4x4tographer
Hard mounted HAM Radios?
I to am radio ignorant and in need of advice.
Decided on a Yaesu FTM-400XDR but have no idea on what antenna (height is not a issue) to go with to maximize the capability of the radio. Any real world jeep relevant info would be appreciated
i like a UHF (PL-259) style mount because you can often use a regular CB antenna bracket and just drill the hole a little larger. the Diamond Antenna C213 is both a cable and UHF antenna mount - you'd just need a bracket.
i've used the 38" Diamond NR770HB antenna on multiple rigs and it performs great, it's dual-band so would work well with your radio.
lately, when i remember to put the antenna on ;), i've been running a Comet SS-680SB since it's only 27" and fits in my garage. it's also dual-band and works well, but the Diamond definitely picks up from longer distances.
Thanks for taking the time to fill my brain, sounds like the 38" diamond is the ticket
On 2/19/2020 at 5:46 PM, SonoranWanderer said:
Hey SonoranWanderer, Sorry for the necrothread but are those ram mounting plates just mounted to the plastic, or do the screws go through into the metal at all?
Nevermind, I looked them up and it looks like it's probably just mounted to the plastic. I see that they have one for the JL/JT that looks like it has a steel mounting plate backer that also bolts into the frame somewhere, but the others just look like they are exactly what you see in the picture you have without a backing plate.
Edited by mesach
Actually did some research into what I was asking.
The RAM plate is plastic and it is bolted to the overhead plastic. The weight support for the overhead plastic beam of a JK is limited. It holds that radio head (FTM 400) great without deformation or deflection, but not so much for my old Garmin Monterra GPS, which is a brick. It would probably support a phone, but not much else.
Following so I can post up after I get pics taken.
