over time i've accumulated quite a few coil spacers trying to account for more and heavier accessories, one of which i noticed was crumbling away. to try and clean all those up and also gain a little up-travel, i replaced the old saggy 4.5" Teraflex coils and over 1.5" of pucks with some shiny new 6" Teraflex rear coils.
AP1GczOB20k9shy0vT3uy3UMhx5lubenKBLt6fNn
in the front i removed the doubled-up OEM isolators i was using to level things out and added 1" spacers with a single isolator instead. i also kept my OME 10mm spacers on the right side (front & rear) to help mitigate the "JK lean".
all this ended up netting me about 1.25" of lift in the rear but just a bit more rake than i'd like. i'm going to wait a month to see how those new coils settle before i worry about leveling it better.
AP1GczMPPniUw1373b_BhdmXiNypebaI1yBmqg79
as long as i was crawling around on the garage floor, i decided to pain my Hooker Blackheart muffler with some high temp black this weekend to try and make the big dent it's had for a couple years less noticeable! then touched up my rock sliders, axles, and various other areas with Krylon Satin Black for the millionth time.
AP1GczPSqVnSLQ9HBPJY3QNBhvniDwdUEXtHcCvR
  • Like 8
spent half of Saturday changing out all 4 joints on my upper rear control arms. a mild PITA even with the small joint Teraflex tool.
i've been trying to find a "clunk" when the rear hits a speed bump or on washboards. unfortunately these sloppy bushings weren't the culprit after all. they still needed to be changed, but now i have to continue looking for the source of the noise!
AP1GczMdrCKcaKl3_WrU-Ej3MohJM2wkhORuhVvj
AP1GczP_weLMzMSiZ06R0CHGi23y8l6bKnWIIb23
then Sunday did a little pre-running/exploring...
AP1GczPPxKddi8gmJdiXKkA4ndRMdj2jqfkxpy5f
  • Like 5
never a fun sight...
AP1GczPO6Ox4ysfNyYPVKg2a-kfZipNZ3Irk62sR
i think i broke a pinion tooth... really nasty "clunk clunk clunk" noise coming out of the rear axle. :(
  • Sad 4
  • Wow 2
Is your Jeep coming home or headed to a shop?
headed out to get fixed.
update from the shop: gears are broken, new ones ordered.
  • Sad 1
  • Wow 1
Just went through the same thing, broke a tooth on the spider. Wanted to step up to 4.88's anyway.
What ratio are you running?   I ask, because as you go lower (higher numeric) in ratio, the gears become more susceptible to breaking, mostly due to pinion sizing, causing reduced tooth contact patch/area....
Edited by ob1jeeper
5.13
