klaykrusher 65 Posted March 19, 2016 thanks for the tip on the evap mod - did you lift yours any yet? i need to get an engine/tranny skid for sure, but i'm having trouble deciding which one... a lot of the nicest skids are meant to work with the other pieces as a system and i don't need to get all that at this point. plus i have no idea which lift will eventually make it onto here or if it will need a different crossmember or have clearance issues with certain skid designs... right now i'm thinking the JCR is one of the cheapest with full engine/tranny coverage and so i might just do that as a temporary solution. if money was no object i'd get the the Artec full aluminum skid system, though the MetalCloak and TNT Customs setups are really nice too. No, haven't lifted yet, she's a highway queen for now. The plan is to go to 37's with 4.5. I like the AEV setup but we'll see. As for skids, I prefer steel and also Nena mentioned where she no longer uses aluminum skids or rock rails on her "girls" as they just do not hold up compared to steel. Share this post Link to post Share on other sites
theksmith 5,897 Posted March 19, 2016 No, haven't lifted yet, she's a highway queen for now. The plan is to go to 37's with 4.5. I like the AEV setup but we'll see. As for skids, I prefer steel and also Nena mentioned where she no longer uses aluminum skids or rock rails on her "girls" as they just do not hold up compared to steel. i'd like to use as much AL as possible on this rig, but had already decided that rock rails need to be steel. i've always used rock-rails quite a bit to pivot or slide on - but i see the undercarriage skids as more of a backup, kinda like if i hit them very hard then i probably had an "oops" (on most trails)! do you have any idea which skids Nena decided to ditch specifically? River Raider was one of the first companies to make AL ones for the JK, and i've read nothing but bad things on them... not sure if the TNT or Artec are designed significantly different. for rock rails i currently like the look of the TJM... i really want something that will tuck up into that area where the factory Rubicon rails sit now, but i don't want pure body-mounted ones like most that fit that criteria. they need to tie into the frame or factory body/frame mounting brackets for real abuse IMO. not sure if the TJMs stick out far enough for me though. i also like the looks of the CBI Offroad ones and the Poison Spyder versions that are similarly styled. Share this post Link to post Share on other sites
theksmith 5,897 Posted March 19, 2016 saving random bookmarks for later: compressor bracket, a little different than the common ones and cheap enough that it might be worth buying instead of making my own: http://www.innovativejkproducts.com/shop/jku-mounting-bracket-kit/ Bestop under seat storage drawer that i'd like to get (less than half the cost of the similar Tuffy): http://amzn.to/1Uc3dL8 some great info on the TIPM (the JK's glorified fuse box and solid state control modules): http://www.jeepforum.com/forum/f96/oem-tipm-study-1200238/ http://www.jeepforum.com/forum/f96/selectable-battery-accessory-power-source-1248471/ quite a few choices in several contemporary looking 12v switch designs: http://www.ch4x4.com/ i like the simplicity/compactness of the smaller Toyota pushbutton series, but i'll probably end up with the V2 horizontal ones and use a Rugged Ridge A-pillar switch pod. UDPATE: another great place with loads of switch designs: https://www.otrattw.net/ bolt head protectors (if i get the JCR skid or other brand that doesn't have them): http://www.rockhard4x4.com/product_p/rh-6000-sw-496.htm Share this post Link to post Share on other sites
DanJL 46 Posted March 19, 2016 bolt head protectors (if i get the JCR skid or other brand that doesn't have them): http://www.rockhard4x4.com/product_p/rh-6000-sw-496.htm Not needed if you go with the AL Artec (http://www.artecindustries.com/JKU_UnderArmor - the bolt heads are flush with the skid plate. Share this post Link to post Share on other sites
theksmith 5,897 Posted March 20, 2016 first real trail run with the new rig yesterday - just a few tiny pinstripes and some scrapes on the front control arm brackets, front crossmember, and gas tank skid. gonna need a budget boost, it's sooo low - otherwise handled and flexed just fine. wildflowers were blooming... also going to have to spring for a real compressor sooner rather than later - the little $50 thing seems painfully slow - i guess i was taking the big one in the WJ for granted... also dealing with hooking it all up and then putting it away when it's scorching hot is a PITA. sometimes luxuries are a priority! Share this post Link to post Share on other sites
Bradywgn71 1,040 Posted March 20, 2016 The MV-50 takes forever to fill tires and mine constantly broke down. Just like you suggested to me when I was having compressor troubles... Puma. http://www.ebay.com/itm/12-volt-1-5-gal-air-compressor-Puma-Hotdog-PD-1006-/381554859127?hash=item58d6711c77:g:Rs0AAOSw~OVWz3JW Not one bit of trouble in over 2 years. Share this post Link to post Share on other sites
DanJL 46 Posted March 20, 2016 I also don't like sitting in the sun to inflate tires. I assume you will want to go to larger tires in the future, so as a reference, the built-in compressor in the Warn PowerPlant is rated 5 CFM @ 90 PSI. I have my 35" tires deflated to 13PSI on trail. It takes me aprox. 1 min (I count in my mind to 50) per tire to inflate them to 32PSI road use. For what is worth, the Warn also has a built-in small (1/2gal) tank in the unit as well. Not sure why, but it does. When the compressor starts, it takes like 2-3secs to fill in the tank first. Share this post Link to post Share on other sites
SlyDawg 14 Posted March 21, 2016 I also have the Warn PowerPlant. I also added a 2wayair system and really like it. Fast fill of all 4 tires. http://www.wildboaroffroad.com/collections/2wayair/products/2wayair-tire-pressure-system-base Share this post Link to post Share on other sites
DanJL 46 Posted March 21, 2016 That 2wayair looks really nice. Do I understand correctly that it stops both inflating and deflating on its own based on preset pressure points? I don't mind the crouching by each tire, but I'd rather not to the in-mind counting Also, have you tried to run any air tools of the PowerPlant? I don't have any, but I'm curious since Warn states that you can. Share this post Link to post Share on other sites
SlyDawg 14 Posted March 21, 2016 The 2wayAir does have a relief valve that allows you to air up to a pressure that you set. Once you hear the chirping of the valve, just shut off the air supply from the compressor. I do not use mine to deflate because it is just as easy to deflate using my Trail Master de-flaters set for 15 psi. I use a 3/8" hose to hook up the compressor to the 2wayair connection. Any compressor can be used. I have used an impact wrench with the PowerPlant and it worked great. I have the same PowerPlant that you do. Share this post Link to post Share on other sites
