for the past couple weeks i've been on a comprehensive interior noise assassination campaign!
i finally found the source of a CLICK that was happening very intermittently. when i made my interior hi-lift mounts, i used some screw retainers, aka "push nuts" to hold the screws to my brackets so i could install them easily as one module. however, one of those clips was getting caught in the channel on the Front Runner shelf. this whole setup was silent for a couple runs, but then started occasionally making a really loud click/squeak noise that had been driving me completely insane!
flG0hcPR-o930sQCFW3fG55XShPgKjMB-M8uI-uRpecOd1NyDT7hAuliEraEHyaw-_4wtgyRucAFL3gkz_sp3fMfHsAQvBs2qUNwPDw-tbntpUUg0geGoAnvFD4S1RBuK1bm5C7MYhMLWn94N5zk2nf8s-J1rjdj8ESc41rF7phDvXC4VlOIukvwxLP8km3UMbXHh1igJyJ7EVcEFvJV1R5T_NWS5ahva7aH5ebl6_sAcvf48kqlBiwNPs-ZGx6jUhkGQCNa4NIvOjKuQbBtxRYUVXh68oVHla2mDOho86crHJUFnENte2Lk6sKDnJw_CejyTL43-XKOZoj-q8CMuD70kBkJiTf6Gw2gE-Gd8XKaG5aOUBJ6cHGMxFJ5gUbtbtlN2Vi5bDMa15sanv089Bp4fGd-5NdvdST08AKA4Bd2DJ0Ff-9QSN2mOC8sJTlmYr1uPCFtxjCLomNmURHJenfTmMqHMVK8oTr2veYkMoLmIqePdAr1YIpbRDz2_MFyeFODgtrNH5ByF_i8HVfCEW_vVF-F5qtY_cNNZsnML-nK_4qBXEn-Up7D_-aHKBNA8_9CzlYmmk9e_o9bn6cNivlCF5U7xFCgYsxJMDYiHtktOzyEHpE_vSQUtl5AHK50HIjhKDZOay2LZ41c60ktU5FNPLsO-8OG6Uo=s800
once i solved that problem, i began driving around with the stereo off listening for every other little noise i could find! :eek:
the handle retaining pin on the hi-lift would sometimes rattle - fixed it with a piece of hose:
FVPjbvBWoxFxkDXY_B6-z0sZEcrRCzQm2Lix7jS8e8lLIiebrLDaht_iOyypDi6ef0hlNECwekSS-8CyqqLjpux93b45zdBul2o-UGTFuNhIVyjrJlGoU3T1qrFbsZtk2viQFeFUVIEGA5fP7YAkvey-QmhSpIKUo3coM8DmsaBUYhlMQmsJJqboFMgm5xKcU_I2HlIgZCz8PvTRE7rdr3dmOr63CDkQvenOZBUOOhQEm3FumIhdK6ErLn1YFLr50UJ2h06j3y56De7nEwmOC03dgMPJKaXBV3s1My4izCayRrt3DDyMxPfZHVkcH7Ag7p6C4qwbySLlrJFuoEf4EdhA9ElKKBMGCxMXL9uEHLWCJpfJz1slBL9ugjlIqJ_CRuGESp7gv6aaRI4IuK9rj-GVNK6c9IFPRV7jyF4bPJNvqRPuCcZQNx0eNJQK5i4hcbFKpq1d7bu0Rp02MYU_Io7DqNvIc9WkGtoO7g-FT8gViRF_8r8Kx1ZoyO-6sX-1L5Skhba6c20qZ6SpYNwGqVRy7GhaTvGhJCECiFRntSLjCcr2Ojh1q0UY3AzLFXTl_y4ph8amy7UR6qldAFC8-3eqyVd9mmDbSBl546iSB8Ya9mPMO8MeFufHxwxkvcK61BPAN7RFjf7zNFY8BHgwWrx57NiTdI4FwGE=s800
my sleep platform stows as a divider between the fridge and cargo area. i used thin magnetic catches where it folds onto itself, but had only used one catch centered on each fold which allowed the sections to slap together on washboard roads. i updated it to have two catches per fold to fix the issue:
r4vN3Mjksuq-zZOsTy-iitkedAeaJDoWFk8y2_1mdgXi4w1THh9Ms6G3o8hNGQorHdETUW07KGPUOctcx39jN5uSxtxR2umnqV4_WuhCeM-1nf0qfyQeX6kkTp0dalhZbmQZje2eBYGZOaJxRKUOs-RgzwiPFvTf4aJTem4JiozhqhSgy5nBo1xwFGDNerdJlF-WJJAAtU2QZGc2dTTZrKPd7YBpi43XcD0Sp3jbpRJxI-KmkuARUXEAZcU2hcjJA-dse0JL8vcJidHf2ESpTXm7LBQR5cgALJGhFaAogi3feufLJ7DxoM12xejX-73fZ-18o3r4ruaCvDECdcMAwjbJpAzSjCdgKcdh9X3dyCd-EwmmNCVEU7Oatipvm5vHPUCn8TMhggRGv8CS0nujChRpolsjb93hBunR4Ld05v31DV6uyyuHV3Gjeaen02bfydl6Iu3Zlx_2_cV9x-T5t1Hn2Lm43XY6l5yZNet6uV8PqRzvKB0DwMuUJ8qrLSLMdIpZKuOGO4c1oneIPkpwDrb4bMfAQvu-ffD--8Kk5Dlk8QEtMj--1d44VAnOGhagTEXvR3rjVyi4l1luaMiP42ZImV2h4ifv5JhYYik93oUusFebkJDObyfZZqPoNRKRIh0-OQN6TaA4y8_ERxze6ldnuVAN3INnhNM=s800
the folding cup holders on my tailgate table were also flapping around when hauling butt down a washboarded road. i drilled a hole in each one and added rubber bumpers from my local Ace Hardware.
