shellback91
Fire Extiguisher
With regard to the Element extinguisher, for anyone who does or plans on running it, where are you going to keep it? I ask because my current "cheapo" extinguisher set up is haphazardly attached the the roll cage. Similar to the location of others, the extinguisher is easily spotted for use by myself or those that need to employ it. After I aquire an Element extinguisher, I am thinking about keeping it in a bright red bag located on the rear wheel well.
Thank you in advance for your input.
Allen,
One of the accessories on the Element Fire website is a roll bar mount
https://elementfire.com/collections/allproducts/products/roll-bar-mount
I plan to use the roll bar mount for my Element 50, and then store the second extinguisher in the cargo tub.
Russ
Even before decking the rear this 5lb fit into the contour of the panel perfectly. Even when loaded with gear and dog's it's readily accessible.
I mounted the Element fire extinguisher on the Sport Bar.
