I’m right you just don’t know it yet.
well, you might be one day ;)
Something electrical
Thanks
I want to play...
With all that wiring, my guess is that it is a security system.
I want to play...
kinda!
fixed a few minor annoyances...
stiff pedal
my friend Chris (defectivemonk) told me about the throttle pedal spring mod. i always felt the drive-by-wire pedal on the JK was overly stiff, so i was all about this. unlike the originator of that mod, i just completely removed the inner spring instead of replacing it - feels just right to me now.
i may also eventually try something like the Pedal Commander module to change the travel/sensitivity.
_WgjMg32ppDmj9hx8LRgSF4iH2EeEw00cNtUW3MKNsbHR13iYMo5Ea-ikHtkdSfk2GZ636ozxqtNM8HQKjRI3AxyRmuRQI8L-fnLB1MLC-UHrFzckDC-8JTskJ0py1Fk3MIRuc8IaX6pynwR6XtSd9xIMiingPwfXiwHu-_120yr7aOco5tg2jeIhPxAyP93FtR9kLGOxdlZhBSrq5q_jImJy7bvVWjvkwG5Jk-_rITtXKLyzte7St2EgngxgkHB6LAjI7GsiWM1-ZzsZVqPACPU0xAmPfHq8R93B8rUgt6D6w0JHzk6Um4Ne_al-0h7DWL8pLloAK32485PX6ztGXZjH_UXDsgFs9PtZVPSTYDlmPmG-0klachubUor3YI-6_NZE9xBqUXdUGGLzhYKYOl5lMIW9UBdMuvhYp1Tk03s67rq2ZFeeFF6R4HdQTXUXnRQfTSsNLLDbyvRpWSVt-bAKv7ZExsjhmoLPVDT-Ln18AMU9KNppJVsjwnU3zajYtVpDhvFjLYeUzsTWLyoe4wEsaOSQykUPVW_ZZm_V6xyzFp813hhZcUgjAfxft7IfBZH-dAkK-cwZDxgUH_Eq41Dvg0J5Uxq_tLWgSrxR64bRKyokMxp-m0kUAULbAdy22xlYAlmmIQA9tvsI_MDCcEtQl2MJG2crY9HW4NzZAaLffE8WGu4aOF6=s800
wandering carpet
the carpet in the front of the Jeep to want to shift around often, causing it to come untucked from the trim at the edges. a while back i screwed a couple of the little plastic nubbins that the mats clip to right down into the floor pan, and that solved most of it.
bTSnZwqBCR3XWo_GB-JsYQD2YbcUgR1PuzRW794-iglVaTLk29CccKKRB1PcCpAkdCXj1Gx3Ee_WkUv4iPWnvdo5pmntq5KtbXkFtIq2xUiQND7I1gJlpSvBoCyffDvil40JB2_iiGgVLpgzM33VTE6-AqyquWUH0BFNP44XTyI8HuRx_TsJS8If46QJ7Pre0SXqJ_K7vIvw6S4WPySqDX7kNZK1QcdKDGjB11NV99a6mYCWXhawg0JuIGtK01yAGaABeaur0FPx8p7L2nKUUYgeqOc_D_arHKOuZMlgIdxJF4bn2JCkF6BBfjnAJaWpjIeByI2H_QskhnVSAHTJU98WGeVN_-zi9fR_HuSDki6ty0khIf89iacK-kYHRwunT11oIFuA5rIQue_nzK4ZLhcN7oPSM48lpsXI96G4tQoSQZ537RIKSeLBpOhyquRoIReK_6c4feGc_AQnJQh5MEKQ7Qyz-8hGxQGFwiYr2sTbeyfDsE45h41sIE4VLL4Q952PAVvvO-niy1yK91IEJUv89hNHS5dJ1310DrFtwzh5IYrpoDn6IjHknhCRfQ0QvuyV6PTvBCy8ohERbKtL2iKTJu5-W86GMhFK-9bTOYRVKZfrDAb4s4f7NvUs_i7eNZFCg9Ajc_tKQ-8GDZlhlGmKK2JcMOf9KAhQUoigSKYrgRsvzG8Wb0SX=s800
the center would still come out from under the dash occasionally. adding these little black washer & nut combos onto the OEM studs that stick out just below the dash seems to have finished solving the issue.
