sleeping mat recommendation reybie Camping & Overland Living 12 01-14-2016 07:46 AM
Day Run: 3/7/2015 - 3/8/2015 Sleeping Princess and Moss Wash, Kingman, AZ 4x4 Difficult ChrisD Trip & Event Planning/Sign-up 27 03-09-2015 08:26 AM
Sleeping-plattforms - how to sleep inside Surfy Camping & Overland Living 4 10-09-2014 05:07 AM
Sleeping Princess Trail, Kingman AZ May 2014 dzJeepChic Trip Reports & Photos 5 05-11-2014 06:56 PM
survival sleeping options urbex Survival & Emergency Preparedness 8 05-13-2013 07:47 PM
