tsconver
My 03 WJ Build
New to the forum thought I would share my rig
03 GC 4.0L Laredo
Suspension
Bilstein 5100 (f) and 5125 ® shocks, KOR Dual SS Setup, Addco 1" Rear Sway Bar, 4.5" Clayton Springs with 2" pucks for a total of 6.5", KOR Sliders, JKS Quicker Disconnects, Iron D44 Rear Swap, Clayton Long Arms Front and Rear, Carolina DS front Double Cardan DS, JKS Tie Rod and Drag Link, JKS Adjustable Front Trackbar with Super Hard Bushings, rotated knuckles, tank tuck.
Tom Woods SYE and Custom Rear Driveshaft. 4.10 gears front and rear, ARB locker in Front and Rear.
Engine
63mm bored throttle body, K&N FIPK with AEM Filter
Summit Transmission Cooler and Remote Filter
Sunpro Transmission Temperature Gauge
Recovery
ARB Bumper, Mile Marker SE9500 Winch with Synthetic Rope
Mopar Factory Hitch Receiver
Custom skid plates
Highlift Jack
Homemade 15lb CO2 setup
Wheels and Brakes
Cragar 15x8 Soft 8s, BFG ATs 35 x 12.5 x 15
PFC Pads, Slotted and X-Drilled Summit Rotors all 4 corners W/ GoodRidge SS Brake Lines
Electrical
Optima Yellow Top to keep it all running
Pioneer AVIC-F900BT Double Din Navigation unit with Sirius Satellite, Alpine 250w Amp, Alpine Type S (doors), Infinity 3.5" Tweeters and Basslink Subwoofer
500watt Power Inverter hardwired in
3rd Generation Projector Headlights with 55watt 4300k HIDs and Digital Ballasts on dedicated relays.
Cobra Model 75 CB radio and Firestick Antenna
Hardwired Cobra Radar/Laser Detector
Viper Security System to keep the bad guys away.
Misc.
Yakima Mega Warrior Roof Rack with extension, spare tire, and tool mounts.
Driving lights on roof rack
Smittybuilt Gear Seats both front seats
Early picture with 2" BB and Crush Rims installed, also Westin Bull Bar and Nerf Bars
Post 3" IRO lift install
Installation of double din head unit.
http://www.jeepsunlimited.com/forums/showthread.php?p=4347027#post4347027
Initial ARB Bumper Install
Current ARB Setup, control box is under the bumper, plug on front and dash controls as well
IRO Front Upper CAs
Rusty's Lower Control Arms
Both replaced with IRO Long Arms
homemade bumpstop extensions
Rear Lowers installed correctly
started adding some pics, more to come
Yakima Mega Warrior Roof Rack installed
JKS Sliders and Rock Lights, soon to upgraded to LEDs
Front Steering Components, JKS Tie Rod, Drag Link and Trackbar (what a PIA to keep tight) and KOR dual SS. Also a shot of the loop I tie my Swaybar up with.
Rear Cargo and Interior
First aid kit and fire extinguisher
Sub, amps and power converter
Flashlight
Dash and upgraded switches
Under hood: FIPK with AEM filter, Yellow Top, Accessory Fuses and Relays, HID Ballast
D44a install
Well I have the D44a installed that I got a junk yard. I think I am going to do the hack n tap on the TC output shaft and get a DS made. Also got a classic tube 5th brake line made so all the flex is now SS Braid.
Well just added some rock lights for night crawling, wife got these for me for my birthday, I cut them apart and lengthened them so that there is one behind the axle two along the rock rails and one in front of the front axle. Will post some pics later after it gets dark.
http://www.ledtrailerlights.com/other/cargo-lights.htm
Front under bumper
behind front wheel
in front of rear tire
behind rear wheel
Night shots
ARB Compressors and Wiring
Added a high out put ARB compressor to run my locker that is going in this week as well as provide on board air in an emergency.
Well Here are a couple of pics of the ARB front locker installed.
Also picked up a Lincoln welder flux core wire model and decided to weld up my trackbar mounts here are a few pics, not bad since I have not welded in 20 years, :laugh:
Also one of it on the RTI Ramp
I think my shocks are limiting my travel now.