6KcAUC0e3xagc50KZbUEGiBMWqNIQ6Uk7j_ErFISq56ZQ__fxz-JgCXx2C4ffWKtBm2NBlm4YxyjeH-aoW_NGKBtEoISt9yOYmLmptejbXdlGCPb-WPstzqoJooD_o0_ZIhijS4eEjmPGqERZuv46wmNvcfSZHwKXe73aUdDrYqxWERwBVAZ-YMr2Lok-NS1GEBDN7y9YFrbQWMcGZaPgrbdtSE2m1vQOwThENKislkTn9F3j7nM24t1JOm3nJpIcJM4XMJ2wEn9b7HlpxXzEERMTCDmqGj1GwYev0rueUFql2bN54JkKwSONBw3_1Pnl3QHSjMIkRAAc4E185XYKbTLegnmMid_NWCmc1J5rLoCXm_KbSlDaLC5xHtrhoAsWbthmUeWq0ZxuP6HYlHtnd724Sj8yDcS2RPJN9SMv6MKeCoh-af4KwzO5fhbx5jiAwkkzvyZ60KoCrIF__1oCbK9lYyknmlSUAUZKZ1RsjBVr86AZZAYtO6sCQvx2Yl-AVZfFDWHrSyypG_WlDGC0G_g6GMmQtnvk7kZaijQ2WXREJXkvJXFhYQl7FMviY9LTVNnLbw2RZh2DHegOjdUsdIyyLIfCdMeld5TvgKUG6kydtFvFi00m6-pjrUpbBpe4qR2fQXW43ncIzBkv1vXXAGHuawhx-CLbzXsXlvobF29XQK7JGP_5v8K=s800
do-over
earlier this year i also added a BOLT hood lock and modified my Rugged Ridge grille insert to work with it, but didn't like how it looked. i finally decided to undo all that and use some black stainless locking hood latches instead.
poyCPL52fDkO-EDmLns4KLpySeIFwR1xOmrMuAWjrWDgHy5PhZRtIWh2YAoU9WX7rUAAibdG0ebvPHTC9d5htUrzNdvzzO-TyoyjotTaljyC1LwVs52BwQejoQ1JouvkWP6I6JBwD2Ohnjb98x6ytLapRlyyWCpSNlrAb3GEw0JKhy5VptpNCXilx7MIckbjvQeO_BoSqDO9wxcpr3XHyqlw2myOZUl6q6conMJp9sdqXbCf7RHpegVF9yYfaXlxrPvKJ6okLmm8eg-Cl1SOFHBYK9khu3IQa6BqxPlp3SI5H1gPLKxFY22N7onO0SumUhuBkC99LA_pFs3BxmydES7DOF5GKlemjXLdNFcXTciftkYlWwieQkMwNI5twfAQQqBUFrA5SvvWXUSfeWPj5saX5gWRL-bYlLvbM-pu3JAN7kNEtfpO3CF6SsNdPbyPq8WzBdiAhUUUy9aQs7ueX00UJRzwnzkmXxRzw9W13-63ivdZmkLA64DPBg1mJYcId-hxuVd_cWtcGwI9CDpgySaqNZ5LqiyJfsdwPSY-DHMvOm-5ymLEn1hgOKJBctBjCUlglepnqvkFML_cAEB3VHDXtaF_sktrkhoJ3J5qQLPq696yj2qD6mYkZ9XAMiPxmiERjGi1ZLzfn2BKApLefKulWTomqYkD7VRxYjDvhi5zbzLHmYjMJnU0=s800
i can't recommend these latches for most people... the mini cam locks in them were really generic junk, so i bought nicer locks with actual cut metal keys from eBay and swapped them in. the latches are also very tight and would be hard to open for anyone with limited hand strength. the BOLT lock was probably more secure too - i was primarily just concerned with stopping hood flutter myself.
they are very sleek compared to the factory latches though, helping clean up the front end look IMO.
