Inexpensive Hand-Held HAM Radio
Universal Radio has the files linked for download. You can try installing the Win7 driver. I would think it could be made to work with Win8.
http://www.universal-radio.com/catalog/ht/5934prgm.html
If none of those work, try the Prolific drivers at this site.
http://prolificusa.com/pl-2303hx-drivers/
Received my UV-5R Plus radio today. One problem though: Windows 8 does not support the USB to Serial Driver. So I will have to program by hand.
Bummer, I dont know anything about Windows 8..I use Linux. :o
I could help you manually program it also, unfortunately I am still in Boston, Most likely for another couple months or so.
Its really not soooo bad just a lot of buttons.
Here is a video that had helpd me out. (first part of the vid. is a review the second part gets into programming.)
Great video! Thanks!!
I have a Baofeng (dual band) and it is a nice radio for the money ($50). I also have a couple of the Wouxun (dual band) ($115). The Wouxuns are better quality than the Baofeng . Either is a lot less money than any of the Japanese dual banders.
I picked up a UV5R at Overland Expo. Pretty nice radio for sub $100 with extra antenna and programming cable.
The seller programmed the radio with his favorite repeaters and such, nice for the average HAM, but I want to clone closer to my in vehicle Yaesu 7800R.
I made contact on 87 near the 4 peaks turnoff on my way home through the MT Ord repeater. Had a brief conversation until I turned off at Usery and the mountains blocked the 5w signal...
I downloaded the program Chirp and the Windows driver so I can program via the PC (windows 8).
All is working smoothly.
Will be a nice addition to the truck for comms when out walking...;)
Thanks. I would like your help. I went to the Chirp site but it also states only Windows 2000/XP/Vista/7 are supported. Windows 8 has a problem with the serial port or something.
thanks
I am using it on Windows 8 and it works. I used the same webpage, C-Fish is refering to, to find the right driver.
Can anyone recommend an external antenna for my Baofeng. I have a tj and would like to increase my reception.
thanks johnpa
check the first post of this thraed for model numbers of a comet and diamond that fit. i ordered the comet based on a review i read that rated it slightly better than the diamond in actual transmission signal strength. there is also a cheaper brand called Nagoya that is all over ebay. it might not be as good as the comet or diamond, but i'm sure it's a ton better than the factory antenna still. i'll report back once i get my radio and the comet.
I purchased the Comet SMA-24J antenna at HRO. http://www.hamradio.com/detail.cfm?pid=H0-011735
I haven't done any hard benchmark testing on it, but I like the flexible antennas way more than the stiffer stock antenna that comes with it.
Dual-band 2M/70cm HT Antenna
Super flexible and lightweight-
Made from the same material as
unbreakable eyeglass frames
Gain & Wave length:
2M 2.15dBi 1/4 wave
70cm 3.5dBi 5/8 wave
Max Power: 20 watts
Length: 15.75"
Connector: "reverse" SMA for Wouxun
