Guardrail 1 Posted March 26, 2014 I piled the kids into Big Jake and headed down to Tucson a few weeks ago for an extended weekend. On Sunday, we met up with Matt@exp-az and some of his local friends and headed out to Chiva Falls via Three Feathers. What an AWESOME trip! We met at the Circle K at Tanque Verde and Rebecca at the east end of town at 8:00 A.M. where we fueled up and aired down. We had thought about the possibility of swimming but the 54* temp and the 30 M.P.H. wind had us thinking otherwise. After a meet and greet, a quick shake of hands, a cup of coffee and a couple of donuts, we were off. We headed east on Tanque Verde past Paul McCartney's house and into Reddington Pass. Shortly after the road turned to dirt, we hit our first stop, the Tanque Verde Overlook... From left to right: Matt's JK Unlumited Rubicon, Big Jake, Scott's 4-Runner, Ever's TJ, Larry's XJ, and Patrick's TJ. At this point, any hopes of going for a swim had gone out the window as the temperature had dropped to a blustery 53*. Making things worse, the wind speed up here had increased to what I estimated to be somewhere between 40-50 M.P.H. I had dressed in a T-shirt and shorts, not expecting the cold, windy weather. I was now starting to regret that decision. The good news was that we could now see Mica Mountain and there was clearly snow on top, which meant there was a very good chance Chiva Falls was going to be running. After having a good look around, we opened doors to get back in the truck, allowing the wind to blow straight through, taking my nearly empty box of donuts right out the driver door. Naturally, the donuts fell to the effects of gravity as the box was swept away by the wind. I managed to catch up with the donut box before it flew off the cliff and straight into downtown Tucson. Scrambling back to my truck, I managed to pick up my two remaining donuts before they had reached the 10 second limit. Getting back under way, I joked over the radio that I had some 10 second rule donuts for sale and how much better they were than day old donuts. I don't know who ate them, but they weren't in my truck when I got home. A little ways up the road, we turned right onto the Three Feathers trail, engaged low range and began to creep our way towards Chiva. It wasn't long before I realized that Matt's assessment of Three Feathers was accurate. Often, somebody will describe a trail to you and, when you get there, it is much easier than the description had suggested. I usually chock that up to the person's inexperience off road. This was certainly not the case with Three Feathers. I have a habit of not following the person in front of me too closely so I can see where I'm going over my hood and under their tires, and so I don't make the person in front of me uncomfortable in case something goes wrong. When we reached the first hill, I hadn't paid too much attention to where Matt went. I waited at the top as he descended, and as he got to the bottom, he and his sister got out with their cameras to shoot the action. Not having watched Matt closely, and not able to see the beginning of the hill over my bulbous hood, I immediately dropped my left front wheel into a large hole. It wasn't a big issue inside the truck, but it made for some great video (which I'll post to You Tube as soon as I have it edited together the way I want) As I got to the bottom of the hill, I again dropped my left front wheel off the side of a rock, just dinging my front diff on the top of it. The first bump of the day. Ever and Larry coming down the first hill. After everybody made it down the first hill, with only one scraped knee, (Big Jake's) we headed around the corner to the main challenge on Three feathers. Matt, leading the group, stopped at the top and explained that this was the main obstacle. He wasn't kidding! To the left was the route known as "The Chute". Nope I thought, Won't be trying that one. Down the middle was a rocky, rough set of stair steps and ledges that I wasn't about to try either. On the near right was an off camber, solid rock slab that leaned well to the left with a vertical ridge down the left side that started out about a foot and a half high and got higher as it went along. Towards the bottom, the ridge jutted out into the way of the trail. Getting past it would either require going to the right, leaning your truck more left in the process, or putting a tire on top of it. We all chose the latter... Matt coming down the slide... ...followed by Yours Truly in Big Jake. Scott's 3rd gen. 4-Runner may look stock, but it's not to be under estimated. He has all the clearance he needs, but lacks the suspension travel of the Jeeps or Big Jake. This is more than made up for with the lunchbox locker he has in the rear and the Tru-Trac in the front. After we all successfully negotiated the slide, we headed up the trail. We had only gotten a 1/4 mile when Matt called back on the radio..."The left side is more difficult, the right side is easier..." Who am I to turn down a challenge? I had passed the fork in the road to get to the left, and Scott was right behind me, so he went up first. He made it without slipping a tire. What he had made it up was a 1 1/2 foot ledge, followed by a deep rut that ran diagonally across the road with a dirt mound on the left just before it and a rock hill coming out of the far side. I got out and analyzed the line I would take. I decided I would skirt the dirt mound on the left and angle my right tires up the rock hill with my left ones down in the rut. It almost worked. After three tries, I called out that I was done. My left rear tire was a few inches in the air, and I wasn't willing to bump it hard enough to get me past the short distance required to put it back on terra firma. Matt said "Hang on, let me put a rock under your tire, you only need a little..." I backed up, giving them room to put a rock down in the rut. One try and my rear tire made it across, but didn't get a good enough bite on the far side to propel me up. "Let me put a couple of more rocks in there..." somebody said. "No" I said, "I'm gonna bump it." I backed up a foot or two, put it in drive and opened the