dE_i_kfdXouMv7RhtVefNQLQUCmbB9oxjGELcr4La03AwzJS9gG1uLf4kRF-FkhsoIQ-7GwjhvvZW5qAFf6VWmQN9KfEXuzYf_fiHsdy2-ol78saT1F9dTz-ZzpSP6nNhpDFUM5rPo9aETXajW49DgZomc4gwhoov-1z7jIRI5jRzvYpLkmJDPF2HOIdh5JxpGt9Dt19sjS7DtOMAVTZmCn13YgcrX5QY3tho6pgt39LRGcjXQlWy7igGG5koZUsIvP_gSYtXfAgzB-sik8-uPNrDbjayzvF2V0ouPtsYO2HZxEhauqUEAiAxSw1eLZ2cFIRvA7hQsI2qtWtxMvUDKpsTfUmlSAZP4W3pdjz8q6z6O_oF4VfAC9a_8LSxA3a53X1OKBNQ_dT2Khbk3uQ7VXEBLfFwMxfqPbFRFluVSNr0UZ6o2kOBAdSyS3CmFu9igQ4mJ7YcSz4sRPd_HieArE_NTc1VaHJMS-S8tcH6_ABRxKbHAukOQxK6q8sNOgI4oGT_-8seyc1JxoiK7F1wCu7OO7tbX_bavnu7JKAWdYcIgLB2fpRHG3EqWDijW9IA9yR0w6GzXr1K7mebrlIEwolk2poxzSEotPxqKoihwZ2r48KLXU-ThE70hFfU0ZtNvIIhHAwiYoEZFhhc3D20sxX9Gz4ovjrG28=s800
when the table is folded up, it presses against those bumpers a bit keeping the cup holders nice and quiet:
Kgkap9aRef3qMGDSi1aRfxY4Ovj7iMittD7LycvciZKtvzCAPzwXrwHOTv1Jj34ysXKkxGlOYWkGbUCzpfeXD_7FcloJqNWRF9Lk7vuwpt9pnLlyxTfuCRbvH3_6gHFqAIZNx5HKggtaS7_AROfXM0bjDWSb5Zcyo-64mJ6u8I2zwkEPpoBPpem-eZDXMbV5Z-wMWFGAZQBDaHHpFMmXhlF1zNOizdm7lHAoXfwZEGe6sP7PSbD5IEPvCdK_gJHHDcq3bwEbYSglyabKXAbZaJlTBJpfdHbmKX871zFWURILFuBDB7spA2adodqhl7C5NF71YLj0-e0CdCmOJ2vx9tsAqBj6ZOCqsYVwM2ngVqQZVf51fifcmED4tNxJ_s7XLWCVa41Nq2WNw9ropHMXQjJFt63dyWf2uLkE1LUq7SfdFr549877ZcUI2-tFSdqpbKRsg0Ksla0sk7t8Eh1xoHM--BiMGpvwjaV1Z0QYeziaOxkCrswiflVPBaROwFeTTk6m1Dv6fnqqslGFdYA6LuRWcFxm1_xj61Ik0-d_LoN8AMqiRk5zM4qur6t5TGW9X1uTBjvhAed2QYI3L2tFFdzgwHi0CJx6dI-oQw5PuWAa4gL0r_gTVNmsF87JahnHyvNI7pIMM4ia5ICVl_XxKWIFKk_0VstdZVY=s800
my aftermarket stereo install also had a couple noise issues.
