On-Board Fresh Water & Hot Shower (in a Jeep Wrangler JK Unlimited)
On 2/4/2020 at 7:12 PM, jgaz said:
I love the use of the fuel door to cover the water fill cap. Genius!
No worry about resale.  Most will think it has duel tanks!🤣
I didn’t realize the brushless Ryobi Drill had a threaded insert to accept a side handle.  My old non brushless drill doesn’t have the ability to use a handle.
if you’re ever in need of  a hole saw for one time use, and don’t want to buy it, hit me up if the needed size is below about 3 1/2”?
I have a large assortment of various sizes that I’ll loan you.
Agreed Jim...  Nicely done ;)
PS:  Kris,  I also have a decent assortment of hole saws...  Just in case the mood strikes again... ;)
PS, PS   Welds don't need to look professionally done if they do thier intended task of holding stuff together... ;)
Edited by ob1jeeper
this weekend's rock crawl was brutal to my undercarriage...
BMIw5M-0CYrOkplum1VO30xrovYmE6ARLqxHlzX9
the good news is my water tank bracket/skid seemed to have survived the beating with nothing but a few paint scratches (unlike my DS boot)!
UrWWbPLki6cLbOgXS3US3g7WpQNAL-ERMgHEZLKP
i'm nearly done adding the heat exchanger and related stuff, more on that (plus a couple minor tweaks) coming soon!
_MXilhaaJw91NqcPL0izhzGPNHz6yW-k7BCCc5NY
i swapped out the Amarine-Made 12v pump for a Seaflo 21 Series with adjustable cut-off pressure (model SFDP1-012-035-2, specs here...)
the Amarine-Made had a fixed 35PSI cut-off which caused a brief but powerful surge of water when you first pressed the sprayer trigger. the Seaflo's cut-off is adjustable down to 17PSI, which made a noticeable reduction in that initial surge. the Amarine-Made was also annoyingly loud. the Seaflo is quieter and comparable in sound to the much more expensive Shurflo i used in my previous vehicle.
for only $10 more, i definitely recommend the Seaflo.
GUljDaw7RAiUqE6u6QIfBhZUgjOmOBGnwUusgokk
hot water!
i sketched out a plumbing diagram for the whole system (just the fill-hose and breather line aren't shown):
3WT1watewVPXx5z5WiYX6kW7hVpLsBYEu-23QP_j
an under-hood photo showing the heat exchanger which is spliced into the heater core return line.
LJKTpLiyQmcdj9G1CT1lA_XroNkODRONziUZ4Mrb
i might should have gone with a 20 plate exchanger. the 10 plate isn't efficient enough to heat up the water to an acceptable shower temp *until* the engine gets to around 180*. the only problem with that is the JK's 3.6L takes a good 15 minutes to get that warm from a cold start if it's just sitting still idling.
the heat exchanger is just zip tied on, but that seems to be holding it in place just fine.
pfC225CMQF-hPwDx9pUU7XjDLOBCOOy5VrWFR589
for reference, the bottom (passenger side) aluminum line in this "before" photo is the heater core return. i disconnected the rubber hose coming to it near the firewall to splice in the heat exchanger.
d6q599tz7iUMzI7HlrJebxPFPXRW5tw9YiOYLUCQ
one item not shown in the diagram above is the coolant bleed/fill valve that i added. since all of this new stuff is higher than the radiator fill, air bubbles would be trapped in the lines without some way to bleed from the highest point.
rpYseMdmawv5wcvCZorsuc4QNOhSnQ88ieJxVQSQ
the thermostatic mixing valve was placed under the front wiper cowl next to the pump.
cVunndtT1cdNeiaq0vpkkgGtFhwJSxmkcQuxO_O2
X_xCtcQudU_5v6Xj0P3gm-wxlbz-a3CmLiXjj2Vd
it's not something that would need to be adjusted often, but i can access it with the hood open if necessary.
I_p8VhhY7FWLhiCGGoXRjdsOXOEpDpCgVWZXlKS-
when water sits in the heat exchanger for a while, it can reach the full engine operating temp (over 200*). so the thermostatic mixing valve is needed to provide a consistent "warm" output, regardless of how hot the engine is or how fast/slow the water moves through the exchanger. it does this by dynamically blending the cool tank water with the hot water from the exchanger.
another issue i encountered: because the "cool" line coming from the tank runs above the engine/trans/t-case, the water inside it was heating up to the point that that the mixing valve couldn't do its job and i was getting a brief initial pulse of scalding water from the sprayer. the solution was to insulate the cool line where it ran through the tunnel. i used common foam pipe insulation tubing and then wrapped that with aluminum duct tape.
6UFO5rs2osVOR026E48GrH15b2s-58kWfMUD7ptm
one final thing to note is that i have some "straight" and some tapered/conical thread fittings. these shouldn't normally be mixed, but can be made to work just fine in this low-pressure application... for any joint, if the female side is a straight thread ("pipe"/IPS/G/BSP/"shower") then use a rubber washer and if the female side is tapered (NPT), use teflon tape.
jMpttlFIdQxfqOjodVG-TM6RN1SkhdrbR1V-a_h8
shopping list for this part of the project:
Female side.. I like it
discussing weird science GIF
  • Haha 2
finishing touch:
WWdwRo6fO7gAgu0VHMrYkeaTc1buUcDgBmYkXzia
Very “clean” installation.  😉
A lot of  thought went into this project, as usual
Ditto Jim... ;)
a couple minor tweaks...
leaky flush tee
the Dorman flush tee i had installed as a fill/bleed port at the new high-point in the system was leaking a tad. i didn't like that plastic thing when i got it and had already purchased a metal replacement from For Seasons but just not gotten around to installing it.
leaky part:
ACtC-3fNywVKIT0xjmGdCfqPlNIwOQM00Juus77X
replacement:
ACtC-3d_pEkzpQlcu0qH3L4JxXwatmHjdfpMuBsr
too hot!
after idling for a long time or doing a slow 4-low rock crawl type trail and then using the water, i was still getting an initial surge of scalding water. i talked about trying to insulate the supply line to prevent this before:
Quote
that attempted solution was obviously not working out, so my new idea was to re-run the supply line from the tank out along the edge of the Jeep, away from the hot "tunnel" area.
ACtC-3fSABlyaGDkW5SMptehzSoR6LWyzATdIooG
then route it up inside the passenger fender as far away from the engine as i could realistically get it.
ACtC-3duE1frY7PU33UkSaWJQxy7h_nsNabdL2ZC
i'm not sure if this is the final fix for the too-hot water - i still need to test it on a hot day after a long slow crawl.
other than those 2 minor things, the water system has been working great so far.
leaky flush tee
leaky part:
replacement:
too hot!
Kris,
I was glad to see that you replaced the plastic tee in your heater hose.
Many moons ago  ( in the mid 70’s!) I worked in a Standard Oil gas station.
We used to install a very similar tee in the heater hose line in order to connect a very effective coolant flush and fill machine.   Darn near every tee we installed developed a slow leak at the screw cap.  It got to the point where we just replaced the customers heater hose after the flush was completed.  It was easier to eat the cost of 3 feet of hose then to deal with the “comebacks” after the cap leaked.
I thought about this when I saw your very slick installation but didn’t want to be “that guy“.   The one that says, “you know what you should have done?”.
You’ve done a very slick installation of this hot water system.
