Crawler Conceptz Ultimate Series Aluminum JK Front Winch Bumper & Smittybilt X2O Winch Install
Really impressed with your skills Kris!
Looks awesome! Painting it was the right choice.
thanks guys!
i took this picture showing the factory lower front crossmember when i first test fit the bumper because i was already contemplating what to do with it...
837FN_ako7D02GnsPT2NEMxE1Um2oIwMu9FAG9Y3OYXrBpZXyDOou6u3z5CeBE28vHLo82TWzr2TN8qnuC7elxnlYT25qsKqLTeeBE9klfyprYg8Nbvzcc2ojyjBU4nI-mkwSzvOxFl9A_Ub1kSvsrpqvabnNCPOsRIJuvot_Edh8f8GNQ6pO52OiDrnZ9b_kMJ_9ULYxTwQuYrf-Jw3czDKhbtaPajDPtq6pdIuDgd3H9AX_vrvpo98PJdKSiD4KBdsRcocDSDSCq-tY5bQzgYbQ9wOyfq_2OX9-VRMi9T4yxaB3-ZJEWzgBiHXT3HaD1gOWZP-LC3nsaJXai_OPnPKQM_DVe6B6_-h5qcHXQtj2k7R2k5dqRfxn_AB6DPuv3duXv0DDLCeQylIbVCevsyTtCeIy6fk7pCAI5PqIBalD9MMTT_hzUJxt0nOrj0jlg-XEj7LX8mmB8d-SL6xoWIePlscumjgWH1Cyb8MYSLz1YTb6_IxWX8Ra-v6_IDH2c3UFQVBnHCO-AMTVrvZCxVhLE7D17g7mpksvcByE79QGtGq0Ya_s_R2f4_9KC0WEqcEuapbtoIIRQQSXxKxnRzMzHy8BnsM92gBFcVX23OvMEFHQLOF6WFxF7tRqcz6MmhJwEY8RezBmJDDK8NyFJ9GqeOcRQTo7FxS1oWxw7HBxcoQ0O0ormE0Z0wNdLx8TcAe6VU-HgRAbDwHWDLCflj7=s800
a lot of folks cut it off, some weld something back higher up, others just leave it...
i was all set to just leave it alone but as soon as i had the old bumper and plastic air dam off it suddenly became a rock magnet. the first time out with it showing and i ended up gently tapping some boulders on there! ;)
anyway, it didn't seem very sturdy and was sure to become a pretzel before long - so chop chop!
1bvGLn_-O-VYe-FpUuYp1TAIWcqeobv08EfJWHbcPfDMgPxgA1nZ8iNLg4fSHZrqwwPzby9gQ0j2vp9IQf3eRNfgnUNNyWDEnQhBDRhmYuv2AJLw2n2YrhWsqTqmUrri9ODjyNxmG0-Fl09lfQqHON5ptSpZfHIlvXQ6jo9rjrpvyU3PJoBFvtElYSvOU0m0pPCF1lAQQPPWeRc0oTGMm98TOxTg5Zi9-ziJpiM_FJGQz3Uqv6s-1XklmnNkBWznloHvfSkwnqkZUNTKDNmWUzFyi8tsvqrLrs7-k1faW1nCauA4L6axhCP7Kb1d4qjeiSctiQfNI2qT0YQHDpONzxRhbprCgr3cFp_w82HdlEuW_NG0TGTldTxOi8C2wM_uwfYB1GGqn8kUcIDs7vbUD4M-Ieq6nrGU1Xb3R2uZg_crZ7DaEGRM8ZtlSfZ2V4PM3FYfNqDjZ4HjSdbuHV0JVo732nGG_mme11jFymqFZvyC77TCCaDCjaaVs7dQBl3FIG-H1zHieI3jgdr8QBUqpHb2trt6DuJuEEq6APfT10lcY-HZqR_USlNokKDLGuHCj1RTketESvC1lj-Z82OGzlYdMNTZY6GM9Op-MkuQRkh01xeyk_oRd0qkhWbiX-FwDsegqOkiD0CxV1R_AyrjkljULfAqZHM53KqwBQ1K1agCJaDDbvKC2I8mVx-YwIOMl25WYiDkSXSnPVlh9BQZVV1A=s800
