Ryobi 18v Cordless 6 Gallon Wet/Dry Vacuum
i received Ryobi's new small wheeled 18v vacuum for Christmas and really like it for typical work area clean.
pj4DoXGukW1-ictP5W44pjWuMFNfMqBndOTnyjlJP_InMWV82m7JIy5_b8Ay7xrg8YboZrRnCHFpytAO5thKhv4InasTfn3jtDP4R3slDd75IbgQc4eEdgQKMezMCUPdb_jh5OnioaX60AAJwrxuPUk6GT6HoqK9TfVVqZzsIN9qtrMv07cnZ6MBxYHO8du-ImfOPsrjoKRYI4xrT2T4164sQJEgvaBLS3MKEFMXv1fHfQMhpctbGa4v5h4cbayGdA9ppthr2u_OxI4ebSKm7TPhYesOUMTH34ZTMRF1ngOFgsYndQ-uddioF5l3zTAiVzP-ycAd-WS9sAoCcs7wOgAcgqxBeHHvI7qgm1F9e20MYiEvTLpr85-66dqsTEMT4fWAG5s1SA6TehBmd7h4MdQ4lFjpt0LersxS-KLzlJgwSSAwnhIvj_IzYfuQO_6xPpRzJgYqzCD40dDwmeibp5d4B2T4Oi-wkXzCQJtZH84CJ__J9OEcCwPfJhmFdVoj0tW6diPKszEnX6FlCWEL32ZpYyMW7kS2MocdtMIAKeumTkF1XmHYjWBsmOHNBn4ycxyvDrOBYbJ6_vXnIu-E_UKK36NnikmEZy3JulPF4GVsCw0TDAjAypxkjXJBn1kvWqHxLXhdfBLzXPo8d32GUKK4qDDPYCHf2kuAjxPhEFxv1uoUhsDTeYDDCe-kVUyXlbbc-uWFx4TlMRWCXw=s800
the main selling point for me is it's 80 CFM suction which rivals some corded vacuums. that's a substantial upgrade from this old model, which i always found convenient but underpowered:
BVWE60hBMUZr1jw6qccDyOixriBhHb2I63Qt9NieTgc0V4jLpYnToyERdXCBxduXofIxgQPgPB7xRTSFX2-eY5OIR304k7_ONEJlAC5ANxZdVcYlWPf6g7VtB3DUuJJQe0QQvf1ubX67AcgkKasxtJ4W-BMzpVHg5cnfz_f-GXLH7ET2sZW4YLLlYTIzuRO9sZHdJkuCRzyx7hGVNlmFcBxiGU5DLG7Utv8DWF5E8xAQ-CcU9gejQmWjBPn6-peeIj3Rgw5gZ9Z4arh0k07SetQtf7cE-082ED2HhB3lGT80ZDjd7slTawOINza-o-ZxWq5RpM-OpMndbS_eXdXA-XeFwptpkyOvt6M_TT2KnOPviOsT5g7VbcqR9HszGfxEWPLNYoNYMX2NEjwp6WPvHITz3m2GUiISeQiDL6NHBnh2zuDL9NlDcxCijQCJKwe--THqglTH-TeJEEI0TDCE3WuG6bS3sEUWohT-Hj9uagLHVGTOXLsBVYEiZEWhSl8xQrYhW6-T6vgN-AmaDXqHxsD2VpF-K9X-KRTJPdDVNXPYQziA8kU9nycOAGy3erWUJLdGE_nXFpsYMRHD2xkaiWFfFrGqi7596Y8nJUJOMXIShR1Nc6bMkyar3A6_2jjaDO8xTpHs7d82oojuoFT3n2-tLSt1221U8GHRGvhQOrvNJLpe7Podv5av8hHRVRCIJYUt6pNtHBqdy5wwMw=s800
the tip-wheel design lets you just pull it by the hose and the little dude will easily follow you along as you clean up.
pTQlrV9VELLr7mqiPd47T48-6m4_uvJaRT8jYwd8e2X6iZO9m8m51Nkykz2YV9EJUC3ZYBdWdSv0Kk3FZUGuyS2E0pJjecRWaQE2CBfWOceKJ6_OYJGm5NjL5ASkgDOoQvE7YFDxOSIMb4egeFfkNFmVjDZwMrM3MpabWAvV8V7WDRyHkc-QYRXcs64Ls4oDhKx-zlPq75e-IIwGZZBpXi6t5c0FIFCz86AUqX3IG3MJxUYR-Nm-oer-bKu_suT0YCdM6EhNFldaZ04DLWpsxHggozyGcPNHBNKCU73m-g5LCVxl25qOlgEtENRN240jw4R9RCNto6yDG_9Q11kqLMQZh71AZKJuupNjzMrqTWSybIvAO5z1dbLoQco-k2YfpcSgsXP6J-GclkaPsPlF9goR0hoY7kXqrvUyDTx5OX2HW5mRe8NziFfuSErnrAPnYt4vAx3tBj4NYS0wvZO_z5qVlWJxoYWStWozShcnpz0xUBIsSsp0SCBRyZt2q8Syr9Wptq8F4ZwAJVDeucUCCsTnocUtBI5Cr8P8Q2RK-0uTfTZq1fo4RaLLsZa06KChVoJptlYhTCUlFgnQojOWPi5V4KjNBSkYMHV6XGp0oy4_XAGc96DK2vdrGdF_tA7CE8kFAxquYMrzoMfRglDOKhAZbETmfCEhCRjAoY12UcMBKDlJ0eNyLPAikObDtIHCa65Hah_AuNg2PEZnuA=s800
my only complaint is not with the tool itself, but the overall package. Ryobi cheaped out on the included accessories. it only comes with a rather stiff 7ft black hose and 2 attachments (crevice & narrow floor tool).
