dbell
Heater core help
Hey guys. This new jeep I bought happend to need the ol heater core replacement. BUMMER! So I have found most of the info I need and yes I will be replacing the mid-case blend assembly and the air recirc assembly. I also am planning on the evap core. Now I am as "newbie" as it gets, so are these the right parts? And what are your thoughts on dorman products?
http://www.amazon.com/gp/aw/d/B001D53JNQ/ref=pd_aw_fbt_auto_img_2?refRID=0YQB0K162QNM6SW0SZFB
http://www.amazon.com/gp/aw/d/B002CS7BD2/ref=pd_aw_fbt_auto_img_2?refRID=0YRGN9Q7TC55FR6ESAZ7
http://www.amazon.com/gp/aw/d/B000IYLFUM/ref=pd_aw_sbs_3?pi=SS115&simLd=1#
Thanks for the help and I hope the links work.
99 wj by the way with auto climate control.
Anybody? I want to get them on order...
Cannot offer much assistance regarding the how to of the job, and am unable to access the links from my phone, but I can say that in general, Dorman products are upper-tier aftermarket components...
Ok thanks ob1jeeper. Really appreciate it.
sorry i don't have time right now to lookup part numbers, but amazon should tell you if they fit your vehicle (if you input the year/make/model).
it does look like the right stuff, though some people use the Heater Treater approach instead of the factory stuff which might fail again: http://www.heatertreater.net/
also, be sure to examine the collars on the actuators (where the actuator motor attaches to the pivot point. some of mine were cracked when i did it - so even though my doors/pivots were ok, the actuators were spinning around on them. i actually was being cheap that day and put hose clamps around them instead of buying new ones.
I agree with Ksmiths comments regarding the door axle pivots.
IF the Dorman products are like the OEM plastic ones, I would instead recommend the Heater-Treater units, as they are metal, and will not fail as easily as the plastic ones… That is what id did with the failed HVAC doors in my truck…
HTH…;)
I bought my kit from Blen Dor Store. I'm about to tackle this job myself. They're made of aluminum and look to be a quality product. I'll give an update after I get them installed.
Thanks K and Brady. Parts have been ordered. Can't wait to knock this job out and be done with it, then get that lift put on.
I haven't had any trouble with the blend door on my cherokee yet. But I am sure I will down the road. Thanks for the information on HeaterTreater. I had not heard of this company before, but after watching the video on their website. It sounds like a much better fix, than repairing with oem parts. I tried looking up info on Blen Dor Store, but I didn't have a good internet connection. So I couldn't access that info. Thanks again for the info.
