we were doing #throwbackthursday photos on the Facebook group with "when you got it" versus now shots... Gadget's grown pretty slowly over the past 5 1/2 years, but i'm really happy with how she looks and performs now!
AM-JKLU1C9l5DfZRoi-iRMhciNvIZn4Ehef4e6vv
  • Like 5
She looks amazing! I saw your post on fb and considered doing one of Clifford, but he looks basically the same, so... 😆
added a chase light (a.k.a. dust light) to my rear license plate / rear camera / 3rd brake light assembly...
before:
AM-JKLX2DcxC1yvxRaH-9WAEEOYC4EUnCO7C5DqU
after (with chase light on):
AM-JKLUxedfXCHh0cA5-IKzw1zpbdDliq2xBzY0b
after (with brake light on):
AM-JKLUdizw4NzbNeuR7tcqNsmvTjoz-ePvESPm4
i swapped my previous 20-LED Custom Dynamics Red Truflex strip for one of their 40-LED Dual Color Truflex. the new one does amber for the chase light or red for the 3rd brake light.
it was a fairly quick project. first, i made a wider mounting plate out of aluminum, painted it and also refreshed the paint on my license plate frame.
i had to run an additional wire from my relay/fuse box to the back. that feed for the chase light was run through the N/C contacts of a standard 5-pin 12-volt relay. the relay's coil is triggered by the brake light so that the chase light cuts out whenever the brake is pressed.
AM-JKLWLzRWtW2v-ATHQqU1iMbee7Q9bWyRgSh0a
then i just needed to change out my JST connector from a 4-pin to a 5-pin (the round connector is for the camera):
AM-JKLUwov8a2mIx-8tzWWvOmVUKHIMUzljb4gi2
and to wrap it all up, i bought a new custom switch faceplate from CH4x4 for that spot in my DIY switch-panel.
AM-JKLX47MMyvRWd9QSGy7eYjxGeL4hTqx6_calx
i'm not sure this is actually going to be visible in the dust during bright daylight, but at least all the wiring is done now if i want to add something brighter.
AM-JKLUYWx0g_Cjn4e3oHhc4ekQFCM3nbMLW-NcA
  • Like 5
  • Wow 1
i drove up to Kingman yesterday to wheel with @ChrisD while he was in the USA along with @stockjeep plus Bruce and Ric from the Rocks & Wheels FB group. it was 32* on the way up, but that craziness soon gave way to a nice cool but sunny day.
Gadget did great on the "Homecourt" trail,  spanking an optional waterfall early on:
AM-JKLUk8aWenShoie3op_0Y4mUBV6HOhM6mopbJ
only our fearless leader Wayne made it up "the big waterfall" later though... thanks mainly to a large tire-soaking puddle at its base, the rest of us couldn't get traction and had to winch here:
AM-JKLWGLOOeyI-n7rLNozEk3V-w72saDB4EffYR
AM-JKLUHtjaDQOWGXHUzf9SJt9aHdEiMAhltftM9
AM-JKLVJUyc-TYNO6Qxmjjr9NCUOuZXbfHzHGmph
just a few hundred feet before the trail ends, Wayne tried an alternative line on the last minor obstacle and somehow busted a front axle u-joint. he had the right spares, tools, and know-how to make for a speedy trail fix and we were still airing up by 3pm.
AM-JKLWo8r9ZUjET1ubnk_ILM64DI4NUsep5p55C
Homecourt was a nice "difficult" but not extreme rock crawling trail. Gadget escaped with only a couple small scrapes on one rear fender flare. i'd like to run it again without the puddles to see if i could get her up that one waterfall.
a big Thank-You to Ric Swats for all these photos!
AM-JKLW876aQkm7dQtQA9s-fedm66yx5bpQ52-KB
video of Gadget on Homecourt trail thanks to @ChrisD!
  • Wow 1
Them 37's just clawing away, Nice.
Posted (edited)
Aimee got me 2 new Rigid Ignite Series (flood pattern) LED lights for christmas. i already had a pair in the diffused pattern, which work great to light up the sides of the trail near the Jeep. i wanted these new ones to fill in the front corners better between where the diffused ones and the headlights hit.
AM-JKLXRtTvKalIWlVEkIC08gk1jJ6NJZdSTlga6
i really like that the tiny size of these make for a somewhat stealth install.
AM-JKLWzzF7i8MkHv54ziLnPyVhacrW6HrZpQnDj
AM-JKLVJ5XEVWnT0ExnOACd1Dm_dCGkyZ1nnc3eG
a couple examples of what exactly these are lighting up below. shots on the left are headlights only, shots on the right are with the ditch & cornering lights on too.
AM-JKLXEB73UnLdGTdb8IEllY6OI8DrHYiZ21pkR AM-JKLU6ybLeQ9wlZGWRxu1unIWdinsRs316MQi1
AM-JKLUZQ5lr1wWLpha2CbQuuqE7K71FDcm2AtR1 AM-JKLXrgEdNAVZcHBJR9Cv9_dRzDA_IGJGHsMzP
in this animated overlay, frame #1 is low beams only, #2 adds the ditch & cornering lights, and #3 adds the high beams as well as my rock lights. i ended up pointing the new cornering lights slightly more forward after this test.
AM-JKLUJkMx6WPU9md2XRsSPySXedJ1YiAaWyqRg
FYI, the headlights are ProComp and the rock lights are custom wired 12v COB LED "DRL" strips.
i'm very content with both the pattern and total amount of light i have for the typical night wheeling situations i encounter.
  • Like 6
