johnpa
tj rear wiper switch
does anyone have or know where i can get a wiper switch for the back window on a tj. i have looked up new and i can always go with just a toggle switch but i wanted to ask.
thanks
john
480-694-5175
Are you replacing a defective switch or adding a new switch/circuit to the rear wiper?
I just bought a hard top and my jeep did not come with the switches on he dash. I was going to wire the oem switch to the wiper because i do not think i have the wiring harness which connects the wiper.
see Rich at Moore Chrysler Jeep. He got me new OEM switches for a great price .
Forgot to add that you can pm him over at the AVJC site.
only problem with oem switch (#56007249) is that if you don't have the harness then you might have to figure out how to plug into it and which pins do what (it has 6!): http://www.ebay.com/itm/Windshield-Wiper-Switch-Rear-AIRTEX-1S1809-fits-97-01-Jeep-Cherokee-/311314179132?pt=Motors_Car_Truck_Parts_Accessories&hash=item487bc5643c&vxp=mtr
something like this would look fairly factory but be easier to wire if you don't have the harness: http://www.otrattw.net/CONTURA-V-WINDSHIELD-WIPERS-UPPER-LED-INDEPENDENT-V1D1GNNB-PZCWW-500.html
EDIT - if you want everything to work on your fancy new shell, you might want this: http://www.quadratec.com/products/11190_50.htm
thanks Kris.
If you need to figure out connections on the back of the switch, I have the factory 2006 TJ manual complete with the wiring diagrams. I don't know if the wiring has changed but if the switch is the same for an 06 It would be a good place to start.
You may have, or be able to get, this info yourself. If so please disregard.
Jim
thanks jim. if i get lost with the wiring, you are my first call.
Just curious how many people use the rear wiper. I accidently turned mine on once.
