jgaz
Petroglyphs
Found this small panel on a side hike in Cave Creek Area last Thursday. There were a couple of other even better panels but for some reason the pictures didn't turn out. I'll try again next time.
Is that in the 7-springs area Jim?
I'm not familiar with the 7-springs area. This panel was off the drainage that leads back to the actual cave of Cave Creek. I believe it's a controlled area but I was there with a friend whose house abuts the drainage.
The other panels that I photographed (poorly it appears) were in the Spur Cross Conservation area. Quite easy access if you know where to look.
The cave.
