How To: fixing Jeep Wrangler JK flickering LED headlights (without a PWM adapter/harness)
It's a well known problem that a lot of aftermarket LED headlights flicker when installed on some JK's.
RKzcryxBWP9PJmr75-blSDxjhytAgKnhAnFFhXTJwtioYutyk2W-E6AqSV7_bZ93Gm7qa6HiYOAyQ851CzyhunHvqdM4Rl1XRfMhr8qYQK5Je6mt5uknQ7SlGRdJbXRNJkolC4jBoP5FtAXVoQ-r4FXuhLLlt14cFr_wbUXWdgi5wabNDpIxMwhKDlhzwSNVGCugSVrEMHQqUWPh0KfAkcZS3TgRC6DP0PfzuzhDW6ndc1yqpFpExrnqFTU-r4YRQjPI1vhT2CbAdtTcN7RUtFjdOm0IP_2dUgRN4zMgvypweVm8VsvF5ApxpaE_vwXcdjH6E_3F5wADZmBDk1jk2H-R8QMacD7kKcmCw3WYpVdJaHeY-obxr-DA1vRfjq3Opr8Jp4p5wztzVxLoatbJF40DENq4BdcqXFSCo7toHcTs59FSPfBWz-P9sToCRNZr947959OGFiC6uflCbRk1LDoczJS7-BotZnNZqXNwadVN1ipxJxuyZz6vt9WxQLbVzs26ejEOhqGGwoq5t5T1Sp9W8WO76ACa-u8YvhRfxkJBveQN1IFoLeN9uyuYtsfJZocLTnztjepYIb91Jt2lDxG_9dbqGzOAudManQwlXSuTDDDSeGW74eudtFlzrXrjn526wOFCkdLugiAyF-pm51P_aL-bh-NaUW-2mmdgfODT1C2J6PjOXspU=s500
Top-end headlights like the JW Speaker 8700 Model J2 have built-in electronics (smoothing capacitors) to prevent this, but many others require you to install a separate "anti-flicker harness" inline with each light.
I ran across a discussion on the AEV forum explaining how a simple software flash from your local Jeep dealer solves the problem without the need for extra electronics...
According to user "redrockjk":
The official OEM fix for headlight flicker is adding "quad beam" LED lights option code to your vin VIA "add sales code" in dealer connect.
He even details step-by-step what the advisor/tech needs to do: https://forum.aev-conversions.com/forum/all-aev-products/jk-parts-discussion-2007-jeep-wrangler/11659-2017-jk-led-headlights-swappable?p=161855#post161855
There's also mention from another use of the exact software flash (5SX) likely happening behind the scenes when this sales-code is added, which might be useful info for anyone with a non-OEM programmer.
It sounds like this little update doesn't correct flickering LED fog lights though, for that I guess most will still need an anti-flicker module.
