4x4tographer
"Oki": 4x4tographer's 2018 Jeep JLUR
Just clicked over to 60,000 miles!
AJFCJaU1HKVJSnd3BZlZyo6Yj5rbiFe15limr7ZH
Minor update to my Smittybilt 5.56cfm air compressor set up.
AJFCJaWE1AYRxgDp9MZtMWsyHKeXHbK8sFybN9zH
While my compressor was sitting on the floor in the rear the plastic on the air gauge shattered.
AJFCJaUgM7k2DOrJ2iJ3QqYtT1vTYGktqjc1w1pg
The gauge and air fitting were hose-clamped on to the end of the original hose the compressor came with. After watching this video on modifying the compressor for a pressure switch, I figured it'd be easy to just ditch the hose all together and with the guage/fitting flopping around.
To make it work, you have to adapt the Smittybilt metric fittings over to whatever you're using. In my case, I picked up an M12 male to 1/4" male NPT fitting on Amazon and removed the hose entirely from the compressor.
AJFCJaVOvlwuem_KVZr2al0Hu9MJkMNQw4R49I81
I reused my brass t-fitting and added a replacement pressure gauge and relocated the quick connect fitting I've been using. I replaced the broken gauge with another from Winters, however this on is a little better built with a thicker glass face and is filled with glycerine to help prevent vibration damage on the needle.
My old gauge was always read a little higher than reality by about 6-7psi. Hopefully this new one is a little more accurate.
AJFCJaVQHVc79Jeq2Nt8WgNYAEnwkiU8JH2czC7M
A dash of thread sealant and a few turns of a wrench and this mod took all of 15 minutes to complete.
AJFCJaW63Rr28OrPDac_2W1kQLb0KK3zQ93v8fL2
AJFCJaXe2ZVb889uHrTMecoyLkzGa47FY5pdP95U
And there you go. The solution to a floppy hose! 😁
  • Like 8
