Old 06-20-2016
Food Every JK Tailgate Table!
For your comparison shopping or inspiration pleasure... every folding table that specifically works with the JK tailgate, and some thoughts on building your own at the end. Please post up a link if you know of any that I missed, and feel free to share your own custom solutions in this thread too!
M-PAC / Springtail JK Rear Door Folding Tray/MOLLE Panel
$189.99 + shipping
(Regularly $224.99)
25" x 13" x ?? (folded depth)
325 sq-in surface area (calculated)
unknown weight
MOLLE compatible table
16 ga. steel table, 11 ga. steel back (powder coated black)
paracord supports
unknown hardware materials
40lb load rating (option to drill more mounting holes for higher rating)
appears to work with factory passenger side mounted subwoofer
mounting hardware included
no drilling required (uses plastic screw grommets)
requires removing or cutting the factory trim panel
Replacement parts available (latch pins)
Matches other MOLLE items sold by M-PAC
Also on eBay as seller springtailsolutions
eBay seller alanjk427 JK Tailgate MOLLE Panel
$125 with free shipping on eBay (black) -
$130 with free shipping on eBay (zombie green) -
22.625" x 10.75" x ?? (folded depth)
243 sq-in surface area (calculated)
unknown weight
12 ga. steel (powder coated black or lime green)
paracord supports
no load rating given
unknown if mounting hardware included
drilling is required
does not require removing or cutting the factory trim panel
Appears you can get a custom msg laser cut into table (not sure if extra charge)?
Matches other MOLLE items sold by alanjk427
Teraflex JK Multi-Purpose Tailgate Table
$189.04 with free shipping at Quadratec
(MSRP $209.99)
23.5" x 12" x 1.25" (folded depth)
162 sq-in surface area (calculated)
6.9 lbs (shipping weight)
appears to be MOLLE compatible (has slots & holes)
aluminum (powder coated black)
stainless coated wire rope supports
stainless hardware
75lb load rating
mounting hardware included (screws, nut-serts & install tool)
Includes bottle opener and trash bag hooks
Small plastic cutting board accessory available ($19.99)
Same as Vector version (companies are partnered for this product)
Vector Off-Road MP Table
Currently $199.99 + shipping
Same as Teraflex version (companies are partnered for this product)
Currently comes with free set of Hood UFOs (http://www.vectoroffroad.com/ufos-hood-p-40.html)
Vector used to also sell a longer version of this table for use without the factory subwoofer, but it appears to no longer be produced
Outback Adventures Trailgater
$299.00 + shipping (plastic board)
$329.99 with free shipping at Rebel Offroad (bamboo board)
main table: 25" x 13", cutting board side-out: 20" x 11"
1.8" (folded depth)
525 sq-in surface area (advertised)
20.3 lbs (plastic board), 19.5 lbs (bamboo board) (advertised)
solid surface with slide-out cutting board extension
14 ga. stainless steel table (raw), 0.120" aluminum back (painted gray)
wire rope supports (unknown materials)
stainless hardware
40lbs load rating (main table)
works with factory passenger side mounted subwoofer
Includes slide-out cutting board in white HDPE Sanalite (plastic) or natural bamboo
Table & cutting board surfaces are FDA approved for contact with food
Also sold as an Adventure Trailers product
EVO Manufacturing Trail Table
$179.99 with free shipping at Quadratec
25" x 14" x 1.5" (folded depth)
348 sq-in surface area (advertised)
30 lbs (shipping weight)
solid surface
1/8" steel (black power coated)
solid folding supports
unknown load rating (company shows image of adult standing on it, 150 lbs claimed on another forum)
Can be mounted to fold up or down
Rock-Slide Engineering Tailgate Table
$159.99 (raw) with free shipping at 4WheelParts
$179.99 (black) with free shipping at Quadratec
bottom shelf: 17.5" x 16", top shelf: 18.5" x 10.75"
1.6" (folded depth)
450+ sq-in surface area (advertised)
unknown weight
2 tier solid surface
12 ga. aluminum (raw or black powder coated)
solid side supports
no load rating given (38 lbs claimed on another forum)
does not require removing or cutting the factory trim panel (can fit below)
2 tier system provides a lot of workspace but not practical for typical propane camp stoves
Warrior Products Tailgate Table Storage System
$349.99 with free shipping at Quadratec
unknown size
unknown surface area
22 lbs (advertised)
half solid surface & half MOLLE compatible
aluminum panels (raw) with steel sides (power coated black)
no supports (thick enough to just rest against tailgate)
work swith factory passenger side mounted subwoofer
Acts as a storage container when folded, includes 2 small shelfs or items can be strapped to back
Lockable when folded
No supports needed means items can hang off sides (a wide stove/grill for example)
SunTop TailMesa
Italian company, could not find it for sale anywhere in US or with international shipping. Neat 2 tier design can leave top up so you could use a tall stove on bottom shelf still.