7lD1Kp9X9GRCAUdII1m3UIGb0OS0db9_7rwZMmZ7ehj5LzlklduXY82cUwB4Es7gTO9HKlDS_HMmgHIX9TCtjez6UwMRipwt32mP9j2SXcRVxMzcw_4Lc4ttD3oKsZIyDw_8PetaAa8iPSF1856DfCFkeHnrevfVPXxV7X9rL1wWfmzhoRStONkqOd23MIp5Eyn-4OV_BLFjjhdzfZn3X5ii9cv6yImmIY6z-bhWCYkF7vaExWtctnCN0-6vKcfDx_ecIUzZHLzH1GyE_gg4GM29OwxQyvClgeH6lIDvYCtSITahRIO5qvSgtIFMhhjqdyykDCAL8j0s1e7Nuofpa5_luTgtyDVPeVA5uLFfOekfd_fkmKpsqDyKwF3W1agmwRbq5W0yKg9Y7uwnLBmrG0priN-NNfhBf1OAkveBYLza1eYxg7RNvA6kGJR3j0rOYUjaD31maPNciV9QSRnBKyfkKCEB2jjpbVBHatzqAWudlhofOsfpJuuYsqufdcnV6Dlqt-5q7_ZXytkvvOKt28MWHPFLNwslmJF7wjq0uNlu3Jt46iPYOiv_oE2UY5RTBRQBBv57BPfFBuhaxwUG2-Swky9x5f0l9MAiuFWObSkGH-w_1JpAe8lssD4z8cl-Zdn0zG41tMnKIKi0bKv2Bb3KwwLg8YkeVPo77_pIQSbju5BOvzRlV3CI=s800
candlepower
finally, a more obvious change - some very cheap new headlights. i'm actually quite pleased with them and will post a writeup/review soon. black hold-down rings were added at the same time.
here's the new latches, replacement grille, and shiny new lighting stuff all together:
Kfh5s8FBpzCa2AalerZIM7QqUZZ2uKBRSoFeuasCG-hJEeND28skVeNSmtSHinarAAc9i4IMIHZxsZvX0S-zMU4or6x0FqoIYCEk9JYMJ6wZ3qqR7SDP-ihhDt1kfn6SNedUqgABOHarwhVJo24aLYG8IOQ0b2pPWki5tx2i3miySUKcO_ewInf3VjN_eW2fipORg6_Oegz06pH074FIfW8OrELJc86Jjz7ll_im3SiH1HCAbsW10RQjDbzEvbZLKTriWh9FkIjIsLB3VKLMx6CUW4uIqmOs1la1ImTnWLuwRh10eC78q_rfOS_V0hIXlApD5LTMcf-mlbylW2Rqe-nHWdQXuzCH3pOulG37DvwE8gUmFRW6ZCCiUjmBN2bdPvMYWebFNkMD6vIqDidWouPRcsi5WuOEjbWuqPAJt7AI9_W3vWwOfRJ1eqT_Zcv7jWZKrZ4RDZQ-3jM_8YSG_t7NvA85m92_4YiVq9mNHhRKVaMcM0Tmfc-xcpKqEMzf3X3IsVNU_93TZrPE6STC1IaA_cFKKRMltBQOo0LLP5VKb3tuiAcPlzUK29aHnvYoFqERJrwQvj0Ate21MXpKHlU6L-UUSbYllzI8kLpTBcBnSkeVxHL-SKG1KY7BB_9ZMVAjH_xOwDNqARVX3r2Y2UqZPC_Ws5_HzrJbKS5F9SsHsWbtV8g8cYUY=s800
also the mystery electronics project ran into a delay but should be finished later in the week.
