GRUNT
231 position
It appears your adapter is graduated in approximately 12-15 degree increments, where as a rotation of the case using the original hole locations would have resulted in approx 60 degree rotation of the case from original, per hole moved. :eek:
Got the Jeep back from getting the new transmission mount welded in. I had to push it from the street the driveway and into the garage. Due to the fact that I was by myself, and Uphill driveway, and its 173 degrees out, I am done for the day. I will get out tomorrow morning and position the t-case. Pictures to follow
You wimp, it was only 168 degrees today! Don't know how much of an incline you have, but that is quite the feat!
It wasn't a terrible incline but enough to whoop me. Ha ha
I just got done jacking the end of the drivetrain up, pulling off the mount and priming/painting it, as well as the tabs on frame.