yfS2lg1JUtgkdHoICyf8bFF4ATer1mSBwDANnnPMDBl8BsRGLGToGfqBtLRpHQBuHrqNIlLBxzvoYwB97sdq_gefv7VHI09-emlFGr6IBnmb4UB4dVTEu-ZRzVy8arCmdmOwlWHJGcQin1qdksCu8d2CIoyOIq3cb9GVeRifli7C6-lQmUQ5Jgq7wMyM1LkG2P6Ou_PH9nd5b9RHid1q-4txDGzVYRcAW6owcmqAVpiApogxdZl73uOyiZTm02rvX7By2wvwIeHmq7TS1yzstaqJ1E79slslYPJwb2GEo3gjlAMQfH1-kRGnpBVrGODk1no5Y67YCXPbt_S8-oFfuZ61wPvgWvHtCeRPuSTo9_YpdKO8Cf8n_V-Oz1gwfG1LUKPb6OWm0Koe7_ujFYsABknbT4LtF9yUgsXNtG1Dqo5Ts0ZPx_UOilxqbz-JOfIozLvlVutbrQzfvoCozVScXsBodbsVID_ofGADc8YpJ_esIO-ss7gClIibHl15O2aR3TSWDD6c0a97QJjcItAjx3excTg7hXxd4iwZLsY8ovEFChlx1O7irhBIxmOCP8dkpjpN58kCROMnsi5flLQQx6Gv-8FaHArPVQaF4tFyoo4dfGpGY9iQM1qI_6-AdpkgY53UfoEIUYIf7I-krRhUM1-5uf9cRpzE5KhKvMHlQRK1S7j3rsQZogjlXL-PrOOdvA1FSFO3OkkL_h8X3IikA_Jl=s800
a sawzall with a quality metal cutting blade made easy work of it, then i used a grinder to clean up the rough edges a bit.
auH2uXyot2yCIWZ1757ONcvj6_lI9M32ULquxCYqk_zs9OKAa_jhrbWF08Kk59uaFMSHOKkEHPayyLyBnvf5qOK7WtEpSV6gqsb-s9RT-wD_yD4MjNgvdtb6e8b8ZNBezUJQcX-19dC3CO_4WW_JXcgVzaBW6hgl-l-QfaayyDtfndEGscCuYUaXmCPfpj4xFKQeoSX5yJsNwpp6L3w_uld4PMxkQBv5QVDgDBYnHXWTQy1gG8_f0OFInWjM9Cjli_lcMTTKywgM-xUSQ9qdQwgD00mBtXjxr6fpoC9BZAbFlqPaMEg110qi7Hj8czf0_PaO7l4YElplvyRW4NdcefJAxux9lP9Rq1wieeWa4-AtfBuDEM8Ydvjra6VR1UR0hEz3EeeqZ8d4Ut6RcnLbK_HFHb86MRSiqH39lJtx8qP4n23sg6Gs8JFNnfw8rIFAOf1zZksFNq-AUEuppCsM1CgX3_ahBaeEQjBEU5GcxB7nOUwbeuml8ZpSnQTs_EeEXDbZQrs1pz-63aadxEcti_czqRL8urfE2ir2X2_EZIimtIMTleiAKo0ifM0Vkcn9sR0MAazMptPjXW4u-SM_jnHx69VjUTRqK6dyE5XOclGrEtfFKijFZa_OOYjdxNaoV7Ntb1FiQwWxRYJpV3BmEO9WL5GpM4qV6cR7Z1lVKDtzO0KkOK5PCT3uF4cJpBxGo5r_QOMIT852L5ujxqhvwE9E=s800
i added an Expedition One Rubi Skid Plate in its place.
hL1-NHjXox6nzN_EWATjKnbnEOBebvgilCjtHp5ffSvyTdcYKvIMEQ-UwZIdZ3cA-tW21ybejkJ7la1m9tYVCciSYYRjTxwJydCCiNOSCytKOczvdtEv0tACRHYJA-p1o2PbVbNGWFycGYJyeelXAE1G53oUEnI9aoavmChafmX6IP9DdYaGW7cH0z9Vfuv-IuAOlJ7SldVAxYLhjNqbKmAl6pdZln9FLLjEiqcOp3CSq_rVlPm03i3bnk1p9g58T3yD93TVYJPYCquhZCZ8Vmuuj42xkWCAY8XgW90Pw2D5Q0oo9BynRGJu_JhiMYOI5JSzh4UFBrgFOkD2EaJd-J2pxSRjg7Q3ABwhbtLBFU6L84QR_BX-PuQIY_ljQN1SXfCzS_kAWt0IVnZXV0Ff8neH42Cersxv5RY8YFKjk-_jdy0owLHNfq79IeIm7nToyGy1uVhzSOjRWmodSfUPEWlLiZFVKEKjELRW-DBODXl0G_ITdST-alZ_qYo0shk4u9VG2Mah4httXlOxns86drXpaNA42Lj35rZs3XM-an6xZ3YM60avyGeRZmfdpBulAch7ZvzAffllzWWnQrK69xOQhCWh-c_mVanwDggITOXoDHjvbVx-yWWTQYuOdoPXyVGe0KJYQACfalcMshLAexERImGuka2Ntk06A8wtoBNsRCby3YXWnKThpB4LUZVcS2Sgy0eFhRBK-X_65zswEBeD=s800
the skid works on any JK, but it's named "rubi" because it has that little dip for the Rubicon sway bar disconnect motor - you do have to flip the motor (which i had already done), but the skid comes with the required bolt for that mod.
