GRUNT
Does my Jeep have the Corona?
On 5/23/2020 at 3:38 PM, Curly said:
Grunt, I don't think the TC seal is leaking, that would put the fluid closer to the flywheel, and the pic of the wiring connector makes me think this is where the problem lies.  If I were doing the work, I would replace the wiring seal where the plug exits the case, and if that entails removing the pan, then replace the pan gasket then.   The shift shaft seal doesn't appear to be leaking either.
Another suggestion is to get some UV die, available at NAPA, Auto Zone, etc. Clean the mess as best you can, add the fluid to the trans and then run it.  You check for a leak with a black light and special tinted glasses.
To answer your original question, maybe. :) Depending on the trans, the shift seal may need a special tool.  Front seal (Input seal) probably doesn't but I can't say for sure.
I agree with Tim's assessment.
Sorry for the late reply, we just got home from a week in Moab... ;)
