there were only 4 of us, but we had a great time running Elvis and Box Canyon out in FJ this weekend.
AP1GczN-hXIl-Ae9CxlBhnYzkM0YekTH3QTauBal
i managed the up-n-over obstacle (next to the squeeze section), but i caught my spare tire coming down and bent/tore the Teraflex tire carrier and possibly tweaked the tailgate a bit!
AP1GczOuIUUkiZaILO96kPclhvMtoMJ4Lvk36xHR
thanks to @4x4tographer for these photos of Gadget:
AP1GczPXzeJ99-t3weWKiU-q7SHQhss-2fbThooc
AP1GczNlj5gKSIAVmwu3EzpgnklZqBF6pPbfZVSU
also on this trip - my parking brake cable snapped! i have a new one on order already though, along with a replacement Teraflex tire carrier base and OEM tailgate guide.
AP1GczM8xwM2X90Y7Hq1mGv-f_uW4rgDQCuMTxeU
  • Wow 1
when i installed the PSC's upgrading steering box, i didn't opt to purchase their upgraded PS pump because i had recently installed a brand new OEM one. over the past few days i finally got around to putting a PSC pump in. of course it turned into a whole project...
the first issue was the OEM frame bracket for the motor mount interfered with the new PSC pump bracket. i ended up having to trim off this little ear from the OEM metal:
AP1GczM2VoXh3iQgQYCNrdXxZ1ZX0cU7gRX-h1v1
my K&N snorkel's tubing snakes down through the engine area to the airbox and there was a joint between 2 tubes that would hit the larger pulley on the new PS pump. here's a shot with one piece of the tube removed:
AP1GczMkRtZvLdTGRV-BXuysJrdn_fpGt_Q7JH4t
i used a heat gun to reform that elbow you saw in the last photo to be more oval, and then also drilled new bolt holes in the airbox to allow me to rotate the elbow away from the pulley.
AP1GczNLzsdztw8ImUp8Rx6dQy9G0VN31FgYc9kh
AP1GczPIiSO5pwbpKlE-krD17GM-Brw_u1g43pQ_
AP1GczPQupoywM-s1eLnNuD2Yiu7ks1FkglIT35U
AP1GczPU02P1iU6EEclcbnscV_9HVpkgWluE9pjO
then i chopped off a couple inches of the other tube (not shown) where it angled towards that elbow, and replace the straight coupler that had joined the 2 tubes with a new 4-ply reinforced 45* coupler.
AP1GczMGcdB7toDOH_HLzaRoghTVOHvUXim7plol
AP1GczO9HC1VzrXc7tUaO8Q__-hjQkEIhLJG3Yyt
i now have a comfortable amount of clearance between the coupler and the pulley.
my only concern is if the new coupler could collapse from intake suction over the approximately 2.5" that it's unsupported internally. this joint is before the air filter and i don't *think* a naturally aspirated little V6 like this would create enough vacuum pulling from free-air to collapse a 4" reinforced coupler? i guess i'll find out!
  • Wow 1
one more minor issue with the PSC pump install - the 90.5" serpentine belt they specify was too loose and squealing. i had to go down a 1/2" in length to a Duralast 900K6. i found this info on someone's post on a random forum, which was fortunate because PSC doesn't answer the phone or return emails or voicemail - i'm not impressed with them or their products.
AP1GczPWBpNkJSLlZDzxPCx0BYv_E5NLAuhKI6wO
unrelated, here's shot of Gadget from the recent Backroad to Crown King run (from @4x4tographer)
AP1GczM1eUC3CowPXR3uTfYA0SMQ1hMPa_dnjo_Z
went up to Summit 4x4 in Prescott Tuesday afternoon for their even with the MetalCloak CTI trailer.
Gadget scored an 830 this time. over the years as her suspension has grown up she previously hit 600 and then 770 (thanks @Bradywgn71 for the photo).
AP1GczPxGBuCGpfR72w80Z5DcQlNnc4gwNUBqeGR
i was able to see that my rear driveshaft is hitting my water tank skid again. i had it fully clearing at one time, but then recently centered the axle properly with an adjustable rear trackbar and added some flex with the new rear SwayLoc - so it's hitting again. i'll have to see if i can shift the tank a little and clearance its skid more.
Summit also had their RTI ramp out, which Gadget scored an 870 on.
AP1GczNExaCkyE1RMxK2XShyI190rwKqHg0x2qlg
AP1GczONDvI2zGdyNmvN9jaWmhjQ_0z9Bu2lJVcR
those scores are both pretty good for a standard short-arm 4-link suspension.
AP1GczPo16EX6n71MB7nLn6__1ZjefLjuVU5i3mx
AP1GczMhu7TaBMJ0Anfk7fP4LdGnAHMg79e8zN2E
i think i have my water tank clearance issue all fixed up (the rear pinion yoke was hitting my custom tank skid).
significantly enlarged all 8 mounting holes in the whole contraption so i could attach at an angle - with the back end of it twisted away from the pinion.
AP1GczOk80ah2Wp1BnCVDmW24wwEBU-PnSRMRjqg
i still had to chop out a larger section of the square tubing that makes up the frame for the skid. then i re-welded the back side of the tube to the lower plate.
AP1GczNLylXCwtal6NTFO6aLklLqG9obPk0o4aXI
at full articulation, it just barely clears now - but it does clear!
AP1GczNxDxY0UbZUJbfKsWNzNzG6lXtFFqO9ymKF
i've yet to re-install everything - the above was just a quick test fit of the skid/cradle without the actual tank in there. i'm waiting on additional heat shield from Amazon to better insulate the entire tank from the heat of being right next to the exhaust.
i just need to get it all back together before the Rug Road trip.
of course i had to grab a couple poser photos while flex testing the clearance!
AP1GczNWqa7NMvzQNc2EEoBLS_E3Y5EwvL4-xvf2
i really like this shot. i think Gadget is almost as flexy as a JK can be with factory-length control arms. one day i may change to a long-arm 3 link front setup. for now though i'm very happy with her overall trail performance.
AP1GczNYvpLKNuIGgYudMLnXcoirlHk-ymF992Ih
ran a trail with some Facebook strangers last night, didn't die. Gadget did good, lots of steep rocky dry waterfall climbs.
AP1GczNjZYyVZ1ULFUAyujIggQkR7vHQ2U-uFDA5
we had a few winch sessions
AP1GczPHQcG-kXVz4TJU8O4dMudwzoJ9eCaxGWms
AP1GczNulj_jOLZ22Hc1KpS4enk5OOF2pIl4_ub8
couple future wheelers
AP1GczNlMSK75ZWC6-oY7XvtEJ1GPjmv6VCZwMsB
a Gladiator working hard to make up for that extra length
AP1GczNbMRtT62JNMgdAW0LmoXYEEkLDg3e4Addq
the "big" double waterfalls area, i didn't try this - maybe next time!
AP1GczM55rI2ag_o5rpCDrW6ROFJSnGv518L2zGt
this is Kevin and he's a very good boy
AP1GczOLCM13MdyIWDbQnSvTqhwQPWJTSAPqg84T
  • Like 4
Posted (edited)
FWIW:    Judging from the level of rust in the crack zones, it's obvious it has been cracked for some extended period, and the cracks did not occur on this single event.   ;)
good catch!
