tsconver
My 03 WJ Build
time for some updates
Well I have decided to build me own bumper.
Here are the beginnings of it. It is the basic frame waiting on the tire swing pieces to come then I am going to box it all in with 12 ga steel.
will add more as I progress, waiting on the kit now.
Tire Carrier Swingout Component Builders Kit
added swing arm pivot
base swing arm
closure
a little style
side closed in
top plate
angled back under
started boxing top in
top of side box
tire mount add
gusseted
still more work to do but got a lot done, need to do a lot of welding and a few more pieces to fill in gaps around door and fenders.
I think the bumper is done, will take it off, add a few welds from the back side, weld up all the seams and the grind and paint.
I also think I am going to order a CO2 tank bracket and mount it on the drivers side for carrying my CO2 tank.
Add a cross bar that fits really tight and nice between the top of the receiver and the bottom of the horizontal bars I welded to the side of the hitch receiver mounting plats. I think it will nicely add to the strength, also may add a couple of verticals between it and the main cross piece once it is off for finishing.
Hopefully will be able to finish it up over holiday closure at work, then it is clayton time.
got some paint on it, after I welded up the seams and did some sanding. Not perfect but will until this spring when the weather is nicer and I can sand and paint it a little better.
updated pic with bumper finished
Here are some pics, more to come,
truss going across top
Iron Diff with tubes welded on it
Going to go with a steel cover and weld a support from it to the back of the truss to prevent rotation
couple more
going to have a plate across the back of the truss and then the cover will attach to the truss as well.
Well it is all installed and it turned out great. ARB hooked up and working. ABS and Speedo working, Parking brake working. Need to rebuild my front DS then I should be good to go.
Pics for ya.
What is left of the D44a
Not sure if I ever posted any pics after I replaced the switches for my lights, got away from the safety switches and went to rockers. So here are a few of my switches, including my ARB switches.
moved my radar detector power from the vent cover to the vehicle info center too
Also a couple with my wheeling tires on as I am going to take it out in a a couple of weeks on a club run.
also an excuse to play with my new Nikon D-90
rolled 100k
claytonized