i was right, it is an electronic thing a ma bob
SliRAQgwL7SBEDsDhyxxXXtkX6bKgYWQs7PZteWrOmO9tdL2--aNNmwjyEwmrEa5ovqN3l-tHJZ2WIWRfhwt74tY_G4x32RCGl__kAOxQflP6cRzEfw2DEp5Z6M0f0SNQ8sRXsUvJPCE4S0w7vAVN8fWaX3PLgzZsu2GfKow-_V81yKQmLQGgZiuw0fOlXou8Yz6hPRJ2TOth5hWsDBLdgI2SdH_IjSMOMzRS2nO8kDr8tYqMrEECT_Ii_FXQgzLJyj0gnpRN3E1UnlGpA2YPTkXaE159PEQ_QoSiFLKkCKY9y0Bga0pqJ9iiJ0lC-U0nSdPoEg0jLy714A9JjpDd5PHle4JubKUAV6SfL7pGwIeJ2J54hsks2BXtZSjx3Z4e7dCRSp-DJFcTwWJfuqZbBBBixIEvrJ5141hxcoQ0prvMRCegXKictYWnGBhohb_TYmv7F__P0E8q2s_rA13bkQjoNoKIm4XznTjJaRCiD4naQl58W9qDIj2uyH6Jug6CE-vtq0Aqv6Q3MIcM0-kvKZleQOC-ard3hqXMwGzR2JZRdeadWAmE4ZR5Cmu0X9f9Zt8j0UKwuCH0B0h1iIOKUniAdOtBTXGrfiMPH98N9V0D_duKPW9_4tSAbnV9GhG4EeQmYPkB51bfj2YBlntIHXB7qj4nU1Vyfj7VU7_mZkuU3QMa8AfBpmc=s1280
random bits..
  • unfortunately one of those eBay headlights i was so happy with started to fog up. so i ordered the Pro Comp version from allensoffroad for $265 shipped. as long as they last longer than those eBay ones, that's still a great deal for this style headlight IMO. they do have a lifetime warranty at least. UPS says they'll be here Monday!
  • my secretive electronics project is nearly complete, crazy long writeup here: https://offroadpassport.com/forum/showthread.php?t=5514
    y1SeYwu8cCHDCSlS_e5lWTdnNmSVa2SHzWbwF7RakC1WIE6K7sRa0rxaPKwIA-CNpNylQOhuK8UJ0FPKSm6_f2S6Jyx52ST8EqoJTF6-W1nDcujK8gvh4viVRS2l5bfWY5I0qRwpieUEqy4eEVAlm72a5ExJwiPlkVvMjLf8XZmAFhQwDgU17hH2mWFIZLlck1D7MoFAEgDm3ZmwFwPVAMmSMBzwkr0ohOJ6RGhdMB1mt7oXOx42dp9WxtCXgEaVfwjWcAtC_bAwP0hQAqrOibQKHu1HXzpR0a7ngAmJ2tqFz5aTGwx53m6LbWg4rI-UcAA1rwQu9bpvU9WV2SlmVGaNcv667P_lvQjKaof27vrMrDMCfu8IROayhUvzGxauSTHRVvBJmwKx6oNPxozoCDzpQTwqkCTy8WH-HUThT6fjM9NSaYnZJFRvC9gYjdhJr4ZvY0M37rn1CFNOLgXYaL3XoMuyKmg9zvKHjG7KjslPJvAcS7_u2vRoFzjWFyWyjv_E9p9-y06RY7p5fg2Q6_t2jeOS14jGptOVgDgbvCgi9lWsCDWmJImMdq32baH0r-5445B3lJ0gzpmkmLu9-k1Cw1N6ii3BZO4MHC9pCNARgV5p-DKihhYwJiBP1uQi0nfVHlKxKX4zYhVLn5ASYs3TZx5y_mV-C9xOEUTb7jyPtq3SyhiiOuNZ=s800
  • check this out - i went for a quick romp near my house (Lake Pleasant area) the other day and it started to absolutely dump rain, quickly turning the trail into a stream!