HzojYDvNQlaqzqjhrQOnVKU51dvg4KbICyLYe0pCREZN8hMYTHxqn3IL4i1G-UTcXX5CVzx0cXuypeAWl7OZV2-J-rtCxtPzFLnALPCYnWfZnwIIWWZgv2Ryu4hfnDz---S-6I0P4GELuZo6XeMDabcUQQnBfia8lrsWdLyNX9EJgNqddEa_V3AqX06pKexNWdEYoLhs8BhPtY5THMvobyOBviHFShD5KRSu-7I4rH7tjFDvT0BYhg-gihRT-qWJcS50bMkC3BcdTNBfDMuBcE7YutE9RoB1ySlzCPNN0eSK8YLtkH5RpodESeXrf8LEvX4Sg7SDmzl2jBzvw-op88-giorbLk__cuzBVvsi9RpzCFVHUFz_9f7JXPyr-tyonEOu0xMyeLiOezPMj4e_ZDf6FiwVO1OI6_aW5EGqcaFR1mzLWCJLHNXdgayWDjKJ8wmnpYyMe1Rt3qV6AagxOGhZoiRApSRO6noZHyOvKb4ni0pyfByZW0WDsjSuVbzTW9USHh5FjniJd5OhN5grsYz8CGE9U_ByvrPUxsFvKb83Gw_gM3uz13r8RM8KIQBgslro9xBhh-dJ0Vgzx2JH16mpMLptfKHdsrj4qRrlNefZDZfzPTPOwVN1QWL2ePLoI4CPRuvZ8V3BbVaPYzqDihBDipYKpHe0xv0XaSrIKreQj4LEDtvkeFzY7ls97DBNltUnS-hbPu0Yvhl5EoIqvQHY=s800
i had to cut out a long notch from the front of the new skid so it would clear the Crawler Conceptz winch mounting plate.
wBcWVklm4y18bTNKDbdbduz119AsTnIJC9FUR1R0uS--_TeasvMWTpYFTb89jfjclliE3YlWTj9MUsPvy7-ags1gp9-c33DNOuyL9fa2D3dZ8B_YYjOGfgNjNOI7z3PZpbeTSCBtUp7grEdvlzCGUES3tnxLVa10Gfvp6U0NSPF-VpJqnytH7ghiR2u1o9pj1Ile2TnaxhuU4TITkrb-qPXjJFTxvrdmChWWnXoZ9a5ctACi5xdADQ8jXx9BRJ_NEEDPc8Io3UoRpX2UsaKyNBG8flHTlrB0YlAUQIBJgLBcyUyPASHkY3765L7CRw48PtMISL_P0BJMJC_XZVPrpoSGOYvLYdzNYLfxBzSO6TDZtcoMs0ZeIhHtew6SKMuSZcqEhpxq8MBTriUTrbMr9vHVhZR9RtTcMdZVWCGk6JzW1dNihyBclyclgMLGmUvrvGcsBmXRR5tR4Gz8cHl5dil2jSCYE9kvhBR_prjovcyzpaYF7F3sgqMa2ZFjAhTwq4OaIB8aAlO9Cu_2HAePdacOOJySAtAiZRJ-JtctQAquYPxuGeX14quEaTiR0ejZorxtvojoPQMe3lYvAX3Ief2fSg7yoU6kk2Nr6iD8PaluP8ySLbuSOcyGSpjO0YdXWRWMcFi9CSItckzhplZS0PL-UWRytb-lJXFy15lOHTHvkXxb-EI5OCyiItp81Fb9058xGqC9aJnn32WrLeHL2vwi=s800
removing the factory crossmember not only gives some additional clearance, it cleans up the look.