throttle. A hop, skip and a jump later and I was up. As the only one in the group without a locker, I was the only one who had an issue here. Ever heading up... ...never slipped a tire. Big Jake heading up the ledge. CRESTED! So far, so good... ...left rear tire just off the ground... Grab a rock there, Ever... "I think I can..." MADE IT! After that, the trail got considerably easier for a while. The terrain flattened out some as we finished our transition to the main Chiva Falls trail. After a short stop to check out the lone Juniper tree in the area, we headed down into the main wash...which was running a decent amount. A good sign. To the left was the trail to the pools, but we'd do that on the way out. Our goal for now was Chiva Falls, straight ahead. The trail quickly got nasty once again. Not terribly technical, it was more just plain rough than anything. At one point, Matt called back to inform the rest of the group that he had banged his belly pan on a big rock and to look out. The second scrape of the day. At least I wasn't alone anymore. Placing my wheel on top of the rock, I managed to keep any metal bits off of it and be on my merry way. Soon, we came to a narrow slot. Most in our group could squeeze through easily, but I was in Big Jake, a full size Ram, and was much wider than the Jeeps and the Toy. It wasn't difficult at all, but Matt, knowing how wary I was of cutting a sidewall with 6,000 lbs of Ram on radials, wanted me to have a look at it before I attempted it. The left side had rocks that could potentially cut my sidewalls, but the right was a smooth rock slab. Placing my truck just to the right of the sidewall splitters on the left, I walked through without issue. Shortly after the slot, we arrived at the Chiva parking area, not much of a parking area really, just more of a wide area in a nasty road with some neat rocks to perch your truck on top of if you could get it up there. I chose to stay at the top of the hill where I had ample space to turn around and walk the 30 yds to the rest of the group. We had a quick bite to eat, packed up and made the short hike to the falls... What a place! AWESOME! Patrick's Jeep has been underrepresented to this point, so here's some obligatory shots... After thoroughly checking out the area, we headed back to our vehicles. We went back down to the main wash and went to check out the pools. This main wash is relatively smooth and very easy with many places where crossing the water channel is required... I swear there's a Jeep in there somewhere. After checking out the pools, we headed back out to the main trail and headed for home. And naturally, about 100 yards before the trail ended, I scraped my front bumper on a rock...figures. What a day! That place was AWESOME! The 4-wheeling was fantastic, as was the scenery. The destination was totally cool, and the company was excellent! I want to thank Matt for the fantastic adventure. It was the first time I got to meet him in person and I hope to do more adventures with him and his friends soon. Share this post Link to post Share on other sites
dzJeepChic 2,940 Posted March 26, 2014 Great trip report and pictures! Thank you for posting them, looks like a fun day. BTW, the first 6 pictures don't show up on my screen. Share this post Link to post Share on other sites
SSRx7 0 Posted March 26, 2014 I've been out wheeling with Matt, Ever, Patrick and Larry numerous times, and everytime has been a great run. I did Chimney Rock with Patrick back in January, but Chiva Falls is on my to do list. Great Trip report! Glad to see that Big Jake made it through. Don't often see full size rigs stretching it out. Looks good! Share this post Link to post Share on other sites
Guardrail 1 Posted March 27, 2014 Thanks SSRX7! I'd suggest doing Chiva at your earliest possible convenience. That's one of the best 4x4 trips I've done in a long time. Regarding Big Jake, I'm actively campaigning for the right to put an "Honorary Jeep" sticker on 'im. DZ, I reposted the photos. Can you let me know if they are coming through now? Share this post Link to post Share on other sites
dzJeepChic 2,940 Posted March 27, 2014 Thanks SSRX7! I'd suggest doing Chiva at your earliest possible convenience. That's one of the best 4x4 trips I've done in a long time. Regarding Big Jake, I'm actively campaigning for the right to put an "Honorary Jeep" sticker on 'im. DZ, I reposted the photos. Can you let me know if they are coming through now? Yes, they are showing up now. As far as Big Jake's Honorary Jeep decal; if he gets one, Marge gets one too! Share this post Link to post Share on other sites
Guardrail 1 Posted March 27, 2014 Yes, they are showing up now. As far as Big Jake's Honorary Jeep decal; if he gets one, Marge gets one too! I can hang with that! Share this post Link to post Share on other sites
matt@expaz 2 Posted March 27, 2014 After we all successfully negotiated the slide, we headed up the trail. We had only gotten a 1/4 mile when Matt called back on the radio..."The left side is more difficult, the right side is easier..." Who am I to turn down a challenge? Brian, you forgot to leave out the part of the story that I was the only one who took the right side and completely chickened out on the left . It was a great trip. I really enjoyed seeing Big Jake flex his muscles on Three Feathers! Thanks for coming down and enjoying our southern Arizona hospitality! Share this post Link to post Share on other sites
Guardrail 1 Posted March 28, 2014 Brian, you forgot to leave out the part of the story that I was the only one who took the right side and completely chickened out on the left . It was a great trip. I really enjoyed seeing Big Jake flex his muscles on Three Feathers! Thanks for coming down and enjoying our southern Arizona hospitality! PBSPSBST. I know, being in the lead, you were just trying to keep the moron who decided to take a full size Ram down Three Feathers out of trouble. I also enjoyed seeing Big Jake, as well as the 4 Jeeps and the lone Toy, flex their muscles. It had been a while. And Thank You for the Southern Az hospitality, I had a GREAT trip. Share this post Link to post Share on other sites