    -9J6Iwb3x1YgiSIP0VpV5VVIsD8hYWb2sU9XBvYvEaOlErsGGKDEukyV2e4J1mMXIdm3ABnodbNTv3I6JrTQKaIwbkUZQ10nDwU6ckmK6cuEaffAQljtfPB3m_SHRKItW-Znvg9cYFPSDIpUPrKtx-u7NnldygxU0AI-reDV3JRKEjXkndRENnFM4qkFhw9lqkDPFfDkKuaJe3VW0RC8HjxhIBKr54OzkTE04WhjpFmS9HNJS74ocuCaumZpZWnQdwkPz-3CETtAr7janQe28gb9oSoo2pHw5vszxkf_MW20aET8uFDmFz5bYeEfZRgM1GV9WUTkW4T1kw_z3ZhPXfm0WPDUXaWg0cahgdje2U6j0Xs56PXqOC3R4HdV3RGLgb7b1JkNPmBqZ7DoV2x4OylLflNPORPS6f-B20SndTC_VzLFe9CNtKl7ITkUHLKluoQPwCK9eUvErMXgBvjOhhRNor2ybo0xwspJWKbAQoJ08dyrER9kiTJn_tIDyfix7YfbPonJhEWAoL5epZNwS_Lq27me0A4UQEEvSrpLxgD3QxkQWzkEq6alGeEzt2glqbYtq2HuL4F8H6xAkHvXLPSkycfbJb5F3YY_KB9CnVimTa1PVuqvGSaowwL0UR69QAt8QdNqacAD2n4p3MkCHci7lCpTPsn1mSUl2B-mvwSX3hzFS4Sszscu=s800
    i had crossed this wash in exactly the same place 45 minutes prior and there was barely a trickle then!
    S_A2E4oCWKwr_DR5Fa-fAAr_eU02QYuIKhmSfdJmUshIDymHAAm3seYNLtWVaERKWAmp3PMVaDNFPsrvfukkLYdIJRXxRFqVP-cTVmC4_4AKVxr7rZkz_2wkUCTiwIH2bBO84ZApIWJxbVN5B9FA-x1kftngCbA-35g7bZJM666c1fZGV2T1IRJhXlUq5IkuvfIBgef9R_aYFCoehxkjFDtDAF0D22ye_YkjAkTjiy5_92guHvt6U66T8_RTIEkmuklVIW-MPAjYC6GFUAO9DucdkUaYoii2uaOLjIobqgv2lhEawrx3oo8PwBORhfLN6yviLSfk89QNxSsSy8uG0U_QJm9H0p-eLY2Q74qUm3stZxGOhebtLGIQ-dwMRkuC3Jl8ELcRQLL0b4mAWDHRTdFYogDQi47wMr4rq9wcJWv_Wi9owsh9S8GP1Ub3EBJCK0huOP3JMJZ93KO9g1FSZ5nvJpTko-4ZLw3eeeDWEeBy0fA4zTz1Tfg7qwqVq_-yRKegmCUkmZ8A3nwhj6sPBURpIswpWS4N-5YUEsymX6lKgbR38By9yoskwastRHtyVJ9RhvCvUHs2EAtuUWEqD-l0xY9EhfSSWt12mqFciVat6wIpInuDLfuBW4V2FT5L_grRHH0uDhw3jPTU0yDzmiFboKV2_oMkVPH_N1Wq5YqSQaWd3rG1p2rg=s800
    WMRwEtGmz7GBw4EtlhBxO7bf-yexj3EndOJ52-RG2U3NWAkCSQOl0inpMGLRFowsdYACOwGry_hCtmEIbZok-bQUt6zhVI5k6eKYSRir0lBTKqSd9Z3FpnIDwSs-iZTADvnoBucwuZPsh9V3Ysb5SBOibgitYhaMNb5SdRJouaONDKdnMn-fdB5_JsDWalbIGuNiT_JcIHD8VFUaRXNMU6GP2x7QIBcm3ZOr6LnRnyNmescp6rGWgYBv6zwjMJ59vnLFLb1skTZNUl0rcktFr12_GeY01MJ5ovnwd7C2vMnu6mdIowQO_0RcRlK6PkujgsJjD9pWGTMFZyADU7FPmKaJjRB1sn89rNbBxhAVA-j1dX9aUGW7HS9-JcZeYL8mdSdlCHT_z8wOWk7rg-8gmz_f4DGrNPI6LyrZkzZg1QL4bvvNzEgFqNEnhlTz5c7auLIRpyA6Ih7nfgVxPj1xcHXE9nJll_1DSJZ_jtnUShNy9zoJYOM4AZp2uTDv-5c5iZ4sBdvUXZncFOxzZTP0_lA7eoPM46vAxwMnSwv5fmLRC99Ge756uWcekyIwtwSVgTt1xUIta1PqzHMV7lnSl4e5zQgXTSvgviMaM-d-G1GwyDRht4Ozv5y5xW-dgmRgOyNkp3j51ewn9LdoqDq46W02xvix961aImsIpEEg7ktyj_B5aFi-Hrgx=s800
  • replaced my factory horns with a set of PIAA "Superior Bass". they are only slightly louder than factory, but a nice low tone - seems more like a real 4x4 now instead of a car.