Offroad Trail Tools Tray Table
No longer produced. Very nice aesthetic though, lots of space without secondary shelves or slide-outs, no need to remove plastic trim - but doesn't work with subwoofer.
DIY
$25 - $200 in materials + your time + must have tools & work area
A quickly accessible vehicle mounted table is one of the single most useful accessories anyone can add. But is paying $200 or more incredibly insane, or absolutely appropriate?
It really all depends on your unique situation (time, skills, desire, etc.). Some things to consider:
- What level of quality is acceptable to you? If you're perfectly happy with a bungee corded, out-of-square, splintery edged chunk of wood that you found on the side of the road, then have at it and enjoy your free table. If you're the complete opposite and obsess over every little detail in a product, then you can still certainly make your own, but you're not going to save a ton of money trying to make something really awesome. Realistically, you can probably make something fairly nice that belongs in the middle of those 2 extremes for maybe $75.
- Is your contraption weatherproof? Especially important for top-off rigs, but even a little rain can quickly swell untreated wood and rust bare steel. Using stainless or aluminum for any metals including all hardware drives the cost up quickly. If you use wood as the primary material, you need to seal it well - multiple coats of paint/varnish/bedliner add time and expense. The same goes for powder-coating any steel panels (for long term durability and weatherproofing).
- Are you building it for trail repairs, food prep, or both? The whole MOLLE thing is neat, but you'll be torqued the first time your stove boils over and goo drips down into all your accessory pouches. Only one table in the list specifically mentions using materials that are FDA approved for contact with food. Sure, making a sandwich on a painted piece of wood isn't likely to kill you, but if you plan to work on parts one day and eat off it another day then you at least want a surface that cleans well and doesn't hold chemicals or germs.
- Shipping costs and unplanned hardware/tools/bits/blades/etc. can add up quickly. Most folks that make their own will already have plenty of tools and parts lying around, so this might not a huge concern. What wears on me at times is all the extra trips to the hardware store for unexpected items, or waiting for some final piece to come from an online order.
Old 06-24-2016
HeyOK HeyOK is offline
Vehicle: 2007 Jeep Rubicon Unlimited
Reputation: HeyOK is an unknown quantity at this point
Default Re: Every JK Tailgate Table!
Here is what I made.
I'm always looking for a flat surface.
I use this to hold tools and as a work bench. Probably wouldn't hold up too well if you were to sit on it but it is surprisingly strong.
Some paracord is being used for the supports. Originally I was going to use cable but the paracord is easy to work with and doesn't rattle around when the shelf is folded up.
Nutserts are used to hold the aluminum angle to the gate. The shelf is just a piece of pine shelf. The hinge is nothing more than a 1/4 - 20 bolt that threads into a threaded insert on each side.
To help keep the bolt from ripping out of the wood, another piece of angle was used. It distributes the force over a much larger area and keeps the wood from splitting.
These pictures are a couple of years old now. Eventually I replaced the wood shelf with a piece of Baltic birch plywood. The paracord is holding up fine as I have only had to adjust it one time.
Old 06-24-2016
nice and simple, i like it!
Old 07-24-2016
jgaz jgaz is offline
(Jim)
Vehicle: 2006 LJ
Here is another possibility to add to your list:
https://www.frontrunneroutfitters.co...own-table.html
Price point looks competitive especially considering it has the pull out extension.
Old 08-03-2016
i'll have to add that to the list now that it appears to be shipping - and for a great price. i'm really suprised how cheap it is, Front Runner stuff is usually very well made and priced accordingly!
this is probably the best buy out there if you don't mind drilling holes in your tailgate.
Old 08-03-2016
a writeup on my first attempt at making my own is here: https://offroadpassport.com/forum/showthread.php?t=4710
Pet Barrier & Tuffy Security Tailgate Enclosure JeepUniq Classifieds: Parts & Equipment For Sale 1 03-01-2015 05:08 PM
Other: 20th Annual Albuquerque Ham Radio Winter Tailgate 4x4Ham.com Events from 4x4Ham.com 0 11-26-2014 05:11 PM
TJ Tailgate Table squinko Other/Multiple Brand Vehicles 6 09-14-2014 06:42 PM
AZ: Gas Pipeline from Rock Springs Cafe' to Table Table (Mesa) rd. 4x4Ham.com Events from 4x4Ham.com 0 04-16-2014 06:00 PM
Day Run: Table Mesa Maddogjeeper Trip & Event Planning/Sign-up 17 01-31-2011 03:26 AM
