3 hours ago, theksmith said:
scored a deal on Facebook marketplace for 5 very lightly used Toyo Open Country M/T 37's on 17" Black Rhino Barstow wheels...
i don't love or hate the rims, but they did let me get rid of the spacers i was running for the stock wheels, so that's good. the Toyo's would have been my second choice if i was buying brand new tires. they are 13.5" wide, which also isn't ideal - but i got all 5 wheels & tires along with TPMS sensors already installed for less than i would have paid for just 5 new tires.
AM-JKLUZ1BV2WPyhs1rY7c7AJCQfshb-NGG8fgVE
AM-JKLVAvxluIhxqz0MYWIjsHEqr3vMxaR7Ji9U5
AM-JKLWSQjhKxrYpSX3B_7KxOPkrWsBYTvBuynqf
AM-JKLVg_YMedcGsvKDiZrKhWdVH-huUbrNR7__Z
AM-JKLVGs8Z6EqxklJ7sB3_FUaMpIABvlx6WkwFe
  • had to adjust the Teraflex spare tire carrier, remove the wheels spacers, and slightly modify my license plate mount
  • also adjusted the speedo using the OBD JScan app
  • still need to flex-test and may need to adjust bump-stops
  • need to re-gear soon, which was expected
  • aftermarket brakes just moved way up on the priority list
so it's only one tire size up, but man it's a different world... i could wrangle the 35s on and off pretty easily whereas i could barely get these 37s installed, they weigh considerably more. my braking and gearing weren't ideal before, but still very manageable - both suck now with 37s. basically, i would not recommend anyone with a JKU go to 37s unless you really plan to do difficult rock-crawling trails.
...but it does look AWESOME!
they fill up the extra space from the Nemesis fender flares perfectly and should help with my chronic belly clearance issues on difficult trails! ;)
Gadget looks like a beast with that set up! Shes Stylin' & Profilin'!
ric flair GIF
Whelp, I definitely can't take the same line as you anymore... 😆 I hear you on how heavy they are. She looks amazing!
Good thing you saved some bucks on the setup, you're going to need it the extra cash for gears brakes...looks very badass!
did a quick flex test and found that i need to trim a pinch-seam inside the rear wheel wells:
AM-JKLU5DZCrQ_wP2lXciITwGknVu9Xew9_7SBTI
i couldn't quite fully articulate onto the bump-stops because of that seam, so i'll need to trim and then test again.
AM-JKLUBo2ycLXhT-gVtdyCEJQUQYeu1brf39YfK
trimmed this much from that rear pinch-seam and the back has plenty of room at full stuff now.
AM-JKLVJ5tF_aTPN12-j2Zaca9bDGO-Vn3XzpW19
the front inside edge of the tires just kiss the bumper right before full steering lock. i'm going to wait and see how often it happens when actually wheeling before i trim the bumper though.
AM-JKLW6sLAFlg29EVFonvNmwuIhUE_0Nd7k2Fag
AM-JKLUZNqIs6IQKB1ekfrCz89LXD9uzFqH4tEQn
  • Like 5
it was almost too hot to be out grindin, drillin, and weldin today!
...and no, that's not a weaponized boomerang! any guesses as to what it's for?
p.s. thanks @Bradywgn71 for the hand-me-down drill press (and @DGR61 😉)!
Looks good glad you could use it.
made a new gadget for Gadget:
  • Wow 1
painted the center caps on my new rims a textured black to try and match the wheels. the Black Rhino text was around the ring of the cap, plus their symbol was in the middle, plus the text is on a spoke - too much free advertising! i left the text on the spoke... for now.
AM-JKLVWoP2k5LCnbD077_YKHEh-8Nb46x41Hejy
AM-JKLVKFqG2rp8tWolTkbJfHXdQ-HixCS-11Iau
found this nice little boulder today:
AM-JKLVJoXYUn9UTruEkXYmEFqEWC0i7VnfQFGTs
AM-JKLXhR5q1138_9WWpnWDP1z3MmAbuKPQhzTSI
  • Like 4
It drives me nuts how much these companies splash their logos all over everything.
The “de-badging” turned out nice!
Edited by 4x4tographer
