Old 05-03-2016
Radio 2016 JK Wrangler Simple Tablet Mount (for GPS/maps)
A few days ago, I posted this teaser of a new tablet mount bracket in my build thread:
Let's jump ahead to the nearly finished product:
Rationale
Since I'm not sure if I'll ever do another complete "carputer" type setup in my new rig, I just needed a simple and possibly temporary way to mount a tablet for off-road mapping...
Aimee is letting me borrow her Verizon G-Pad 8.3" tablet since my larger Sony 10.1" may or may not be sold along with my WJ. Right now the G-Pad is just going to be for topo maps and not integrated with audio or anything else. The 2016 JK factory premium sound radio (430N) has decent on-road navigation and works with my phone over bluetooth for calls and streaming audio, so I'm leaving it alone (for now)!
With the 8.3" tablet, you only lose about a half inch of visibility on either side of the A-pillar in this location. A 7" tablet would be perfect here and not cause any view obstruction.
The Cradle
For the actual cradle, I reused the piece of the Satechi clamp-style mount that I customized previously for Aimee's Jeep Liberty KJ install (she's since sold that rig):
One of the RAM Mount Tab-Tite products could be used instead of this clamp, or a ProClip custom tablet cradle.
The Bracket
For the actual bracket, I used a 1" x 1/4" steel bar about 10" long, welded to a small steel plate.
This custom bracket attaches to the Jeep with a single bolt, through a 2 1/8" long stand-off, into the factory upper A-pillar bolt-hole location.
I had noticed that some of the grab handles which mount to this location call for tightening that bolt to 300 ft-lbs (EDIT: supposed to be in-lbs, doh!), so think it's a pretty solid place to mount something.
The Satechi cradle is attached to the bracket with 3M double-sided trim adhesive tape and a couple tiny screws.
Testing & Wrapping Up
It turns out there's zero flex, thanks to the 1/4" steel used for the main arm and large diameter stand-off. I was actually more worried that the plastic cradle might not hold up to extended off-road use. However, I tested by doing a few hours of high-speed travel over severe washboard roads this weekend and everything seemed extremely solid.
I'm currently running the power into a USB charger in the factory dash outlet, so I'll need to rig up somethign more hidden if I keep this for a while.
As you can see from some of the photos, I've already done a textured black paint. I did actually bend the arm just a bit in a vise after these photos were taken - to bring the tablet a little closer to the dash vent. So, I'm in the process of re-painting the bracket and also waiting for a nicer looking main bolt to use. Since the local Ace only had a regular shiny hex-head bolt, I ordered a M8 x 1.25 X 70mm allen button-head bolt in black oxide finish from Bolt-Depot online.
Conclusion
I'm not sure if this would be a good location for on-road use. It does help keep your eyes near the road when glancing quickly at the screen. but it could also be a little distracting always in the line-of-site. For my current off-road only use, I think it will be perfect.
Pros:
  • Easy to make/install
  • Requires no permanent modifications to the JK
  • Not in the path of an airbag
  • Doesn't block any factory controls or screens
  • Very minor reduction in road visibility
  • Inexpensive
Cons:
  • May be distracting for on-road use
  • Requires welding
  • Highly visible location that could attract theft if you leave the tablet in all the time
  • Tablet not as easy to use for right-handed people (versus a mount near the radio)
  • Passenger can see but not operate the tablet for the driver
FYI: When searching for the link to the original grab handles that inspired this location, I found another company that integrates a ball-mount onto theirs. It looks to be compatible with the RAM Mount system, so this might be a ready-made way to accomplish the same location (along with a RAM arm and cradle): http://www.carolinametalmasters.com/...iant=365288329
Old 05-03-2016
gearhead's Avatar
gearhead gearhead is offline
(Mike) (KF7OGY)
Vehicle: 1991 YJ
Reputation: gearhead is on a distinguished road
Default Re: 2016 JK Wrangler Simple Tablet Mount (for GPS/maps)
cool!
Old 05-03-2016
SlyDawg's Avatar
SlyDawg SlyDawg is offline
(Roy)
Vehicle: 2018 Chevy Colorado ZR2
Reputation: SlyDawg is an unknown quantity at this point
An amazing job again. Thanks Kris.
Old 05-03-2016
ChrisD's Avatar
ChrisD ChrisD is offline
(Chris)
Vehicle: 2008 Jeep Wrangler Unlimited Rubicon
Reputation: ChrisD is an unknown quantity at this point
Very nice. I am using the Carolina Metal Master grab bar handle to hold my iPad.
OffroadDance
2008 Jeep Wrangler Unlimited Rubicon with 4'' Coilover Lift, 40'' Toyo MT, UD60´s front and rear axle, Warn winch, Genright front bumper, TNT Customs rock sliders, Rockhard underbody protection, CB, 5.7 l VVT Hemi....
Old 05-03-2016
ob1jeeper ob1jeeper is offline
(Steve) (KG7EWF)
Vehicle: CJ7 - OlBlue
Reputation: ob1jeeper is on a distinguished road
Originally Posted by theksmith View Post
I had noticed that some of the grab handles which mount to this location call for tightening that bolt to 300 ft-lbs, so think it's a pretty solid place to mount something!
Kris,
I'm gonna bet that this number should read; 300 INCH-POUNDS, (or 25 FT-LB)
Old 05-03-2016
Originally Posted by ob1jeeper View Post
Kris,
as usual, there you go making sense again!
Old 05-03-2016
(Steve) (KG7EWF)
lol...
Old 05-17-2016
got my $6 black bolt (darn shipping costs)!
Old 06-12-2016
i noticed Carolina Metal Masters is now selling the ram ball mount as a stand-alone item: http://www.carolinametalmasters.com/...lar-ball-mount
makes it even cheaper to grab that and a RAM Mount arm plus one of their tablet holders and have a very solid, easy mounting solution!
Android Tablet as a Head Unit & GPS - New Install theksmith Communications & Other Electronics 27 11-13-2017 07:09 AM
What to use for Phone/Tablet based GPS (maps) theksmith GPS, Mapping & GeoCache 47 04-05-2017 12:17 PM
Dell Venue 8 Tablet on sale - GPS navigation Bradywgn71 GPS, Mapping & GeoCache 1 02-19-2016 06:29 PM
A Basic Tablet Setup for GPS & More theksmith GPS, Mapping & GeoCache 21 12-26-2014 03:52 PM
OSM Maps - Maps for Garmin GPS dzJeepChic GPS, Mapping & GeoCache 0 07-09-2012 08:05 PM
