Dang, look at this very nice '91 XJ for sale $6,900
I don't know this person or this vehicle, but I thought I'd share. It looks like a VERY nice find!
gallery1
Link to the ad & contact info for the seller: http://www.ksl.com/index.php?nid=218&ad=39772631&cat=402&cx_navSource=fbShareMyAd
This is a well built and very well taken care of Jeep. We have owned this Jeep since 1993 and kept it meticulously maintained/modified.
4.0l High output engine with many mods
-Rockit large bore throttle body
-Throttle body spacer
-Livewire ignition coil/wires
-Doug Thorley stainless steel header
-Flowkooler water pump and thermostat
-High flow power steering pump
-K&N air filter with ARB Safari snorkel system
-Flowmaster exhaust system with high clearance head pipe
-ARB compressor
AW4 Automatic Transmission Factory Mopar Reman 30k ago
NP231 Transfercase 4-1 Ratio
-Teralow 4-1
-Teralow 2 Low upgrade
-Advance Adapters heavy duty short shaft conversion
-Upgraded shift linkage
-Heavy duty 1310CV driveshafts
-Full 1/4" steel high clearance skid plate system
Built Dana 30 Front high pinion Trussed with HD brackets
-4:56 gears
-ARB Locker
-Teraflex heavy diff cover
-Upgraded alloy inner/outer shafts with Spicer 760x joints
-Warn large locking hub conversion 5on5.5 bolt pattern with Premium hubs
Built Dana 44 Rear Axle heavy wall axle tubes
-4:56 gears
-ARB Locker
-Moser HD Axleshafts
-Disc brake conversion with integrated parking brake
-5on5.5" Bolt pattern
Custom 4" long arm suspension using Teraflex and Rubicon Express parts
-Rubicon Express long arms
-Rubicon Express HD track bar and bracket
-4"Teraflex coils
-JKS sway bar disconnects
-Rancho RS9000 shocks
-Custom rear leaf springs military wrap (Tons of flex no sag or axle wrap)
-Unitbody Frame strengtheners
-Poly Performance HD leaf spring mounts
-Teraflex extended shackles
-Full stainless steel brake lines
-PSC upgraded steering gear box
-Borgeson HD steering shaft
Custom bumpers and armor
-Full front bumper with frame/steering mount reinforcements, built in receiver and wired for a quick connect winch
-HD rear bumper with swing out tire carrier with HD receiver hitch
-Rock sliders tied into frame stiffeners and main body seam, step tubes built in for extra protection.
-Confer full length roof rack
-Bushwacker pocket style fender flares
-Full Weathertec floor mats
-CB Radio
-35x12.50r15 BF Goodrich Mud Terrains
-American Racing Wheels
There is much more to add and I will as I remember, this will not disappoint and is quite possibly one of the cleanest well built Cherokees around. The only downside is this received a rebuilt title in '92 when the Jeep was almost new. This was fixed right and you would never know and it has never had any problems!
Must see, please no joy rides and serious buyers only. Please text or call for more detail as I will not respond to emails.
Gee, that's almost identical to mine except that it has paint, good gearing, lockers .....
Very nice looking Jeep.
SOLD. Looking for a clean Jeep for Mason too, thanks for sharing.