fxTKbOP426ESfC1TPJFQaCx53vV4DsBLQULst13bOawgB9TnAy4t3_pcRaGfUCl96wU3y5JMdKFT6bv-i-KetFavt6RG2b42s_pBKdHsPfToSWAQII2iqQXmv6bkUA9k9eD1gBcbRd3D9QGWaD99nc0jxIBb77P15P4LuOaUWtfyOgw7S3P38LyFWCCioJ6d75bOTcRsltnaYrCrocBNwM7puh_TR1WTylcslEI21S6Ik9YQqPtLdhm1tq4EMH1m5IzZuaTtRwe6Nwi397b7v5uK-4iOxcy0tF48Rs5JG5MNyF6G8HL6MCavKQnajpm-UDD7muHjNjR8h-mR2HkWZisvr8DyY64_m1s5_OJPnLJlVYSEDKoRsAGtqXlxm_wDap6j6eanf8RLSYNxrMDBShlFOqACy2xJLa-DbVNK28d9GZ-lkmMvDWnOVS99QNaT1KLy41Q0J5kVgLGjtekj48atLFznriYf-lJ_zI5GlYYkH9T0hBVUEyDzi5f_19nuApIpMr9vFUPeZjwRwQ0htoK_kua7gWLBsKjW4nFfnosfzNLg_ej94TcDlIY1ZHfJLjZ4DH5rhCSx6Uld78uevpnZo94Skh5ZdoUcYsw1hNQv7UtZ0DEMLanfMtkO7qTGrnn7AOag_NCRHrUoi5eDBmliW_-jEuY-41fuQ8sTTrNMunnv8PyBVxHMx5LDe60q0iGdiWcJMmVC2xkKtoc11woi=s800
-2u9jBmYmBVYvuKs2wChGOKcgHE7NRNsWlDSn--kaKrm-UQa3spzjEWB5a78ovQIA4fWQNqnuJysHD6OZDSlhR7JBV8eqY-43Tp5JO1SOiWim6Qlh1H2MtoAlpM_OrmaUNXlVppvgaSYps0dQ42sQsbYy02zVL-hSV8BsHDB7CHhValVnq25UZz8oJYSNTAXrszWYCjtxcgV3IfpRoZPFG51qu--dxSoUKE_9FWIsIzrZ7Q-2sGs1R3P7umqiRHNsemQrewxsAr4I7vz8qmPNY1ha96Fi0AQ6vfol_9dfRvByV8tb5oqsumAtUp8UDb7wPD-gI9m6kbvNDEyQaZF8Dxv93176keFWmqr84ABGQOhX1xT2f1hWbYyJ4uavnZLIe09AItZ9eDFwak58CHpIT5g4vN7IeMXB1IGTUib_7vax1hPSczzc8lNrymjhEm25eJfaXmDZz6wy8486q9Mg6HFSOPbkNjmZEN-ZoeiHAyRWuHutS3XxqNa2AbOrdV63wSCIySIx9MvOgs5_OBMqEiDinVsTx9jwgTIdUe6kbLh7_GZDx_Fk8brKNNW3ZDoqnsqpk9szIhdONEoRjsjaDgCLo7gSVQDeQ_DAAESEOZLVyOyT9djJSOmp3iHz0un4vQiah8SQDcSFiOAuPb913gdFK_2wWbofojeVkCgWa1eKqhoysVpzU2Ajl-rxlAxhAJmBxTPUFX9Z1RAN3cj5_i6=s800
this might seem like a drastic change, but the "real" main forward crossmember that ties the frame rails together sits just in front of the engine, hidden from view. with the new winch plate, new bumper and this skid all bolted in, i'm really not worried about any loss of frame rigidity.
I am an ARB guy. What kind of strap would you recommend in sand, snow, mud?
ARB makes a quality snatch strap. Bubba Rope also has good yank ropes in various strength ratings and lengths. you should probably wash and let dry any strap/line after use in mud.
one thing i didn't know till recently is that tow/snatch/yank straps should never be used with winching. they are meant to stretch and recoil which helps with a momentum type pull, however...
with a winch pull you don't want any stretch as that can create shock loads many times the rating of your equipment. use synthetic winch line extensions, or else winch extension & tree straps that are made from 100% polyester to minimize stretch (instead of nylon).
