theksmith 5,897 Posted May 23, 2025 B is home so i got a shot of all the license plates at once! couple other recent shots of Gadget: 5 Share this post Link to post Share on other sites
theksmith 5,897 Posted May 25, 2025 (edited) i replaced the original steering shaft this morning with a Borgeson 000311 HD aftermarket one. the lower u-joint on the factory shaft had nearly seized up completely, making the steering intermittently stiff as you turned the wheel. i wasn't 100% sure the shaft was the issue, till i got the old one out and found that i couldn't turn that bottom u-joint by hand at all on one axis. the replacement Borgeson is all welded steel, instead of a mix of aluminum and steel parts pressed together. some people have reported issues with the OEM shaft becoming loose at the coupling areas. i never experienced that problem, but i do like the design of the Borgeson better. hopefully it also lasts nearly 185k miles. Edited May 26, 2025 by theksmith 8 Share this post Link to post Share on other sites
theksmith 5,897 Posted July 30, 2025 (edited) went for a night run on a couple trails in the Table Mesa area with some random folks from Facebook... i ended up turning around before the 1st waterfall on Anaconda after watching the leader hump a giant boulder and do Austin Powers style repositioning for 45 minutes. i guess this particular rock used to be where you could just squeeze left of it, but it's gotten moved around making the climb out more difficult: i waited for the other folks to finish Anaconda and then we ran Lower Terminator. Edited July 31, 2025 by theksmith 5 Share this post Link to post Share on other sites
theksmith 5,897 Posted August 8, 2025 (edited) for those of you that have been following along with my P0369 (intermittent camshaft position signal) issue... it's still not really resolved. i've been running 0w-40 oil instead of 5w-30 and that keeps the problem at bay if i change my oil before 5k miles. the last time i had the engine apart, i installed a new exhaust cam phaser to see if that was the problem. then on a recent trip up the I-17, i was getting very close to 5k on this oil change and sure enough the code and limp-mode symptom resurfaced yet again. attempts at fix thus far: cleaned camshaft reluctor wheel, new camshaft position sensor, new wiring and connector from sensor to PCM, new PCM, swapped phaser actuators between exhaust/intake positions, new exhaust phaser. at this point, i've replaced everything that could be related to the camshaft position signal except the actual camshaft (which includes its pressed on reluctor wheel), and the oil control valve inside the phaser. hopefully i don't have to take anything apart anytime too soon, but if i do have the valve cover off for any reason i'll replace the oil control valve next... mainly just out of curiosity at this point, to see what the final real fix is! Edited August 8, 2025 by theksmith 1 1 Share this post Link to post Share on other sites
theksmith 5,897 Posted August 8, 2025 random throwback sunrise photo! 2 Share this post Link to post Share on other sites
Stacey and Scott 1,407 Posted August 10, 2025 On 8/7/2025 at 6:28 PM, theksmith said: for those of you that have been following along with my P0369 (intermittent camshaft position signal) issue... it's still not really resolved. i've been running 0w-40 oil instead of 5w-30 and that keeps the problem at bay if i change my oil before 5k miles. the last time i had the engine apart, i installed a new exhaust cam phaser to see if that was the problem. then on a recent trip up the I-17, i was getting very close to 5k on this oil change and sure enough the code and limp-mode symptom resurfaced yet again. attempts at fix thus far: cleaned camshaft reluctor wheel, new camshaft position sensor, new wiring and connector from sensor to PCM, new PCM, swapped phaser actuators between exhaust/intake positions, new exhaust phaser. at this point, i've replaced everything that could be related to the camshaft position signal except the actual camshaft (which includes its pressed on reluctor wheel), and the oil control valve inside the phaser. hopefully i don't have to take anything apart anytime too soon, but if i do have the valve cover off for any reason i'll replace the oil control valve next... mainly just out of curiosity at this point, to see what the final real fix is! Just a thought, have you tried flashing the ECM? It seems odd the issue is so milage specific. Share this post Link to post Share on other sites
theksmith 5,897 Posted August 10, 2025 (edited) 7 hours ago, Stacey and Scott said: Just a thought, have you tried flashing the ECM? It seems odd the issue is so milage specific. once the sensor and wiring were replaced without solving it, the whole PCM was replaced. i took the opportunity to put in an unlocked one from HP Tuners with a custom performance tune as well. the mileage thing is really just as soon as the oil looses it's heavier viscosity. if i run a thinner oil, or it's really hot out, then the problem comes back sooner. everything currently points at a problem with the oil-control-valve which controls the phaser that adjust the camshaft's actual timing/position. i forgot to mention in my list of fixes/changes/checks that i also checked the oil galley bolts in the head which can sometimes come loose (causing lower oil pressure to reach the head and all this VVT witchcraft). they were still tight. oil pressure also reads fine in general. Edited August 10, 2025 by theksmith Share this post Link to post Share on other sites
theksmith 5,897 Posted August 16, 2025 i relocated the PSC power steering cooler, at least temporarily, from in front of the radiator to below it. this is of course less than optimal for the efficacy of the PS cooler as it no longer has any forced air moving over it. however, i'm currently more concerned with improving the performance of the engine cooling system. this is where PSC has you to put the PS cooler; however, i think that was blocking a large amount of airflow through the rest of the cooling system at highway speeds: its new home: 2 Share this post Link to post Share on other sites
theksmith 5,897 Posted August 18, 2025 lead an easier night run this weekend on Black Canyon City OHV Trail... little bit of the Milky Way peeping past the Phoenix light polution: a cool shot of us all climbing some of the hills (stolen from @SonoranWanderer off FB): 5 1 Share this post Link to post Share on other sites
theksmith 5,897 Posted October 9, 2025 (edited) a little different type of repair for Gadget... so apparently i made this brace on my rear bumper too close to the body. a couple of times i've come down really hard on the tail and the body pinch seam slammed into that brace. the age of the body mounts probably isn't helping any either. so this has happened on both sides at different times and now the seams between the rear corners and the rear side panel has cracked. i assume it's some sort of panel bond material. minor crack on passenger side, bigger one on driver side: i decided to fill the cracks with Sikaflex 221 which is a paintable poly sealer/adhesive - not really sure how it will hold up long term, but we'll see! filled the entire line, finger smoothed it, then removed the tape. let it cure a few days and then re-taped the area and painted. i still need to remove the bumper, cut those supports and re-weld them a bit lower to prevent continued corner-abuse. a project for when the weather finishes cooling off. Edited October 10, 2025 by theksmith 4 Share this post Link to post Share on other sites