    H6JYRsvxOI2ATDfCpSq9zVr0HpnyxJOxjwVD5OrNWztfrGJ3pYk1Xe67wsan5ynuVUQiWu9EC5y3zI76jVpvcVxp1lgSLJddIf3BaG0a3CgOiKQ4jS3ZQL68kbzrYDK7_z1H28wic9ERiaWp0jfczm5Au84lK7fp6sBDtdKKvRlFuUrP0czJcBPd6gz7p3HgStr1xmJl-29yP97klwdGMyVkkc35tuSOE1qOk9SekYbBp3IJJJW_S2ngvlkl75ahXZEOrDhLM1EWnsD4g8ZM0c0MNmWcnG29LPxai3e-FLwou2FIrYtjrZvUlejGfdic-UIYzu4ZjOZc6H_w0uRuVME6g__uCnUpwSSbgJxzfWhZmgZpNCHri0ZBmvCU32jWnEu65geuemQydWQEWG6dGrafaQnQ7EBbzO6d-tYEdmzSv2HdSnXFNY7ZR4VcdcwnZz3QiXa38jlchqySx7eNMRgeq8zdW9WXTil2rb1zWtx6D14XojGFhqOYeElcjmT2hMJUTj12eOBXAJKEUgS-t6ejtxGwPwha7YJEsGlrG477dywYitZduVGf2BbeSOtXudFZHoz4QflVmc3a5i_75ug-TS4sYfNYfqPG70ZsTtyuhK0aBjATZlxdPk_jtpm7Plc4DHeWaFn9ivZrmjffYPIm_XZPkVKUYt_LqTK4gOdyJxo0eoKt2nuF=s800
    i was able to mount them in the factory locations with just a small bend to one of the OEM brackets. these are low amp draw and so they don't require any extra wiring or relays like an air horn would - pretty much plug & play.
    HMw3vTaIWWuWk82SqNItQ2jckc_4gkFLvGSe79J2k3P3QrKNvp5xDyzt8ASA7w_myvAJPlRTq8J65Uqsf3eTRsRvPiCE_s6yr9XLZsDZX_2v0W1wEKWsGK_4KBtcFLN8HTfSyjKd_dDCOHBGWJQ9Yzg1meUH_LnHH_Sa1U1c6K_gOKXTHAewo6Zysj1u5VoDmsr3wP3hBiuYSr4g69UWkrQ6U9nUUxTNrP8MSrj4ZI6RVHi6SX3uyJKthy3oJ054pQQUowecnDfSIFKN0vMqXvqUDobOlLYam28W3sbYfxXW_n72pPctkUAJSWxX_643zESzeMG9qKhWyn0vZXzWzGxjy70PFJSrUflI6HHvfTp1LDz64xZJDAFiYZBc3y1Oxvd3NGgu4vMkDBvKIlty7szgh1IWIh2TYZLrO9N1sE2cpABFCn8isaMDSISI8GU1ELnp8p1Brc84rQ9SbWtFrqsS7Hcr8rj46N-v2cZ2Z_L5cmtFOyJ0W-2JPVcYo3uBKfyZfFZ2KX-AimecGagpH2Qy7U22iiquTvRCTX9lsw8he-k1F-eyb0Xrgqdq-3tqsEN7n9m4DnIgWbYsuVG7lOG_GjXZEkZP-cFTvUtXafhp7vG0lzBVK_n3NLFUuklNZr0bXoFC_MAI1hUnylLMBU1wYQkeiFecsMY3SyqBKolTCoQG6BsoepZC=s800
