4 hours ago, theksmith said:
AP1GczOjuLvMcJF4yIi2y2Vs27iUwEGEss9Noeyv
Gadget Noir.
Edited by shellback91
AP1GczNzq2Wyb8-HzV3CchkdePV25PxQzpDPgfl4 AP1GczMTv9o4sYZQvBPyXwKLuw2qNE4FdbRAcZ2l
so even after fixing all the worn/loose parts in the steering and front/rear suspension, Gadget was still handling terrible. with everything else tight, i was better able to determine the main problem though. her tail end was wagging like a dog going down the freeway, sometimes it would hit a bump and the back end would want to send me into another lane. it was to the point that driving on the freeway was dangerous.
i think when i raised her with 6" rear coils - that was just too much. her tail was acting like a very heavy bobble-head. i figured to fix it i could get stiffer and/or shorter springs, stiffer shocks, a stiffer rear swaybar, or find a way to eliminate a ton of weight. i decided to start with a swaybar change. i didn't want to loose any flex though, so i ordered a ORO rear Swayloc system (selectable dual rate sway bar). i've been running one up front for a while now and been happy with it. the on-road settings for both front and rear Swaylocs are stiffer than the OEM front/rear bars, the rear significantly so.
installing the rear Swayloc opened a huge can-of-worms though...
the Swayloc bar snakes between the frame and the body, in a little nook between the jack holding area and the subwoofer bulge in the cargo area floor. it seems my body mounts had sagged as well as the middle of my cargo area floor was dish-panning (sagging in the middle) - to the point that the bar wouldn't even fit at first. after I made it fit with a BFH, it still obviously rubbed the body.
AP1GczMG_zYZ1IqJ7cZ6RvFlovOL8WAokI9wwonr
i replaced all my body mount bushings with new OEM ones, which gained me nearly 1/4" additional frame-to-body clearance, even after the new ones settled in.
AP1GczNs7aGo1w4Q23Rb1u9lUQmSpvHfDtIQxY3J
the Swaloc bar still rattled against the body when offroading, so i made a 3/8" body lift by stacking some thick square washer plates from Amazon. i tacked each stack of 3 plates together with the welder so they wouldn't shift around (mainly while installing). they were galvanized, so i sanded that coating off around the weld area and used a fan to make sure i wasn't breathing any toxic fumes while welding.
AP1GczPBwwffZIv9L8BVacf8D2Q8yDxiEZI5MD-k
once i had those installed, the bar portion of the Swayloc was no longer rattling or thunking. i still needed to set the links to the right length to try and prevent tire rub. i found that my rear axle was pretty far off-center, even with the raised axle-side trackbar bracket. so the tires were rubbing the Swayloc when flexing, mainly on the driver side. i ordered a Synergy adjustable rear trackbar and got the axle centered.
AP1GczNwC8oiFjvVz_VJFHCMzifI-hp7a6_N5yCH
even after centering the axle, regardless of what length i set the links to, my tires would still rub on the Swayloc arms when flexed out (now on both sides!). ORO says that you need a max of 3.5" rear wheel backspacing, but i don't see how that could possibly provide enough space to prevent contact when articulating.
i ended up having to order rear wheel spacers. 1.25" was the thinnest i could go without trimming the existing wheel studs. i'm not thrilled about running spacers, but it did fix the rubbing (and just barely).
here's a shot of the Swayloc installed, showing the switching mechanism on the driver's side.
AP1GczML6K4S5AiN8Rg5Dba7SUyVKQS1t0_NiYv9
this whole time i've had my rear bumper off because the Swayloc brackets share 2 mounting holes on each side with it. i still have to modify the bumper by cutting some metal off its mounting ears and welding them wider so they can sit on top of the Swayloc brackets.
AP1GczMOBEO2_R60og0b36Wb11mV4DgNubwJ38qL
all this has been worth it - the Swayloc helped my on-road handling a TON. it's the most substantial change i've made in a while - i can drive on the freeway again! as a side effect, she takes quick turns almost as good as a non-lifted Jeep.
the overall handling is now acceptable, but it still feels like a 6" lifted Jeep and wants to bounce around and wander a bit sometimes at high speed. if i was just doing local trails, it would be fine - but on long interstate drives, i think it will still be somewhat tiresome.
so hopefully as a final handling related mod, i've ordered a set of AEV "high capacity" 4.5" rear springs that have a slightly stiffer spring rate for portly rigs. if they give the full advertised height even with my heavy girl, then i'll probably still need 1/2" spacers to sit level with the front. but yes, overall i'm lowering her by an inch or so! i'm willing to sacrifice that clearance if it improves the high-speed handling.
oh and i think the Swayloc when unlocked actually improved my rear flex a little! i.e. the off-road rate bar seems a little less stiff than the factory Rubicon bar was.
AP1GczNEWEl1Dmns9ynsmFFR1adFDMNSIrx5BSQj
AP1GczNBkfWxkQVHen7vkZV-Mrl0eKl6rgCKi0uW
  • Like 4
took care of modding the bumper to fit over the Swayloc brackets...
cut this much off each side of the bumper's mounting tabs:
AP1GczM-QBT6Rwv9iYFMIcr0PCLt4x7WLqaBwD7-
then drew up a replacement patch and had a couple cut out of 3/16 steel by Send Cut Send.
AP1GczNFmhf-hDRtwWt5GWn28tBsv4c1QB5Wwkdx
AP1GczPr3LWeb8gt_j-gAGN6UCnlvHl_SYxv4pF5
AP1GczPYO4zXzN8jnElRjJkd2Hmj6-aQ72wAj8xC
Rocker Panel Pass got a new first obstacle sometime in the past few years. what used to be the first obstacle is now at the middle of the trail, it starts earlier with a hell of a couple rock outcroppings. 35's minimum and at least one locker required now, IMO.
tagged my hard top in a couple places...
AP1GczPrbIA1FwVdoTCdUwhBbVCSfDGsjfkQnyc9
came really close to taking out a rear side window!
AP1GczMT6YRIsXC2GTogqc-31AqMj0s-qXyMnCAz
also gouged up a fender flare pretty bad.
AP1GczMWz2tzf7HfmjsHXa3RipK2Sp0zDR_Jqp4R
the part after what used to be the first climb is worn down and pretty straightforward now.
AP1GczM2w73p02Zdc7AB9X8GXcMZ5oUNmPdJcKoV
  • Sad 1
  • Wow 1
AP1GczM_xHjIQiR2PRkHO0w_yVCOWUZ0P4SP7KoX
AP1GczMcVBzxwSYs_n-IJEnSjXwPveeX14nULJ8c
Great photos!!!!
I'm interested in how you feel the difference here. My (JLUR) perspective with AEV 3" springs vs my original 3.5" Rock Krawler X-Factor springs is that I gained a lot of stability and weight bearing capacity, but at the cost of flex. The don't compress as much and don't stretch anywhere near as much. But I expect that's the trade off to be heavy. I also am running AEV HD on all for corners and just gave up the 1/2 inch.
I don't carry (I think) anywhere near as much as you and I'm overloaded (GVRW and GAWR-R, maybe part of why I tore the OEM rear spring buckets). Despite being overloaded, I have a slight rake without my trailer (recovery gear loaded) and run level with my trailer attached (340 lb TW plus 180 lb weight shift from front to rear axle).
Edited by SonoranWanderer