the plastic mounting brackets were rubbing on the very front edge of the head unit which made a steady creaking sound on bumpy roads. i simply Dremel'd out a little notch at the top and bottom of the brackets to fix that:
KJ9tQLgmZSy7oD6RijcTJ7kMtmRizuYFaJLcsL1VeHOXDC978NbcjZT1onn-fnANm9rLXvyBwiA5tVXTJEGY8DU4PwRT2zer9HurqmNpdbvra_lLLrO3leoYLoGeXfkHrYKRj4pG8JD4JsSd6uOggCioiENtrAkUVXBRlaK4lf4_1Vrfr1TFFUYt0bqQURa7L_850aadPbT7DpVHlTifEssg4JzOg4C76cvgRGFt6-UjgasC6gfXAGLEEr9J84PDqxFbqrylWUFFfjPrtIOS2coi1wLNDZxTgfPQ0bX170QiyRv07V9rWlMHYSeD7vETHR3iX9y1d5Y5vSZPaCHIic-hyB5e7evt3QNWffrRRyRrx0SitXVPGJl57jWiGDX94rQNuTbxofQeOS42mqJhEjKhJ8A00k8V8aJoal4Ot9DYtMuywXkoIexe_UO4vqHDrGvadaSYHwR12IUU8ApnCaiJUdXymaHuqEFQCFa6qaeX5naWVERDXPozstgrW3h-ETzgmrSG1NgVz7AwzyIp9lyDFr4RC_kbwbiNok8dC7S6jxLfwrRghh0tcQmhd4CcyHkBrnkr0-vQgoytFRe-DdjpJ0QL7QzKTIydBGjMMeAEuYeX5RDL3Lf_KcRLbNuUBVebI4yZJ1c9DapAwOG6y2pooPemug_KUtg=s800
while re-installing the unit, i zip-tied the Maestro interface box and its harness more securely so it wouldn't move around inside the dash when i hit a major pot-hole.
as a final step with the stereo, i wrapped all the large connectors in a felt to prevent them from making any sound if they rub against other plastic or flop around on big bumps:
6y_FDSJ4fOz4bwSh2ttxdt_oQlUIDGiQ4WIrHdNdM3Vx_spbAOlhX_VUfPt9vPEtbgvdH8UHpcOKL3WkJ3IKFUsRAf9grTiIiJy0-InRVYyhwEZ-gJq2JG-bjvE4RoxOkWMDJWa6iT-pFXfrzy8YpfAopzwwsOwMt281s0sGhWRL7YqM1JRmNUqjrUebVEChQvXWDidNjpTcZuSkY20EaNJbrlOXO0M8FaGVjgbVqrovQyXiG99OLcSjjHIlDBJ_8KvSfCSXepZPcuXQ1TB7OAIQ9s8Vhq190qBQLV4OpxBnbFMwaBYo9fEPhtximc35jQXP6zSYsjwfUw3Eo6cGpde9KM35kkjSBYcC6epmaEQxOR9NHSIJIxq8dxR58nxV1KYWfQXl4SRwJEPhGq079yJy4ljnHVk89cawjH3mVkgPSGGxKNw9X0qsU7_sMtYyo_5EJjryvLIFiQA4uFOE7zvZdWYuqaelE5b16o0CIlG1DXui4fQMCV-jXU37G-E1pP4kAQSIzHh1YUOooA0Qbvqd1T7bgDJ2-sV7R6KgHfPSQI1BqLV-OXnKNqTuLLdkRdeMbQdpHSrKaNYlOwrEFjGHdeiH-CHA0MSpbUyqqXJ-x_Mea_roaAEy0eOlWGzCkwKFr2P2zIiWIudkGk3XFWgPtdpz6CydqOA=s800
the only noises i have left are my passenger front window creaking when all the way up, and some rattling latches on a new storage related project. i have a couple higher quality latches to install on that and i'm hoping to get the window fixed as my final factory warranty issue - i'm only about 1k away from 36,000 miles!
BSR (buzz, squeak, rattle) elimination can be madding. It sounds like you are almost fanatical about solving them.
Nice job on their systematic elimination.
I thought I was the only crazy one trying to stop squeaks and rattles in the same jeep that gets beaten over rocks. K, you are a CINAC Ninja:cool:
P.S. I noticed your passenger window rattle the other night too but didn't want to dampen our date by bringing it up!
