CampnFever 0 Posted April 27, 2010 Ok, got a "new" problem with the XJ. The steering shaft on the XJ is looooose, so I was going to get a new stock shaft, but started thinking, the XJ has 4.5"'s of lift and will a stock shaft be ok or should/is there a relatively affordable shaft for lifted XJ's... Any input is needed before I pull the trigger on a stock shaft. Thanks, Matt Share this post Link to post Share on other sites
theksmith 3,583 Posted April 27, 2010 Are you sure it's the steering shaft, or is there play in the steering box? steering box play is common on older vehicles and there is some adjustment in the box, as well as the box can rebuilt (probably easier to just get a rebuilt one from autozone though in that case)... and then sometimes if the TRE's are old on the draglink/tierod, that can also make for sloppy feeling steering... just throwing out some alternative ideas... oh and the actual steering shaft on a lifted XJ is no different, the pitman arm may or may not be a non-factory drop-style, not sure on 4.5" lift if a drop arm was needed, someone with XJ can comment Share this post Link to post Share on other sites
CampnFever 0 Posted April 27, 2010 Yea, its the shaft itself. I can "wiggle" it pretty good right at the point were it slides up and down. I believe that the only pieces on the front steering/suspension that hasn't been changed on the $#$%#2 thing is the power steering pump,steering box, and the shaft. Share this post Link to post Share on other sites
Number7 81 Posted April 27, 2010 I dont know how a steering shaft can get loose, maybe the u-joint is worn out. My XJ has a loose steering gear shaft that makes the steering loose. George:cool: Share this post Link to post Share on other sites
CampnFever 0 Posted April 27, 2010 I'm guessing just wear and tear ....it is right in the middle of the shaft, where the to pieces slide into one another. I found one on e-bay from a company called my4x4store out of Utah for 98 + 10 for shipping. Says it made by Crown , so I may pull the trigger on it . I've got a trip next month and don't need the shaft coming apart on me while driving:eek: Share this post Link to post Share on other sites
scottL 169 Posted April 27, 2010 i have to adjust my steering at least once per week to keep the steering wheel somewhat straight.. i'm considering an over-the-knuckle type set-up or maybe even hydraulic steering assist. we don't have a reputable xj steering specialist that knows aftermarket suspension set-ups i know of. i've been talking to Hunter in Tempe about it but i think he's more fabwork specialist and less mechanical work specialist. i see now you are not local. sorry if i "steered" your thread off course Campn'.. this is an issue i've been dealing with too for a long time. thanks for posting! Share this post Link to post Share on other sites
K7VZ 15 Posted April 27, 2010 Have you seen the steering I have on my XJ? http://www.higherground4x4.com/forums/showthread.php?t=2130 Share this post Link to post Share on other sites
scottL 169 Posted April 27, 2010 that's a sweet set-up Virgil; i know i've seen it firsthand at the xmas gift exchange... but my webbrowser won't navigate to that other website anymore for some reason. who installed it again? ps: i still remember your wife shared the tastiest cookies that day:D Share this post Link to post Share on other sites
K7VZ 15 Posted April 27, 2010 Does this link work? http://s715.photobucket.com/albums/ww153/4WD_HEADQUARTERS/Virgil/ Sy at 4wd Headquarters built it for me. Pretty simple and beefy design. http://www.4wdhqs.com/ Share this post Link to post Share on other sites
CampnFever 0 Posted April 28, 2010 Have you seen the steering I have on my XJ? http://www.higherground4x4.com/forums/showthread.php?t=2130 nice set up. I see you even have some RE stuff in there...but it is the steering shaft that is loose...the thingy between the steering column and the steering box. I may go to pick n pull and se what I can scrounge there before throwing a hundred bucks down for a new one. Now what years are compatable with my 93..hmmmm:confused: Share this post Link to post Share on other sites