fortunately it's a fairly standard 1 7/8 hose setup that is also used on some Ridgid, Craftsman, Dewalt and others. i purchased a brush attachment and car nozzle from Amazon right away.
i also found the included hose too short to even reach into the Jeep's back seat easily, so i swapped it for this 10ft Workshop heavy duty hose. note all the pictures above show it with the longer hose, which still stores nicely on top of the vacuum.
the 18V Ryobi 6 Gallon Wet/Dry vac is available at Home Depot as just the bare tool for $99, or in a package deal with a large 9AH battery and basic charger for $159.
summary: overall it's a highly usable and convenient vacuum but there may be more complete packages from other companies worth considering if you're not already invested in the Ryobi 18v line.
Cool Kris, thanks for posting this.
Speaking of Ryobi tools. I assume that you still are a fan of last Xmas’s 1/2 impact you received?
Have you tried the 9AH battery in your 1/2” impact? I was curious if there was a noticeable increase in torque or performance.
I used the older model Ryobi 1/2” impact model last week while helping a neighbor put a leveling kit on his F150.
My 3 year old, 4AH battery, made a very noticeable improvement in the tools performance over the 2AH that he had been using. Maybe his battery was getting weak but he said it was less than 2 years old and it was fresh off the charger.
Just curious
hey Jim, still have the impact wrench and use it almost every time i work on the Jeep!
i only got the bare tool vacuum, so i don't have a 9AH battery to try yet...
i'd be curious to know if the 6AH or 9AH delivered more instant-current than the 4AH as well. however, they seem a little large for use in the hand tools.
Ryobi only publishes the Amp-Hour spec on their packs as far as i can tell, but seem to indicate the 4AH versions and higher (labeled as HP) also have more instant-current delivery potential with marketing like "Lower resistance battery cells for maximum power delivery" and "Get the most performance out of your tool with the included 18-Volt ONE+ 4Ah High Capacity Battery which improves the performance of ONE+ tools up to 35%".
FYI, i also got a Home Depot gift card for Christmas and used it to buy the brushless Ryobi 4 1/2 grinder and i'm impressed! their old blue & yellow 18v model was nearly useless IMO but this new brushless version is on-par with the corded model.
i've only used it a couple times (with a cut-off wheel both times), so i can't comment on run-time yet. however, in terms of sheer performance, brushless technology is absolutely amazing.
EDIT: the reviews for this grinder aren't nearly as good as my experience so far... not sure why such a discrepancy. the 2 jobs i used it for were to cut and grind on some 1 1/2" by 1/8" steel (miter corners and smooth/round edges) and to cut through about 6 steel stakes (1/2" bar).
Hey Kris, Are you still liking the Ryobi angle grinder? I just received a HD gift card and was looking at the grinder on sale.
I have a good corded Dewalt but was thinking about the Ryobi in case I ever want to go on a crime spree.:eek::D.
Just Kidding, but wondered if your opinion had changed.
LOL!
i do really like it and still choose it over my older corded model every time, however...
the downside is the anti-kickback feature. now that i've used it quite a bit, i see what people are complaining about in some of the reviews. basically, if you press too hard it will just turn off instead of bogging down or possibly kicking out or breaking a disc. you have to release the switch and wait about 5 seconds and then you can start using it again.
the feature was a little annoying at first because i was used to abusing the corded model by really digging in sometimes. once i just learned that i had to use a softer approach, i got used to it and it's something i can live with for the convenience of cordless.
I used to have Ryobi cordless tools about 10 years ago. The tools were great......the batteries, not so much. The batteries only lasted 2-3 years. How much has battery life improved since then? Is the chemistry different now?
Thanks.
Thanks.
great question Gear!
i've had several of the Ryobi 4AH Lithium-Ion batteries now for a few years and they all still appear to be going strong.
the old NiCD batteries prevalent in many rechargeable devices 10 years ago were complete junk compared to even NiMH, and definitely in comparison to the modern Lithium-Ion chemistry. these newer batteries are lighter, last waaaay longer, and don't have significant "charge memory" issues.
i do only use their Intelliport charger which has features like not starting while a battery is too warm, and automatically switching to a maintenance charge once a battery is at 100% (if you leave it in the charger for days at a time).
also, i don't think the Lithium based batteries are as sensitive to long-term heat, but to be on the safe side i store them inside the house when not being used (instead of leaving them baking in the garage).
I agree with Kris and I’m going to add my experiences.
My first pair of 4AH Lithium-Ion batteries was purchased in January of 2013 as part of an after Xmas kit deal. At least one of these batteries was kept in the drill in my garage in Michigan year round for the next 3 years.
My second pair was purchased in December of 2015. All 4 of my batteries are now stored year round in my garage in here in Phoenix.
Maybe not a great idea but..... All four of my batteries are still going strong.
I’m just using the std charger that came with my kit in 2013. I’ve thought about getting the charger Kris mentioned but haven’t done it yet. The temperature sensing feature would be handy out here in the summer.