BSR (buzz, squeak, rattle) elimination can be madding. It sounds like you are almost fanatical about solving them. ...
i had to fix the rattles so i could hear the voices in my head better ;)
... I noticed your passenger window rattle the other night too but didn't want to dampen our date by bringing it up!
what a great pal!
left Gadget at the dealer yesterday to get the final service done while still under the factory 36k mile warranty!
they are also trying to fix a persistent a-pillar/door/roof leak issue: https://offroadpassport.com/forum/showthread.php?t=4897
and there's a rattling/creaking noise that comes from the front door interior trim panels or the window panes, not sure which. it happens on typical bumpy city streets, but will go away if i crack the window or push on the trim panel. it happens more often when it's cold outside. i'm not sure they'll be able to re-create it, so i'm just hoping it's a common issue that they already have a fix for.
i'm eager get her back since i have new toys to install...
Tell those dudes to get off their duffs and fix yer stuff!
over the weekend i removed the factory Rubicon sliders and installed the Garvin Wilderness Products JK Unlimited Rock Rails that Aimee gave me for Christmas:
wBHjgh5kWph5RYUzyRON901dP80xSNMC7UVRL91ppjP83akFtq0t2VnMSrbqy7qSH9WA0AusiBc1jXiXgC2HfN5xk4kR2FbKBFpgVGs9Tft58H7chpa5_OgG9-36xVAk92V_sSEWh-QVRt4U7iOtCm0i_REZp7BrLOGwaJ0feaTm1fXW_oFGwFUlNNsgl0km75-m5ts7ovRPCb78HWIHOPs-vVAi7tWzeMr8NCL9A-zQN5PaqLQWRxxGksyrPfPgRODRJ-9ZNWDjX09zNeJJhKOGL_C_tywIuTVYFkwD4wxqxI9PkGgiH7w6X4iLIUuheBKsrGwJeH0PZJDP0HujuhdANcSVGAuuVDVv9O5KwvShqHOQiNl0GRyQVmK2qVf6tENhKbmRYB_LlHdFac4tI3kOPRvd_t137uJYxRsqM0tIQopETpm0S2w_EX1CoyTUXGaSRSVlUdzYJgvszic6LdIt5NRyDeKrbdI1bUGElYpPCIlAWCo01-arP8cfAB3c2KefdZ7iIsj_vieKG7b-EIqgZjFTkrsgbsRT4eMV43kCC6qHlO4T_QTpji2kpOcjk1Jetw9R8EeoNPYwCauD1csgUvL8MSN3JEMlVCOWOJxyGgrnByas4D86qwQSKT1rTZ5P7Qe_4fDQvF9iu-oopgTAC3XuZMTO=s800
i wanted rails that were frame-mounted for strength, but that tucked up close to the body for looks. most of the frame mounted ones leave the factory pinch seam visible which i'm not a fan of. Aimee only cared about using them for a step to make it easier to get in and out!
1ImTizl3tktyn6bRU2-E2lzsG4vPj6ccu_nMVaWZU6CcyUJ7-GF_jXzhFAlxMf8Px5GKA6I4sSXDzcpBbRxJ0QYNNPAy-yjg4xQ_i6Q75V5i_TzZAE27k_e9sH3jwcHYmtc7N53rY6bwHWILmBoJP2J9ZYuaQLJk_sg8MKoq4HYVfGaIBtMGXZoLEIqFsTesMjncu3XDt5n065MXZbdx9gSnzJODpFH-pHzWAHrABYU9aeFkGYKFcag5t5di8IiypzeSPiLTeYhK0_MQnrocvDZls7yxNHBDwHu4LnkP6reLgMcSzSgUnIjgH7O_4gj9b0zuJKX9G4L1pyOhr_tSpW3KCvDfrogSp9ICS-EbFfbQ-Bjd5AEtv11tU6LYa2O4-BkiMpxDoFJqLlaX8ByWzLYcQaZlRMp7wOH-fqPYwgZg3SxJzWD5aRhkAeYxkv9dVo13UEkeRJqxqP23EeI0-vgPj7TD96AhFkSAGI-UlOLME938dkKYeq4J-M-WANsd4_zVFB1kXFaZayH3StrDoXHDQWm5g8Ain4UILAxVwtYNbsNUfw-iOCfu06NOC4C8rUFH1c0jW-QM4aTcfel0zpS18Nq2E6Vdv_eB3ho0aUtg88fW32jptQI_vZt4kT7h0y7sRfDEsY6I3BKahLdKxJNMBDTesi8p=s800
i'm happy with how these look in person, and i think they'll be stout enough to last a long time. i did the regular bolt-in installation... the instructions mention you could weld them on for "extreme duty" use, but i feel like it's best to keep most mods removable. if anything i'd add a third "leg" to them to bolt to the frame.
if anyone is looking for rock rails, the TJM sliders where also on my short-list since they are affordable, frame-mounted, and tuck up close. Sierra Expeditions would be a good place to get them. we only went with the Garvin instead because the bar sticks out further which makes for a better step.
They look nice.
They look nice.
thanks D!
